would this work
gmc38609
PostPosted: 07:35 - 24 Feb 2014    Post subject: would this work Reply with quote
I have a old trickle charger abd I was thinking of attaching a cigerette socket to my battery and cutting the clamps off the charger and attaching a lighter
Plug them in an I am charging my battery Very Happy
Can you charge a battery this way?
bodger
PostPosted: 07:59 - 24 Feb 2014    Post subject: Reply with quote
No reason why it wouldn,t work as long as you wired it right and kept the socket on you bike out of the elements.
You know of course you can buy a proper plug and socket for this application on EBay for a couple of quid?
Matt B
PostPosted: 09:13 - 24 Feb 2014    Post subject: Reply with quote
It will work. I've done it on my bike.
The Pan has the proper plug connection for the Oximiser and the FZ6 charges via a lead that connects between the charger and the lighter socket, which is wired direct to the battery.
smegballs
PostPosted: 11:09 - 24 Feb 2014    Post subject: Reply with quote
Might want to put an in-line fuse on the lead which attaches to the + battery terminal (as close to the + terminal as practicable). Good practice for anything which comes off the battery IMO. Fuse should pop and stop things getting melty, should there be a loose connection, abraded insulation etc etc which results in a battery short.
gmc38609
PostPosted: 20:00 - 24 Feb 2014    Post subject: Reply with quote
I have bought a socket with fuse and the lighter attachment that you solder the wires to, all for about £8.
I was just curious as to whether it wou ld charge a battery without clamps but it seems so Very Happy
gmc38609
PostPosted: 21:33 - 26 Feb 2014    Post subject: Reply with quote
Hope this does not sound silly lo but would I need to put an earth wire on the plug part that is attached to the charger?
PostPosted: 21:43 - 26 Feb 2014    Post subject: Reply with quote
I would do something similar but using a small socket tucked away somewhere neat and tidy where water can't get into it. So it's more like plugging in a phone charger.
blue2 This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
gmc38609
PostPosted: 08:49 - 27 Feb 2014    Post subject: Reply with quote
Wow that was clever and yes I am not mechanically minded at all when it comes to car but i am looking forward to tinkering with the bike. i also have a Scottoiler to fit Very Happy
delsol
PostPosted: 19:34 - 27 Feb 2014    Post subject: Reply with quote
blue2 wrote:
I like the use of Aux sound\vid cables, nice tip that I can make use of Thumbs Up Karma
gmc38609
PostPosted: 11:04 - 28 Feb 2014    Post subject: Reply with quote
I have wired the socket to my battery and its showing 12v. I have attached the plug to the tricke charger and the stand by button comes on when I plug in the mains but does not start charging when I plug it into the cigerette socket. Any ideas I tried sending an email to the manufacturer of the charger but it says not a valid addressdoh!
gmc38609
Matt B
PostPosted: 11:20 - 28 Feb 2014    Post subject: Reply with quote
Are you sure the lighter plug is making a proper connection in the auxiliary socket, or maybe the charger is FUBAR?
gmc38609
PostPosted: 11:53 - 28 Feb 2014    Post subject: Reply with quote
How can you tell if its making a proper connection? FUBAR lol I no what that means and I never thought of trying it before I cut the clamps off
Matt B
PostPosted: 12:50 - 28 Feb 2014    Post subject: Reply with quote
FUBAR means broken.
When I plug the Oximiser charger in, it lights up to show the battery condition.
If you have a multimeter you can check if 12V is coming through the socket and along the wires to the charger.
Matt B
PostPosted: 12:58 - 28 Feb 2014    Post subject: Reply with quote
blue2 wrote:
usb charger should only give out 5v
True.
However, this is a 12V auxiliary socket and a trickle charger...
gmc38609
PostPosted: 13:03 - 01 Mar 2014    Post subject: Reply with quote
Ok I have checked everything and for some reason the power will not go through the male socket. I have tried 2 now and it aint happening. So I am going to use some spade ends to connect it all for now.Until I find out why Shocked
dolly3900
PostPosted: 13:41 - 03 Mar 2014    Post subject: Reply with quote
Some male aux power connectors have a diode in them to prevent being connected the wrocg way round.
Basically, a diode is a one way valve for electricity, so if you conenct it up right, all flows fine, but if you put it back to front, it stops the flow and does no damage.
Hope that helps
Mike
2002 Rieju RS2-50 (Sold, spares or repair), 2010 Suzuki DR-125SM (Traded for ->), 2007 Honda CBF 600 (Sold), 2010 Suzuki V-Strom 1000 (Briefly, now returned), 2007 Suzuki Intruder 1800m (Even More Briefly, traded in for ->), 2014 Suzuki V-Strom 650
gmc38609
PostPosted: 19:55 - 03 Mar 2014    Post subject: Reply with quote
Of course that makes perfect sense thanks Very Happy
The last post was made 12 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 112.3 Kb
