Indicators not doing much but indicating something is wrong
Pigeon
PostPosted: 20:07 - 01 Mar 2014    Post subject: Indicators not doing much but indicating something is wrong Reply with quote
Evening all. My trusty pizza delivery bike has come over all Chinese.
Sometimes the indicators don't flash and instead emit a constant light (until turned off) and the flasher unit remains silent, rather than the deafening clicks.
It started around the new year after I replaced all the bulbs (bike is 2.5 years and done 3 winters). I replaced like for like except the sidelight, I only had a 5w wedge rather than 3w.
Then it rained for the next 2 weeks solid. I was riding through 6" of water, then the bike was sitting in the open all day getting pissed on.
Then I got first occurrence of stuck indicators.
I thought it was water. Bought a can of WD40 and sprayed the flasher relay + connectors. This seemed to fix the problem, confirming in my mind it was water related.
I rode home in the wet, in the morning I had stuck indicators again (but only after 5mins).
Cleaned the relay with WD40 and wrapped it in plastic bag. Sorted. Worked for 2 days, then stuck indicators again.
- Bike is 2.5 years old (3 winters) as is the tiny 5ah Chinese battery.
- It's used daily, but only 3.5 miles each way, not much of a run.
- Replaced all bulbs with correct wattages, except sidelight which is 5w wedge not 3w.
I now have 3w wedge bulb and will fit tomorrow to replace the 5w.
I have a multimeter and would like to test battery. Battery is compatible with YUASA – YB5L-B on the YBR125. What should I see to know if the battery is ok or not in terms of output on the multimeter?
Depending on the reading I thought I'd take it out the bike and stick it on the Optimate tonight and leave it for 24 hours.
Thanks for any advice. I'm even worse with electrics than mechanics....if that were even possible Smile
Islander
PostPosted: 20:15 - 01 Mar 2014    Post subject: Reply with quote
You should see somewhere around 12.5v with nothing switched on.
It's likely to be down to corrosion on connectors - have a look at the relay and its connectors and any other connectors you suspect and clean them up if necessary. A thin coating of vaseline will help prevent further corrosion and prevent water ingress. Thumbs Up
Pigeon
PostPosted: 21:43 - 01 Mar 2014    Post subject: Reply with quote
Thanks for the reply.
12.54 Which given it's origin, age and type of usage is a surprise.
The 3 pin connectors on the relay are very clean + shiny, no hint of crud or corrosion.
Thanks for the Vaseline tip Thumbs Up , will apply a little in case water has been getting in.
Is it worth correcting the 5w sidelight by putting in a 3w? I didn't think 2w would make any difference to the working of the system, but maybe it would?
My indicators are 245 / R10w, am thinking of just getting a replacement flasher relay as they seem fairly cheap.
It looks very similar to this
or this
But I'm unsure of the different wattages in the descriptions.
this one matches the 10w indicators, but is a different design.
Islander
PostPosted: 00:48 - 02 Mar 2014    Post subject: Reply with quote
I wouldn't worry about the 5W lamp - it only pulls an extra 0.15A.
The first two links to flasher relays are electro mechanical units for 21W lamp types and won't work properly with 10W lamps. The third one would be fine but you'll have to adapt the mount.
Here's another with clear wiring instructions too:
https://www.amazon.co.uk/Universal-Flasher-Relay-Motorcycle-Signal/dp/B00I3XKYLQ/ref=sr_1_43?s=automotive&ie=UTF8&qid=1393720982&sr=1-43
Pigeon
PostPosted: 01:51 - 02 Mar 2014    Post subject: Reply with quote
Thanks Islander, wow at £3 it would be rude not to Smile
I'll leave the 5w sidelight in, as it's more useful / noticeably brighter than the 3w.
In terms of relays needing to be able to handle low wattages, I noticed there were a lot of units for LED's such as this one
Out of curiosity, would this have been suitable for my 10w due to its wide operating range? Or are they different beasts.
Islander
PostPosted: 03:01 - 02 Mar 2014    Post subject: Reply with quote
Yep that would have worked too.
The key is that it's electronic as opposed to electromechanical.
Electromechanical relays rely on a specific load to heat up coil, this in turn causes a bimetallic strip to bend and that breaks the contact. As the load is off, the strip cools and returns to its original shape which makes the contact again. This causes it to heat up and bend... and so on. Too small a load and you don't heat the strip enough so it either flashes very slowly or not at all.
An electronic relay uses a timing circuit that doesn't care about the load so as long as you remain within the actual contact ratings (and that's just to stop them from burning out over time), you'll have no problems at all. Thumbs Up
Pigeon
PostPosted: 21:40 - 02 Mar 2014    Post subject: Reply with quote
Thanks for the explanation Islander. Electromechanical sounds archaic, but at the same time a clever solution.
Got the part ordered, fingers crossed it resolves the issue, otherwise I'm into checking each + every connection.
Took the 5ah battery out and stuck it on Optimate for +15 hours for giggles.
Multimeter recorded 13.46
Cleaned up the terminals, topped up with distilled water and back in the bike. After an hour it was 13.22
The last post was made 12 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 56.05 Kb
