ZZR600E clocks gremlin
_mjs_
PostPosted: 20:50 - 27 Feb 2014    Post subject: ZZR600E clocks gremlin Reply with quote
Hi all,
The clocks on my bike have developed an intermittent fault: some of the bulbs keep going out then coming back on a few miles down the road.
https://i1323.photobucket.com/albums/u587/mjs1066/20140226_051751_zpsdad30477.jpg
As you can see on this photo, the lights for the fuel gauge and half of the speedometer are not lit (there's also a light out behind the rev clock but that's just a busted bulb and has always been like that).
I've checked the fuses under the seat and they're all good and the other lights and accessories are working fine.
The clocks haven't been disturbed since I fitted a new speedo cable a few months back and the bike had a new Motobatt fitted at the same time.
Is there anything else worth checking before I go digging around under the dash?
Cheers,
-Mark
Inspector_Clouseau
PostPosted: 23:31 - 27 Feb 2014    Post subject: Reply with quote
You can buy a set of used clocks from ebay for about £20, so that's the first thing I would do, If you've checked the obvious things.
If the new clocks work, job done! If not, you've still got a problem, but you've only spend 20 quid.
I'd say, more than likely, the clocks are goosed.
Shaft
PostPosted: 23:54 - 27 Feb 2014    Post subject: Reply with quote
You can buy some new bulbs for a couple of quid, or you can check the connections at the clock end for nothing.
Changing the entire instrument pack because a couple of bulbs have gone dicky, is a little drastic Rolling Eyes
J.M.
PostPosted: 08:02 - 28 Feb 2014    Post subject: Reply with quote
The lighting and clocks are often separate in clocks. I.E. the bulbs push in to the back of the clocks.
I'd be checking the wiring/connections and replacing bulbs.
2004 R1 & 2018 XSR900
PostPosted: 08:17 - 28 Feb 2014    Post subject: Reply with quote
Also, I'd add changing the bulbs is a 2 hour + job Laughing
DrSnoosnoo
PostPosted: 10:33 - 28 Feb 2014    Post subject: Reply with quote
I'd doubt there's anything wrong with your fusesesesses.
Buy a new set of clocks and plug them in, there'll be some shit on the connectors behind the clocks IMO.
take the opportunity to spruce things up a bit?
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-ash3/217087_10152780237180258_320841741_n.jpg
https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-prn1/603738_10152780342620258_1327931927_n.jpg
Shaft
PostPosted: 11:29 - 28 Feb 2014    Post subject: Reply with quote
Think I did it in about half an hour on my mate's ZZR.
Remove screen
Remove instrument surround
Remove instruments
Pull out bulb holders and replace bulbs
Replacement is a reversal of the removal procedure.
Bulb type is 501, I think there's 6 in total, 2 each for the speedo and rev counter, 1 for the temp and fuel gauge.
doggone
PostPosted: 11:35 - 28 Feb 2014    Post subject: Reply with quote
It won't be the bulbs since they come back on intermittently, could be bulb holders corroded with salty crap though, in which case replacement clocks might be best again provided they aren't as bad as the originals.
PostPosted: 13:11 - 28 Feb 2014    Post subject: Reply with quote
Should add, I'm rather hamfisted and bolts do not come out easily... Laughing
Shaft
PostPosted: 14:11 - 28 Feb 2014    Post subject: Reply with quote
Can be bulbs, the connector wires corrode and fracture on capless types, then you get disco lights.
If the holders are oxidised, give them a tickle with some wet & dry.
_mjs_
PostPosted: 19:39 - 28 Feb 2014    Post subject: Reply with quote
Thanks for the replies lads.
I'm working 12 hour night shifts at the minute so it'll have to wait until monday before I can take a look at it, but in the meantime I'm going to order some new bulbs.
Can someone confirm these are the correct type:
https://www.ebay.co.uk/itm/10PACK-x-501-SIDE-LIGHT-NUMBER-PLATE-PUSH-CAR-BULB-CAPLESS-TAIL-LIGHT-12V-5w-/271406405792
Cheers,
-Mark
Shaft
PostPosted: 19:44 - 28 Feb 2014    Post subject: Reply with quote
That's them.
mysterious_rider
PostPosted: 18:40 - 01 Mar 2014    Post subject: Reply with quote
I have clocks in the shed you can have for postage. zzr600. Laughing
KAWASAKIIIII
_mjs_
PostPosted: 18:59 - 01 Mar 2014    Post subject: Reply with quote
I might take you up on that kind offer. What mileage is on them and what year bike are they from? I think 1996 onwards have an LCD clock rather than two trip meters so I don't know if the clocks are interchangable Thinking
lukamon
PostPosted: 19:11 - 01 Mar 2014    Post subject: Reply with quote
5w? id not that is almost certainly NOT right!
thatd be 30 watts shining out of you instrument cluster, staring into a brake light (21w) anyone?
the one from both a mates sv650 and my cbf were 1.7w Thumbs Up
killa wrote: Im an ass man myself
mysterious_rider
PostPosted: 18:14 - 02 Mar 2014    Post subject: Reply with quote
hmm. well mines a 95. It's up to you fella. about 27-30k miles i think.
KAWASAKIIIII
Inspector_Clouseau
PostPosted: 00:22 - 03 Mar 2014    Post subject: Reply with quote
I said, IF you've checked the obvious things.... Drama queen! For fuck's sake!
Shaft
PostPosted: 00:42 - 03 Mar 2014    Post subject: Reply with quote
It wasn't me that suggested the clocks, which are clearly working, were "more than likely goosed", so I'm not sure I'm the drama queen.
Having said that, I've never been called that before and it amuses me, so I'll let you have that one Laughing
_mjs_
PostPosted: 14:47 - 03 Mar 2014    Post subject: Reply with quote
Mysterious Rider, I'm still waiting on the bulbs before I have a look at it (don't you just love ebay sellers who wait a few days before sending stuff out first class? Rolling Eyes )
If stuff is still not doing what it should I'll buy those clocks of you.
Thanks again for the generous offer Karma
Inspector_Clouseau
PostPosted: 05:48 - 06 Mar 2014    Post subject: Reply with quote
Sorry, clocks with an intermittent fault are 'clearly working'? I must have missed that one...!
I bow to you.
Almost makes me feel like a fool for rebuilding those dozen or so bikes...
J.M.
PostPosted: 08:28 - 06 Mar 2014    Post subject: Reply with quote
I bow to you.
Intermittent lighting issue. The clocks are working fine. The clocks and the lighting for the clocks are a separate entity. The clocks have holes in the back, that the bulbs push in to. The bulbs are connected to a connector block at the front of the bike, and are completely detachable.
It makes little sense to replace the entire clock unit when it is likely to be a simple wiring fault in a small section of the wiring loom (or a bulb), leading to the clocks. It's entirely possible that the wiring issue could be in a position before the connector block for the clocks, meaning that replacing that entire section would do absolutely nothing. Additionally, why replace the entire clock unit when you can just replace that small section of the wiring loom?
_mjs_
PostPosted: 15:53 - 06 Mar 2014    Post subject: ZZR600E clocks gremlin - FIXED Reply with quote
Boom.
https://i1323.photobucket.com/albums/u587/mjs1066/20140306_150240_zps6f34a8e1.jpg
My bulbs finally turned up after a week, (frankly I expected more for my £1.49 Laughing ), so I got busy.
I cleaned a bit of crud off the connections and stuck some new bulbs in for good measure, turned the key and job's a good 'un.
The original bulbs were 1.7w but the 2.1w replacements are working just fine.
Thanks again chaps Thumbs Up
johnsmith222
PostPosted: 17:11 - 06 Mar 2014    Post subject: Re: ZZR600E clocks gremlin - FIXED Reply with quote
_mjs_ wrote:
Boom.
I could never find those 1.7watt bulbs anywhere as I was trying to avoid going to a kawasaki dealer. I went to the dealer, and again no 1.7w bulbs.
I was worried about the 5watt ones melting the clocks, but they're fine and cause no damage.
I bow to you.
Regardless of what bikes you may have worked on in the past doesn't change the fact that you are wrong.
Shaft
PostPosted: 18:36 - 06 Mar 2014    Post subject: Reply with quote
Wow, is that your "more than likely goosed" clocks working perfectly again, via the simple expedient of cleaning some contacts and changing some bulbs?
Well, who'd a thunk it Wink
Good job Thumbs Up
Inspector_Clouseau
PostPosted: 20:34 - 06 Mar 2014    Post subject: Reply with quote
Mega lolz...
Did I not, in my initial post, say replace if you've checked the obvious things?
I think I did.
Following the model of basic troubleshooting, I believe that would include things like checking the bulbs, contacts, electrical connections, and such like.
Assuming that had been done, and the problem remained, replacing with cheap second hand parts seemed like a fair suggestion.
Everyone's entitled to an opinion.
The last post was made 12 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 136.22 Kb
