Carbs 1200 bandit mk2
gavbriggs
PostPosted: 11:44 - 24 Feb 2014    Post subject: Carbs 1200 bandit mk2 Reply with quote
I need a set of carbs for the above or just carb 4(or any other that's interchangeable.
Pilot screw won't come out. So if I drill it and fuck the carb I need a new carb.
Do the mk1 carbs fit the mk2 engine?
Any help please fellas
stirlinggaz
PostPosted: 14:29 - 24 Feb 2014    Post subject: Reply with quote
hi,
i dont see why you would need a full bank of carbs, just because they have ONE seized pilot screw.
they are usually made of a soft brass type metal (probably brass Very Happy ) & drill out very easily.
you would need to be quite inept to f*ck the whole carb.
i go on about using cobalt drill bits all the time but even "normal" HSS drill bits should be enough.
if it were me, (i have a full set of cobalt drill bits & a drill) i'd start off drilling slowly, with the smallest drill you have (2 or 3mm is usually wee enough) & work up the drill sizes until the screw collapses on itself.
stay away from them "easy outs" snap one of them & your f*cked.
remove the remaining swarf & debris with airline or carb cleaner & then replace the pilot screw.
they usually cost around a tenner delivered. (with o-ring or spring depending on type of screw)
cheers,
GAZ
gavbriggs
PostPosted: 14:33 - 24 Feb 2014    Post subject: Reply with quote
Yea that's gonna be my only option. I just wanted a backup plan as in new carbs just incase!! Probably won't need em but it'd be easier just to change the whole bank!!
Bikercem
PostPosted: 23:52 - 24 Feb 2014    Post subject: Reply with quote
Try some WD40 and pushing down on the jet with all your force, its probably just dirted in there, unless it has been threaded or get someone with a bit more force to do it, or use a flathead drillbit if thats not what your doing anyway or have tried
gavbriggs
PostPosted: 16:36 - 25 Feb 2014    Post subject: Reply with quote
Yea that's the one! But tbh if you can look at a bike that's been stood a while and tell me that the carb pilot screw is seized then it'd be a skill all on is own.
It's one of those things really.
Anyway a fairy god mother has come to the rescue and bought a s of carbs, seemingly the only spare set in the northern hemisphere!!
So I should be back rolling by the weekend for the Newark jumble!!
PostPosted: 20:33 - 25 Feb 2014    Post subject: Reply with quote
Hwta were the symptoms Gav? One stuck pilot adjuster shouldn't make a set of carbs useless. Lumpy tickover perhaps, but then only if it's screwed in tight or blocked. I once bought a Fazer that had the pilot screws all wound in so hard that the needles had snapped off, but the PO was still riding it 100 miles a day.
gavbriggs
PostPosted: 07:18 - 26 Feb 2014    Post subject: Reply with quote
Yea it was very lumpy up to about 4k rpm. So all the commuting and any travelling and any cruise speeds was a nightmare!!
In the end I just thought its not right and I want it right. It was putting me off the bike.
I balanced the carbs and it was useable but I don't think it's safe to ride a big bike without full control unless its a short journey home for example.
It felt like it was missing a lot etc and popping and farting. I assume the pilot screw was welded in by crap and that was blocking it causing the issue.
bodger
PostPosted: 08:29 - 26 Feb 2014    Post subject: Reply with quote
Pilot screws have no influence on air fuel mixtures at anything much above tickover.
If you are having problems with lumpy running at 4k you need to to be investigating further.
Could be another carbs issue or problems with the ignition such as by leads.
gavbriggs
PostPosted: 06:50 - 27 Feb 2014    Post subject: Reply with quote
The pilot circuit controls up to around 1/4 throttle according to research. The fact that a pilot screw is jammed in and the bike runs shite uptoaroind 4k would suggest pilot circuit issues. Once I have eliminated them if its still there I will know to continue to look.
Without that fixed its silly to continue to look elsewhere. The carbs come today so I will update you as soon as I can
PostPosted: 18:07 - 27 Feb 2014    Post subject: Reply with quote
You can test the pilot circuit with some carb cleaner and a straw, or with an airline blower. If you can blow through the circuit it's working.
gavbriggs
PostPosted: 21:33 - 02 Mar 2014    Post subject: Reply with quote
The carbs came, I put em n and the o rings were shot on the fuel intake rail.
Made a good set out of the two sets with one 'new' carb replacing the broken one on my set. All jets and float/float needle from mine swapped over and put it all together.
Exciting stuff, no fuel leaks, starts lovely. Idles ok. Out on the road, gun it and it bogs then picks up. At least it's running me thinks and packs it all away for another day.
It was on my mind all that night. Couldn't sleep couldn't work out whether it was too much or not enough fuel. All pilots were set to 3 1/4 turns as per manual (3) and a quarter turn to compensate for the aftermarket end can.
Next day, more investigating. Nothing undone on the carbs, TPS connected checked fuel trap by running on prime, no change. Seat off and stuck fingers in airbox intake. Nothing jammed in there BUT I remember putting fingers n there before and the engine slowly died as I blocked the air way. Ahhhhhhhhh me thinks. It's sucking air in, hence not enough fuel!
I'd only gone and mislocated the lugs on the filter cover giving about 1/2 inch gap along the bottom.
Closed it up correctly and it's all working spot on!!
So I've learned a good test for air leaks if nothing else!
The last post was made 12 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 73.36 Kb
