New AGM battery - do I charge it?
ice.shark
PostPosted: 18:34 - 02 Mar 2014    Post subject: New AGM battery - do I charge it? Reply with quote
Hi, I've bought a new AGM battery (YB9-B - 12V/9Ah). I've added the electrolyte (around 12:00 pm) and I've left it to sit with caps on for about 5h till 5pm. At around 5:30 I hooked it up to a battery charger.
Do I actually need to charge it? The instructions in the box didn't say to charge it? The battery was at 12.43V at 12:30 (from 12.32 at 12:00).
I guess I'll leave it hooked to the charger for couple of hours but is there any point charging it any longer than that? Again, manual didn't say to charge it at all.
A shop assistant at halfords said that I should add the electrolyte and wait for 5h+ and then it's ready to be put into the bike.
BTTD
PostPosted: 18:41 - 02 Mar 2014    Post subject: Reply with quote
My understanding is that yes, you should top it off.
Couple of hours sounds alright.
ice.shark
PostPosted: 18:50 - 02 Mar 2014    Post subject: Reply with quote
From the instruction manual that came in the box with the new battery:
2. Initial Operation
Filled Batteries
- Batteries filled with acid are ready for use
-Check the voltage of the battery with a suitable meter. if the voltage is less than 12.3V, the battery should be recharged in accordance with Point 4.
janner_10
PostPosted: 20:27 - 02 Mar 2014    Post subject: Reply with quote
Seriously.. The answer is in the instructions.
johnsmith222
PostPosted: 21:46 - 02 Mar 2014    Post subject: Reply with quote
I'd personally always stick a new battery on a charger. It might not need it but it's not hurting to give it a charge. (using a charger which doesn't let batteries get overcharged).
ice.shark
PostPosted: 22:16 - 02 Mar 2014    Post subject: Reply with quote
OK, so here are some results of what happened. When I last checked the battery after filling (with electrolyte), the terminal PD was 12.43V. That's about 30 minutes after filling. Just after filling the PD was 12.32V.
Anyway, I hooked it up to a charger for a few hours. Charging was at 14V/0.8A (optimate 4 dual mode). Just after unhooking from the charger, the battery was at 13.3V. After 2 h of letting it stay still (with caps undone) the battery was at 12.7 V.
I'm not a battery expert, but it seems that the battery is ready for use a couple of hours after filling up. I don't know if charging will help extend the life of the battery.
janner_10
PostPosted: 05:34 - 03 Mar 2014    Post subject: Reply with quote
I don't understand why you charged it in the first place. It was ready for use after filling.
The voltage you measured and the instructions advice confirmed that.
If it ain't broke etc etc
PostPosted: 08:53 - 03 Mar 2014    Post subject: Reply with quote
I have fitted new batteries without charging them, but I think knowing that hardly any batteries have a full charge from the factory, I'd probably stick it on my Optimate for a few hours before bunging it in the bike.
Islander
PostPosted: 11:08 - 03 Mar 2014    Post subject: Reply with quote
Stick it on a smart charger for a few hours. Thumbs Up
The last post was made 12 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 64.25 Kb
