Cagiva mito starting issue
Deano3517
PostPosted: 22:28 - 02 Mar 2014    Post subject: Cagiva mito starting issue Reply with quote
Ive built a mito from the frame up haven't yet run the bike but when I hit the starter button the starter motor spins as it should but if the switch gear Is in the kill position and I press the starter button it still spins up any ideas
stirlinggaz
PostPosted: 19:08 - 04 Mar 2014    Post subject: Reply with quote
hi,
sounds perfectly normal.
all of my mitos were the same, with the kill switch in the "run position", it works normally & would fire up, flick it to "off" & it would still turn over, just wouldnt frire up,
cheers,
GAZ
_mjs_
PostPosted: 19:56 - 04 Mar 2014    Post subject: Reply with quote
stirlinggaz wrote:
hi,
cheers,
GAZ
This. The Varadero 125 is the same; I found this out after spending fifteen minutes trying to bump mine off with the killswitch on Embarassed
Nipedley
PostPosted: 20:04 - 04 Mar 2014    Post subject: Reply with quote
Yeah, both of my bikes the kill switch prevents the CDI from firing any sparks rather than stopping the starter motor, so the engine still turns over.
Quite handy for stirring some new oil around before the engine fires up after an oil change etc.
The last post was made 12 years, 261 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 38.94 Kb
