Problems fitting carburetor gpz400
guirigales
PostPosted: 20:31 - 02 Mar 2014    Post subject: Problems fitting carburetor gpz400 Reply with quote
Hello
This is my first post here, and it's a cry for help Smile
I bought a gpz400 (84) as a project bike. The guy who sold me the bike told me I'd need to clean the carbs as it starts but stops after a few seconds.
I took the carbs out, cleaned them up and them tried to reinstall them. It was a nightmare. The bike starts and kind of stays alive but I know that the carbs are more than likely leaking. Trying to fit them properly in their boots was incredibly difficult and I doubt they're sitting snuggly.
Does anyone have any experience with this model Kawasaki? I'd love some tips for cleaning and installing the carbs. I know they'll need to come off once more, and I'm not sure if I can go through this again Smile
Thanks all.
bladerunner
PostPosted: 20:47 - 02 Mar 2014    Post subject: Reply with quote
The carb rubbers will be hard with age. A smear with light oil where the carbs fit in engine side can help get the carbs attached to the engine....as does making sure the jubilee clips are undone enough to give a little wriggle room!
The rubbers that fit the carbs to the air box may benefit from dropping into as warm as is hand safe hot water as this will make them more supple and a damn sight easier to get into place and they usually seal better after as well. Just remember as they cool the will harden up again so try to be quick!
dansp1
PostPosted: 21:01 - 02 Mar 2014    Post subject: Reply with quote
https://forums.sohc4.net/index.php?topic=29707.0
PostPosted: 21:06 - 02 Mar 2014    Post subject: Reply with quote
Boiling or baking the carb rubbers before installing can help a little.
When you cleaned the carbs, did you take out each individual jet, cleaning by blowing out by mouth/using a strand of plastic and so on.
Bit late now, but I'd always be suspicious when the seller tells me something is wrong, but they haven't fixed it themselves. If they knew that was the actual cause,
guirigales
PostPosted: 21:11 - 02 Mar 2014    Post subject: Reply with quote
Good idea with the oil, that hadn't occurred to me. I softened the air box rubbers up with a hair dryer Smile It actually worked well. I just left the hair dryer plugged into the air box and left it on. The rubbers were soft, but they either popped out one way, or popped out the other. As for getting them to fit onto actual carburetor it was a real struggle.
It would be sooo much easier if I could fit everything and then place the air box on but I don't see that as being an option.
guirigales
PostPosted: 21:17 - 02 Mar 2014    Post subject: Reply with quote
I'll try the boiling next time. I have to buy some starter spray and see if they're leaking anyway. (which I imagine they are).
The guy who was selling the bike had started it as a project himself along with another bike and was selling them both out of necessity. I only paid 300€ so I was pretty pleased with the buy.
I took out each individual jet and cleaned them with carb cleaner, air compressor etc. In theory they're clean. What I haven't done, for lack of cash is syncronise them. I'll have to do a bench sync when they come back off.
guirigales
PostPosted: 21:18 - 02 Mar 2014    Post subject: Reply with quote
Thanks for the link, Ill take a look now.
PostPosted: 21:46 - 02 Mar 2014    Post subject: Reply with quote
I wouldn't bother with carb cleaner.
Air compressors often don't work that well for cleaning jets.
Look down the jet to inspect holding it up to a light/bright background, either seal it with your lips and give a quick exhalation out, or poke something like one strand from a washing up brush down it to dislodge anything. Then reinspect and repeat as required.
guirigales
PostPosted: 22:39 - 02 Mar 2014    Post subject: Reply with quote
Ye, all the jets were very clean. I could see through them perfectly.
The last post was made 12 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 63.08 Kb
