What questions to ask when buying a bike
SpuceLee
PostPosted: 20:18 - 22 Feb 2014    Post subject: What questions to ask when buying a bike Reply with quote
Hi,
I've just passed my cbt and I'm looking at getting my first bike (which will be used). I just wondered what sort of questions to ask when I go to have a look at bikes?
Obviously I'll need to see if it runs smoothly etc but what else do i need to know?
Thanks!
Davenaylor
PostPosted: 20:49 - 22 Feb 2014    Post subject: Reply with quote
Get this months ride. It has a full section on used buying bikes for under £1500 and tells you what to look for when viewing.
kerr
PostPosted: 22:15 - 22 Feb 2014    Post subject: Reply with quote
https://www.youtube.com/watch?v=tExM88-pF-U
As good a guide as any Thumbs Up
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
Ribenapigeon
PostPosted: 11:33 - 23 Feb 2014    Post subject: Reply with quote
"Is it a motorcycle"
jeddy11
PostPosted: 11:45 - 23 Feb 2014    Post subject: Reply with quote
Get a chum who does know bikes to go with you then you can also blame them if you buy a lemon.. Thumbs Up
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
PostPosted: 11:53 - 23 Feb 2014    Post subject: Reply with quote
How long have you owned it and why are you selling it are the only questions I ever ask - if I ever ask. When you're buying a used bike privately, you're better off trusting your own eyes and ears and being cynical about everything.
lihp
PostPosted: 12:56 - 23 Feb 2014    Post subject: Re: What questions to ask when buying a bike Reply with quote
How fast is it?
Can it wheelie mister?
sidewinder
PostPosted: 18:05 - 23 Feb 2014    Post subject: Reply with quote
You want to see a valid mot + logbook before you go any further. ask about service history what has the bike been used for?when you ring about a bike you want it to be cold so you can hear it starting up . Thumbs Up
CaNsA
PostPosted: 18:10 - 23 Feb 2014    Post subject: Reply with quote
-Check the discs dont have a massive ridge at the edge.
-New brake pads
-Ask about the wheel bearings, put it on the centre stand and spin the front wheel, and the same with the back. check for a grinding/knocking sound from the centre of the wheel > if so then new bearings.
-While on the centre stand, sit on the bike, lean back so the front lifts a few inches and slowly move the bars from left to right. If you feel any notches then you will need new headstock bearings, ballache of a job to do and costly on labour if you got to a garage to get it done.
-Check chain and sprockets
-Listen for a knocking sound from the engine.
-Ask him not to start the bike until you get there, you want to see how easy it starts from cold.
-Feel the engine before it starts to see if he has warmed it up. If he has, ask why. If you dont like his answer walk away.
-Look on the downpipes for any holes, and feel/listen for any blowing from the downpipes and exhausts pipe and can.
-Take the oil filler cap off and look for any white cheesy looking gunk > water in the engine not good.
-The gearbox should make a re-assuring "THUNK" when you knock it into 1st gear. The clutch may rattle/rustle a little and it should stop when you pull the clutch in.
If at any point you get a bad vibe, not to be mistaken for a scared of the "new" vibe, then walk away. there are thousands of other bikes out there.
bren_9311
PostPosted: 18:21 - 23 Feb 2014    Post subject: Reply with quote
What's your best price? Cool
My opinion is neither copyrighted nor trademarked. If you like, I'll trade for one of yours.
Currently bikeless. Sad
Ps4- bren_9311
SpuceLee
-New brake pads
sidewinder wrote:
You want to see a valid mot + logbook before you go any further. ask about service history what has the bike been used for?when you ring about a bike you want it to be cold so you can hear it starting up . :up:
Thanks very much! I'll be sure to employ all of this advice.
snomag
How fucked is it? Laughing
CaNsA
PostPosted: 18:22 - 23 Feb 2014    Post subject: Reply with quote
what colour powerband is in it?
SpuceLee
PostPosted: 18:33 - 23 Feb 2014    Post subject: Reply with quote
Excuse my ignorance, but what is a powerband?
CaNsA
PostPosted: 18:35 - 23 Feb 2014    Post subject: Reply with quote
https://www.planetash.net/gos/powerbands.html
bren_9311
PostPosted: 18:36 - 23 Feb 2014    Post subject: Reply with quote
Pass the popcorn
Ps4- bren_9311
SpuceLee
PostPosted: 18:56 - 23 Feb 2014    Post subject: Reply with quote
So presumably this is something that the seller will know?
Northern Monkey
PostPosted: 18:59 - 23 Feb 2014    Post subject: Reply with quote
The easiest way is to remove the old power band, and check what colour it is.
Make sure you check which way it is fitted before you remove it, so you can put it back in the same way
FretGrinder
PostPosted: 19:03 - 23 Feb 2014    Post subject: Reply with quote
This ^
Plus, you might want to ask when it was last changed. If it's a green or red one, you're onto a winner, they usually add 10% performance.
Also, add a pod filter and it should add another 5% performance Thumbs Up
bren_9311
It's pretty common knowledge. Hope you have a red one! Post videos..
Ps4- bren_9311
SpuceLee
PostPosted: 19:05 - 23 Feb 2014    Post subject: Reply with quote
Thanks for the attempted lampoon but, my naivity on the subject of bikes is counteracted by my well honed common sense.
PostPosted: 19:20 - 23 Feb 2014    Post subject: Reply with quote
Bravo that man!
PostPosted: 10:01 - 24 Feb 2014    Post subject: Reply with quote
If you take along a Mate Who Knows About Bikes, make sure that he actually knows about bikes.
Don't aggressively grill the seller: you're buying the bike, and a real wrong 'un will have glib answers to hand anyway.
Being too suspicious can result in the seller suggesting that you cordially sod off and have a think about it, then selling a perfectly decent bike to the polite chap who turns up an hour later. Whistle
mentalboy
PostPosted: 22:38 - 24 Feb 2014    Post subject: Reply with quote
Don't act like a kid in a sweet shop when you look at it. The more you let a seller know you've got to have it the less likely they are to cut you a better deal.
Make mine a Corona.
stallionX
PostPosted: 10:08 - 26 Feb 2014    Post subject: Reply with quote
This is what I did:
- Do an HPI check, you wouldnt believe how many owners have a 2nd hand bike and dont know it is cat c/d. I did and found out the bike is cat c. you can do HPI for £9, check fleabay.
- Ask for V5 reference number, do an MOT check online, check spacing of MOT (yearly), if there are multiple MOTs within a year, it is a sign of crash/insurance write off
- Check mileage records in MOTs and compare
- Ask for a copy of V5 and check details are genuine
- Contact prev owner if possible and ask about the bike
- Offer the seller that you take the bike to a shop for part exchange purposes. Shop will do a basic check and they should find out any big issues for free for you Smile You will also know the value of PX when it comes for a new bike
The last post was made 12 years, 220 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.94 - MySQL Queries: 13 - Page Size: 129.05 Kb
