Valve clearances
Jonathan A
PostPosted: 00:22 - 13 Feb 2014    Post subject: Valve clearances Reply with quote
My Hyosung GT650r had done 11000 now, Would it be the time to worry about valve clearances now, or could that wait (it has shims, if that helps)
Thanks Very Happy
flumpy7
PostPosted: 00:40 - 13 Feb 2014    Post subject: Reply with quote
What does the manual say?
2012 Sinnis apache
Jonathan A
PostPosted: 00:48 - 13 Feb 2014    Post subject: Reply with quote
It says inspect every 6000km, which is the same interval for an oil change. Is this a bit excessive?
doggone
PostPosted: 01:39 - 13 Feb 2014    Post subject: Reply with quote
Shims don't need attention anywhere near as often as the locknut type, but if you've already skipped the first recommended check it would be wise to do them soon - and not need worry for another 10,000 miles.
Quornholio This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Jonathan A
PostPosted: 10:15 - 13 Feb 2014    Post subject: Reply with quote
Is it a simple enough job to inspect them myself? My garage quoted £200 Sad
Or as doggone said, could it be left another 10,000 miles?
doggone
PostPosted: 10:48 - 13 Feb 2014    Post subject: Reply with quote
I would have them checked, if they say one or two had drifted quite a lot - or nothing needed doing - it would help you decide how long you dare leave it next time.
The garage are charging mainly for time spent stripping things off to access them.
Once the feeler gauges can be used actually changing shims if required does not take long.
PostPosted: 12:13 - 13 Feb 2014    Post subject: Reply with quote
It's a bike with no current importer and a limited pool of potential buyers.
If you're realistically planning on riding it into the ground, check 'em. If you're going to punt it on soon (where soon just means "5 miles before it shits itself"), I wouldn't bother, you won't get that money back.
Jonathan A
PostPosted: 15:31 - 13 Feb 2014    Post subject: Reply with quote
Thanks for the replies. A dilemma I have is that I need to change the oil and filter soon, and from what I gather the oil has to be drained to check the valves Confused
A100man
PostPosted: 15:51 - 13 Feb 2014    Post subject: Reply with quote
Valves are at the top - oil sinks to the bottom.
You might lose an egg-cup full from under the rocker covers
but no need to drain. Never did on a beetle engine and that's a flat four.
200 sounds excessive unless it includes required adjustment/parts etc. A decent mech should be able to check them in 1 hour/1.5 hour I'd of thought.
But then I suppose decent mechs are thin on the ground.
J
PostPosted: 17:52 - 13 Feb 2014    Post subject: Reply with quote
I'd assumed £200 is including a service, but maybe not if OP is doing the oil and filter himself. Might be worth listing (and asking if you don't know) exactly what's included in that quote.
Jonathan A
PostPosted: 19:03 - 13 Feb 2014    Post subject: Reply with quote
The £200 was for oil and filter, plus valve clearances (not including parts) and carb balance (which was done 5000 miles ago anyway). I suppose if a carb balance isn't needed and and I do the oil and filter my self it might not be so much.
flumpy7
PostPosted: 19:46 - 13 Feb 2014    Post subject: Reply with quote
Best practice is to sync the carbs after a valve clearance anyway
2012 Sinnis apache
Nobby the Bastard
Harley Gaydar
PostPosted: 20:43 - 13 Feb 2014    Post subject: Reply with quote
HA HAHAHAHHAHAHHAHA
Oh.
You're serious.
Tell them to fuck off and do a basic vehical maintenance course at the local college. It'll be cheaper.
Triumph Sprint ST 1050
PostPosted: 21:24 - 13 Feb 2014    Post subject: Reply with quote
Jonathan A wrote:
GT650r [...] carb balance
2008 or older? I wouldn't spend a penny more on it than you need to.
The last post was made 12 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.92 - MySQL Queries: 13 - Page Size: 82.59 Kb
