motorcycle suddently stopped now wont start
PostPosted: 09:37 - 02 Mar 2014    Post subject: motorcycle suddently stopped now wont start Reply with quote
its a honda cbr 125 FI
so when i rode it today it suddently stalled (the wheels did not lock) and now when i use the starter it makes this click noise from the battery and the fuel injection system restarts..
PostPosted: 09:52 - 02 Mar 2014    Post subject: Reply with quote
Either the battery if flat or you have a loose battery connection. Check the battery leads and if they look ok put a meter on it to see what voltage you are getting.
panrider_uk
PostPosted: 10:51 - 02 Mar 2014    Post subject: Reply with quote
Can you not bump start these?
CaNsA
PostPosted: 11:12 - 02 Mar 2014    Post subject: Reply with quote
you didnt happen to buy it from a dealership located in glasgow did you?
inb4 rust.
nowhere.elysium
The Pork Lord
PostPosted: 11:29 - 02 Mar 2014    Post subject: Reply with quote
Only if the pump's got enough charge to prime.
On a side note, has anyone seen the size of the fuel pumps on these? It's massive - it's about the size of my fist: total overkill for a 125 single, IMO.
770
PostPosted: 14:56 - 02 Mar 2014    Post subject: Reply with quote
i have tried charging the battery with no results, i have also tried changing the battery with no results too. when i hold in the starter for 5 seconds the battery starts to click very fast like, BRRRRRRRP.
when the bike stopped i was accelerating at around 50-60 km/h
PostPosted: 15:05 - 02 Mar 2014    Post subject: Reply with quote
That does sound like not enough battery power. What is the voltage over the battery?
evilbond
PostPosted: 15:06 - 02 Mar 2014    Post subject: Reply with quote
This.
Had this before with a 10 year old battery, wasnt keeping a charge and wasnt enough power to start it. Same clicking noise as you say.
New battery and vroooooom.
So test your battery with a multimeter.
Bike: K2 Bandit 600S
Car: Astra GTC
mentalboy
PostPosted: 15:24 - 02 Mar 2014    Post subject: Reply with quote
A battery can show a good voltage on a multimeter but be totally useless when it gets a load on it.
You may get a good idea by testing it in situ with switch in on, off and start modes, then back to off, but all batteries will show a drop when the starter hits them so unless it goes through the floor on start sequence you'll still be non the wiser.
Best bet is to find a diagnostic type charger or find someone who can do a 'load test'
Edit: of course if low voltage is shown from the outset then there'll be no doubts (esp after a charge sequence!)
Make mine a Corona.
WD Forte
PostPosted: 15:25 - 02 Mar 2014    Post subject: Reply with quote
Juts to be a wee bit pedantic
Its the solenoid you hear 'chattering' not the battery
Pete mentioned checking the battery leads
I'd also add you check where the heavy duty leads connect as well
One will go to the solenoid
One to frame.
Poor contacts here can give the symptoms you describe.
Dont forget all the electrical systems rely on a good earth return
Some people overlook this and get puzzled over wiring problems
bikers smell of wee
The last post was made 12 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 65.59 Kb
