Written off GSXR --> Daytime Rider (£900 all in!)
j.silvs
PostPosted: 20:22 - 01 Mar 2014    Post subject: Written off GSXR --> Daytime Rider (£900 all in!) Reply with quote
After my accident I thought that would be the end of riding. But I was wrong Very Happy . For the price I was able to retain it and for what I need to put into it for it to be a summer ride out and a possible track bike it was a no brainer....
The idea is to first getting it look like this, then maybe some paint or decals:
https://i1355.photobucket.com/albums/q704/joshsilverman/ed4ef38589f75a81c414f45b05d775ee_zpse4d1d295.jpg
So my gsxr went from this
https://i1355.photobucket.com/albums/q704/joshsilverman/17522b2f4285f456f02ec3fcf86479f8_zpsbbae207b.jpg
To this Crying or Very sad
https://i1355.photobucket.com/albums/q704/joshsilverman/78474de2d5682933810d7b0127ba54cf_zps70dbfeff.jpg
https://i1355.photobucket.com/albums/q704/joshsilverman/5b6791085bdfb6ed659f483d0dd86577_zps58c38111.jpg
https://i1355.photobucket.com/albums/q704/joshsilverman/5fadb133d131e7806e326b8bb501383a_zps850880c5.jpg
Had some time today so took my first go at stripping a bike. Trying to retain all fixings and also parts that I can sell in future if I no longer need them:
https://i1355.photobucket.com/albums/q704/joshsilverman/312c7a11ffa44427037e2af65234c68e_zps41d86219.jpg
https://i1355.photobucket.com/albums/q704/joshsilverman/f676faa63961cff416d1fae2166932a3_zpsfdf8594b.jpg
Surprisingly it was pretty easy. No nuts or bolts were a massive struggle to get off. I noticed that I have a leak for the rad coolant and as it's had a bash there I may just get a new one anyway.
Was able to refit the akra and also remove the SET valve completely.
2 hours later and this is how I left it, notice the pile of plastics at the back which are toast:
https://i1355.photobucket.com/albums/q704/joshsilverman/c88eff3788d0719850fb24c23d8b66fa_zps32f60a1c.jpg
So the next stage is to take off the rad, replace the crash bung, test brakes, test suspension and various safety bits, get some track fairings and other bits.
May be a week or two before the next update but will need this done by spring!!! Mr. Green
sidewinder
PostPosted: 12:09 - 02 Mar 2014    Post subject: Reply with quote
Look pretty good naked Very Happy
j.silvs
PostPosted: 13:37 - 02 Mar 2014    Post subject: Reply with quote
I thought that but not so sure about the street fighter look. However this gets me thinking...
https://www.bugbro.com/06StreetFighters-H-CBR954RR/honda_cbr_929_streetfighter_181.jpg
sidewinder
PostPosted: 15:38 - 02 Mar 2014    Post subject: Reply with quote
That looks nice not to overkill
fozzym
PostPosted: 16:21 - 02 Mar 2014    Post subject: Reply with quote
You may already now this and have done it but worth mentioning. Undo all nuts and bolts to release and pressure which is sure to have been caused by the crash.
Most important being all the front end ie: all the yoke bolts, top yoke bolt and the bearing nuts, clipons.
Swingarm mount, wheel spindles, shock mounts, engine mounts, subframe ect ect etc.
Basically if it can be undone, undo it.
clancy
PostPosted: 16:44 - 02 Mar 2014    Post subject: Reply with quote
Looks like it could be a nice little project really!
I would strongly advise stripping the whole bike down, and rebuilding it. For the same reasons as said above and you may find things that need replacing or tlc that you weren't aware of. Better safe than sorry. Can be done in a day so not much reason not too
KLX 300r
j.silvs
PostPosted: 11:11 - 03 Mar 2014    Post subject: Reply with quote
Thanks for all the suggestions.
I wont be able to do a re-build as I don't really have the knowledge for it unfortunately.
I was going to get someone down to have a good look over the bike but will cost me some time in labour.
Will defo look at relieving pressure etc.
j.silvs
PostPosted: 20:22 - 10 Mar 2014    Post subject: Reply with quote
little update. The following has now been ordered and will be fitted within the next couple of weeks:
New crash bobbins
new pazzo levers
full race fairings
bar end weights
indictor blank plates and led strip for brake
Pics to follow on the install
Tungtvann
PostPosted: 20:45 - 10 Mar 2014    Post subject: Reply with quote
Cool stuff. Glad you're still a biker! (Once a biker and all that). Look forward to those pics.
j.silvs
PostPosted: 11:22 - 11 Mar 2014    Post subject: Reply with quote
Cheers mate.
Will defo be updating once the pics come through.
PostPosted: 11:38 - 11 Mar 2014    Post subject: Reply with quote
j.silvs wrote:
led strip for brake
Is this going to be track only or are you going to tape that up on the road?
I wouldn't bother with any light if you want to sail through an MOT. Taping it up will pass an MOT mind.
PostPosted: 13:03 - 11 Mar 2014    Post subject: Reply with quote
Offroad use and single seater/unable to carry passengers due to lack of pegs etc.
You will need to tape it up for the MOT.
j.silvs
PostPosted: 15:49 - 11 Mar 2014    Post subject: Reply with quote
Just a few things:
Its daytime use only
I have to have a brake light for daytime use
I am not worried about MOT and failing
Suntan Sid
_Iain_ wrote:
You can only get away with running no indicators if the bike has a valid exemption and is registered as such, but as far as I'm aware it has to be registered as an enduro bike or a trials bike for that to apply.
I know this doesn't apply to this particular bike, however for anyone who doesn't know, you do not need indicators on a bike manufactured/registered before 1986, whether or not it is an Enduro or Trials bike!
j.silvs
PostPosted: 15:51 - 11 Mar 2014    Post subject: Reply with quote
To qualify for a daytime MOT your bike must “have neither front nor rear position lamps, or have such lamps permanently disconnected, painted over or masked.” This applies to headlamps, position lamps and indicators. The situation with stop lamps is significantly more complicated. Machines do not need to have a stop lamp fitted if they cannot exceed 25mph, were first used before 1st January 1936 or were first used before 1st April 1986 and do not exceed 50cc. Those first used before 1st April 1986 must have a stop lamp that operates from at least one brake control and those used on or after that date must have a stop lamp operated from both brakes. There is an added if not widespread complication for bikes first used from 1st April 1986 which were approved with a stop lamp activated by one control. There were very few of these and test inspectors are instructed to fail a bike only if they are certain the stop lamp was designed to be operated by both brake controls and isn’t.
PostPosted: 16:20 - 11 Mar 2014    Post subject: Reply with quote
j.silvs wrote:
Just a few things:
NO YOU DO NOT. Laughing
NO LIGHTS. END OF.
If you have a brake light, you WILL fail.
I have zero lights on my daytime bikes and pass, I have a brake light, it fails.
That text you have just details what does not require a stop lamp. You have taken it the wrong way Thumbs Up
PostPosted: 16:56 - 11 Mar 2014    Post subject: Reply with quote
You don't "require" E marks, but I'm sure some 5-0 would get picky if they were really really trying to do you for it.
Note my "Iron Cross" rear light wasn't marked, nor is the KTM Thumbs Up
PostPosted: 17:07 - 11 Mar 2014    Post subject: Reply with quote
You don't have to have a brake light but there's nothing that says you'd fail for having one.
PostPosted: 17:10 - 11 Mar 2014    Post subject: Reply with quote
You have all or nothing. I've done far to many with such a flexible tester I think I'd know by now Laughing
Tape and an LED strip is what I'd have if I could be bothered. But I can't as I'd rather have no lights.
I CBA with arguing, but you must have zero lights.
You need...
Sspeedo, it does not have to work.
Horn, it needs to work.
Full size number plate, it does not need a reflector.
That is the bare minimum for an MOT.
If you decide to fit a brake light or indicators, remove them for the MOT.
PostPosted: 17:17 - 11 Mar 2014    Post subject: Reply with quote
Daytime MOT's vary a lot between testers. There's nothing which says having a brake light means you'd fail the MOT.
I've had two daytime only MOT's which were from different MOT places and both bikes had brake lights. Wink
PostPosted: 17:18 - 11 Mar 2014    Post subject: Reply with quote
You need...
We know what's needed but there's nothing that says having a brake light is a MOT failure.
PostPosted: 17:29 - 11 Mar 2014    Post subject: Reply with quote
If a light is fitted, all lights must be fitted.
It is a stop light, therefore a light.
PostPosted: 17:49 - 11 Mar 2014    Post subject: Reply with quote
https://www.motinfo.gov.uk/htdocs/m1s01000301.htm
Which part of the MOT test manual says anything about having a stop light being a reason for failing the MOT?
"If a stop lamp is fitted, it must meet the requirements of this inspection"
The last post was made 12 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 132.85 Kb
