| Yamahardon |
 Yamahardon Renault 5 Driver
 Posted: 19:46 - 15 Feb 2014 Post subject: Rebuilt my Yamaha Blue Spot Calipers |
| workboots |
 workboots Two Stroke Sniffer
| Howling TerrorOutOfOffice |
| Fizzer Thou |
| _Iain_ |
 _Iain_ Banned
 Posted: 14:43 - 17 Feb 2014 Post subject: |
If it's only going on the back of the pads grab a sachet of Wurth Brake Paste when you pick the pads up. Stuffs awesome for preventing squeal & as you apply it by finger then it's a lot less messy than an aerosol!  ____________________ Please be aware that the above post may be full of complete nonsense.
| Souleh |
 Souleh Trackday Trickster
| Yamahardon |
 Posted: 19:14 - 17 Feb 2014 Post subject: |
Yeah in hindsight I did go a bit mad with the grease.
I had been watching this video the night before i went to pick up my parts: https://www.youtube.com/watch?v=tUyGTvLDrt4
and thought I'd give it a go with the aerosol.
I think ill be removing the pads, springs and pins and cleaning them again, then applying a sensible amount of slip to the back of the pads.
Fizzer thou, did you re use the seals? £134.10 yamaha charged me for new ones, i was gutted!
souleh, I used around 4 500ml tins of carb cleaner, i prefer that as it seems to cut through the grime better than normal brake cleaner. Lots of compressed air, many tooth brushes and lots of autosol were used too. |
| J4mes |
 J4mes World Chat Champion
 Posted: 19:20 - 17 Feb 2014 Post subject: |
How did you get the jammed piston out? I have to do mine shortly as I have one jammed in!
Won't be paying £135 for the bits either!!  |
| Yamahardon |
| J4mes |
 Posted: 20:24 - 17 Feb 2014 Post subject: |
Yeh Blue Spots.
Looks like a good reason to justify buying a compressor to the wife!  |
| stevo as b4 |
| Fizzer Thou |
 Posted: 23:31 - 17 Feb 2014 Post subject: |
According to www.exup1000.co.uk you can remove the blue/gold/silver anodised plugs but the seals are not available from looking at the R1 parts fiche.
But looking at the XJR1200 parts fiche (I think it is that bike ) then the seals are available.
OP.If you still have the old rear seals,may I have them please??
And yes I did reuse the old seals in the caliper rebuild shown above.The bike had only done 30k miles and were perfectly reuseable. ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| drbaig |
 drbaig Crazy Courier
 Posted: 03:53 - 18 Feb 2014 Post subject: |
I did mine recently on the thundercat as they were a bloody mess. Binding really bad, I had an awful turning circle.
To get the jammed piston out I clamped the opposite piston with a monkey pliers wrench thingy and jammed a piece of wood between the other two. Then put a bicycle pump with a conical fitment into the banjo hole (I have a good bike pump, I cycle a lot). Pump a few times and it pops the non clamped piston out. I couldn't be bothered making compressor noise at 2 in the morning.
Then you clean them one by one by using cotton, brake cleaner, dental pick, toothbrushes. etc etc. choose your weapon.
Once clean put the new seals in and repeat the procedure. It took me half an hour to clean each piston. Nightmare I tell you.
I honestly have to say I was surprised to see how clean OP's table is. Mine was a mess with brake fluid everywhere. Fork seals and caliper rebuilds are something i do not like doing because of the mess. ____________________ yzf 600r  |
| Yamahardon |
 Posted: 23:24 - 18 Feb 2014 Post subject: |
| Fizzer Thou wrote: | According to www.exup1000.co.uk you can remove the blue/gold/silver anodised plugs but the seals are not available from looking at the R1 parts fiche.
Fizzer have you got a link to this about the plug seals?
Captain obvious alert but you do know the rear blue spot I've got is the XJR1300/FZS1000 one not the R1 one, don't know if the seals differ but just thought I'd point that out. If u still want them send me a pm.
| drbaig wrote: | I honestly have to say I was surprised to see how clean OP's table is. Mine was a mess with brake fluid everywhere. Fork seals and caliper rebuilds are something i do not like doing because of the mess. |
Did all the shit bit at work then brought it all home when it was clean, She'd kill me if I did all the mess on the breakfast bar  |
| Yamahardon |
The last post was made 12 years, 248 days ago. Instead of replying here, would creating a new thread be more useful? |
