Electrical advice - house lighting.
c_dug
PostPosted: 18:01 - 12 Feb 2014    Post subject: Electrical advice - house lighting. Reply with quote
Evening all.
tl;dr Can I use 100W lamps in a 50W fitting?
In my rented flat at some point an idiot owner has replaced the standard drop down lights with puny 12v 50W spot lights, on a one out one in basis. The result is frustratingly dim rooms that should really have triple the lighting they do.
Anyway one of the lamps blew and I borrowed a lamp from work to replace it but I grabbed a 100W lamp by mistake. The extra 50W over standard has, predictably, made a huge difference to how bright the room is.
I know short term it won't be that dangerous, but long term is there a real fire risk from running too high watt bulbs?
Obviously not being owners we can't just change the fittings.
hellkat
PostPosted: 19:25 - 12 Feb 2014    Post subject: Reply with quote
Surprised you can still find 100w bulbs. Did the govt not make them illegal or something? They're a fucker to find these days. I love 100w bulbs so much. Brightness rules. Eco light bulbs suck donkey dick.
Just leave the 100-watter in there; if it blows, it blows. Life is too safety conscious these days. It's no worse than risking eating a sandwich a day after the sell by date.
Live a little: have 100w bulbs in every possible socket.
Just remember to switch it off after you've finished in that room Shocked
Mark_F
PostPosted: 19:26 - 12 Feb 2014    Post subject: Reply with quote
Depends on the transformer(s). If you can get access, find out how many there are (maybe 1, maybe 1 per fitting, maybe several each powering several fittings). There will be a sticker with specs for either max current output or max wattage (or voltamps).
Need to know how many fittings per tranny, and max output current (or max wattage), then can calculate.
Tranny will look like a little box about 5"x1.5"x1"
panrider_uk
PostPosted: 19:32 - 12 Feb 2014    Post subject: Reply with quote
The new breed of LED lighting is nice n bright.
I switched my kitchen over from 8x50W halogen spots to 8x5W LED and it's much brighter and using a tenth of the leccy,
PostPosted: 20:36 - 12 Feb 2014    Post subject: Reply with quote
I got some utterly acceptable LED GU10 spotlights the other day with a warm, white light (even in the same room as a halogen) and a diffuse beam pattern thanks to a diffuser lens over the end of them.
Shop round, look at tone colour and beam angle.
MarkJ
PostPosted: 00:03 - 13 Feb 2014    Post subject: Reply with quote
Some LED bulbs are complete crap, but I can vouch that this 5w LED bulb is good Thumbs Up Got it on the landing upstrairs and the beam spread is nice and wide, and appears brighter than the old 50w when compared side by side. The light is more white than the yellow that comes out of the old halogen bulbs.
andyscooter
PostPosted: 09:24 - 13 Feb 2014    Post subject: Reply with quote
if we put anything higher then a 40 watt in the bathroom we get a fishy smell from the fitting
but thats a normal bulb not a spot
robs321
PostPosted: 17:55 - 13 Feb 2014    Post subject: Reply with quote
Thats the usual smell from melting pvc cables!
I have a fair few of these https://www.bltdirect.com/bell-g9-halogen-adaptors in my house to replace the old BC Gls lamps. Nice bright halogen light and you can get all different shaped globes to go on them!
The last post was made 12 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 57.89 Kb
