Fazer Missing at high revs
Banger
PostPosted: 17:22 - 20 Feb 2014    Post subject: Fazer Missing at high revs Reply with quote
Recently bought the bike, Carbed Fazer 600, and the 500 ish miles I have done on it so far have all been on wet, busy commutes through London.
Finally got a chance to pin it a bit today only to find at about 9k revs it pulls back / misses. Feels like I'm hitting a limiter. I didn't have space to really try and pull through it.
I'm thinking plugsor leads arcing out is the first place to start. I'm waiting till it gets dark enough to visually check for arcing atm.
Bike has only done 6500 miles, last service in book about 1500 ago.
Any suggestions or thoughts on what else might be the culprit ? Thumbs Up
You only get one lap of lifes track . . . . so make it a fast one !
Yamaha . . Keyboards to biking nirvana.
YBR Ric
PostPosted: 15:26 - 21 Feb 2014    Post subject: Reply with quote
HT leads.
Bloggsy
PostPosted: 19:29 - 21 Feb 2014    Post subject: Reply with quote
maybe ht leads or one or more plugs could even be carburation
Banger
PostPosted: 21:30 - 21 Feb 2014    Post subject: Reply with quote
Replacement set of coils and leads sourced and on way. Thumbs Up
Could't get her past 100 or 9k rpm on a run out this evening. Sad
temeluchus
PostPosted: 21:35 - 21 Feb 2014    Post subject: Reply with quote
try draining the float bowls, on the off chance there is some water in there.
Sid_The_Sloth
PostPosted: 00:33 - 23 Feb 2014    Post subject: Reply with quote
My Fazer is the same, but holding the throttle open it does get through the stutter and pick up. Mainly only happens when I whack the throttle open so figure the carbs need cleaned and balanced. Chucked it into the local garage as I couldn't be arsed with the hassle. So shall see what its like when its back.
2013 Honda Shadow VT750C2B Black Spirit, 1994 CBR600 f2
Sid_The_Sloth
PostPosted: 23:14 - 28 Feb 2014    Post subject: Reply with quote
Did this sort the problem for you?
Banger
PostPosted: 22:44 - 01 Mar 2014    Post subject: Reply with quote
Swapped the coils and leads this morning and bunged new plugs in while I was there.
Problem sorted, runs like a dream and pulls to the limiter. Thumbs Up
Sid_The_Sloth
PostPosted: 23:43 - 01 Mar 2014    Post subject: Reply with quote
Good to hear. Similar problem to mine but completely different fix. Mine had a new air filter, and carb clean/balance and all is sweet.
The last post was made 12 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 1.77 - MySQL Queries: 13 - Page Size: 58.78 Kb
