Leaving the Bike for a Month or Two - Precautions?
Springbok_Rider
PostPosted: 09:05 - 03 Mar 2014    Post subject: Leaving the Bike for a Month or Two - Precautions? Reply with quote
Hi,
I'm leaving my bike (CBR 600 FS) in my parent's garage for a month or two while I return to Norway. I'll be back when the weather is decent to ride it over.
I'll be taking the fairings off since I'm sending the instrument cluster to America for new dials/lights, and also ordered a xenon kit. I'll fit these when I return so the bike will be naked.
For such a short period of time, what precautions are necessary to prevent any damage from sitting? I was going to get my Dad to start it but without the instrument cluster I'm not sure if she will start. I was thinking of:
1) Giving it a good clean and maybe leaving an outdoor cover of it to stop dust getting at it.
2) Unplugging the battery and leaving it inside.
3) Putting some rags in the exhaust and air intakes.
4) Buying some fuel stablizer/sea foam?
5) When I get back I'll fit a new chain and sprockets and give it an oil change so don't think I need to do that before?
I don't have a paddock stand, so not sure if the tyres will get damaged from being in near enough the same position for a month or two. Any precautions I can take here?
Is this ott for a couple of months away?
Thanks,
Antony.
2005 SV650 ---> 2002 CBR 600 FS ---> 2010 Monster 1100 ---> 2006 Yamaha YZ250F ---> 2008 Street Triple 675
Alienfish360
PostPosted: 09:08 - 03 Mar 2014    Post subject: Reply with quote
2 months is hardly anything from being stood.
Get it on paddock stands so it is off the tyres.
If it has no alarm, then just leave it, if it does have an alarm, leave it connected to a trickle charger.
Don't start it and let it warm up, as it will cause a build up of condensation as it won't have have enough time to burn it off.
Come home after 2 months, check tyre pressures, start it and ride.
Dust isn't going to kill your bike after 8 weeks.
Springbok_Rider
PostPosted: 09:18 - 03 Mar 2014    Post subject: Reply with quote
Thanks. I don't live here though so it's a waste of money to get paddock stands.
Alienfish360
PostPosted: 09:19 - 03 Mar 2014    Post subject: Reply with quote
get whoever is home to push it around every week then so it's not sat on the tyres all the time, otherwise when you get home you may find flat spots on the tyres.
Rigga
PostPosted: 09:44 - 03 Mar 2014    Post subject: Reply with quote
After 2 months?
Current bike: Honda CBR 1100xx
doggone
The battery could go down quite a bit if not on trickle charge.
Not a bad idea to put a cover of some sort on in case a bird shits on it.
I can't see much happening to the tyres in 2 months unless it went flat.
Alienfish360
PostPosted: 09:55 - 03 Mar 2014    Post subject: Reply with quote
Rigga wrote:
After 2 months?
Probably not in most cases, but it's better than starting it once a week if you was going to do anything
Chalky.
PostPosted: 10:22 - 03 Mar 2014    Post subject: Re: Leaving the Bike for a Month or Two - Precautions? Reply with quote
Hi,
Thanks,
Antony.
My bikes can go for months unused - the only thing that'll probably go is the battery. You may as well take it off if you're doing all that work on it. Don't worry about the rest of it.
RhynoCZ
PostPosted: 10:28 - 03 Mar 2014    Post subject: Reply with quote
Don't clean the bike, lube the chain, take out the battery and keep it charged up, turn the fuel tap OFF if you can. That's what I do before the winter break.
IF you want to clean it, then you have to ride it after the cleaning so it could properly dry out. You don't want any water on your bike if you put it in garage for that long. Thumbs Up
Islander
PostPosted: 11:02 - 03 Mar 2014    Post subject: Reply with quote
Just keep the battery charged. Nothing else is necessary for such a short time. I've had all my bikes laid up for 3 months this winter thanks to the non-stop high winds and all I do is rotate the Optimate around them to keep the batteries in good condition. Thumbs Up
Springbok_Rider
PostPosted: 11:52 - 03 Mar 2014    Post subject: Reply with quote
Awesome, thanks guys. I'll take the battery off anyway as mentioned since I'll be doing the work on it, and my Dad is using the trickle charger on his bike.
rhys1005
PostPosted: 16:22 - 03 Mar 2014    Post subject: Reply with quote
Left my bike in shed for a year.. Just cleaned it, filled tank to the brim and locked it up good.
DrDonnyBrago
PostPosted: 16:24 - 03 Mar 2014    Post subject: Reply with quote
Just stop it from getting nicked, 2 months is nothing.
Rigga
PostPosted: 16:29 - 03 Mar 2014    Post subject: Reply with quote
How come you filled the tank up?
doggone
PostPosted: 16:41 - 03 Mar 2014    Post subject: Reply with quote
Any air left inside will have a certain amount of moisture in, and it can condense on the inside and run to the bottom causing corrosion there or above the fuel level.
If you're using at least once a month or so it won't be a big problem.
delsol
PostPosted: 19:13 - 03 Mar 2014    Post subject: Reply with quote
Not sure what the climatic conditions are where your bike will be stored, only comment I have is about using an outdoor bike cover.
I would use a dedicated motorcycle dust cover, less chance of condensation forming.
janner_10
PostPosted: 19:57 - 03 Mar 2014    Post subject: Reply with quote
Vincent wrote:
2 months is no time at all and you don't need to do anything........apart from making sure it can't be stolen.
This - 2 months is fuck all - stop worrying.
Richy CB1000
PostPosted: 20:40 - 03 Mar 2014    Post subject: Reply with quote
I leave my 22 year old girl for three months at a time, just park it up, it's outside so a cover goes over. That's it, just takes 20 seconds longer to start on choke than normal after a three month lay up. No need to do anything.
el_oso
PostPosted: 21:17 - 03 Mar 2014    Post subject: Reply with quote
depending on how much road grit is on it now and how pristine you want it to stay would depend on whether I would clean it or not.
If it sees constant all weather use I would clean it thoroughly then ride it around for an hour. I would then put it in the shed (hopefully dry) and covered.
take off the battery or put it on trickle.
fill up the tank.
that's if I was being anal about a pristine looking bike. If there are already a few blemishes then I wouldn't bother except for taking the battery out.
Duke 390
Car: Jeep Wrangler 4.0L
Springbok_Rider
PostPosted: 21:51 - 03 Mar 2014    Post subject: Reply with quote
Vincent wrote:
You could always wrap it up in a blanket with a hot water bottle and employ a bike nanny Very Happy
Recon that might be the way to go. Poor bike's gonna be all be it's self if not. Maybe my old man can read it a story or two...
"and as he come around the last corner at 172mph... the finishing line was in sight..."
It's in pretty good nick but it isn't too dirty. Since it's probably gonna rain all week I'm better off waiting until I come over in Spring to give it a good wash.
clancy
PostPosted: 09:33 - 04 Mar 2014    Post subject: Reply with quote
You don't need to do anything to it
Left my rvf sat for 6 months without doing anything, sat on side stand and battery connected, left the fuel in it etc
Charged battery, started first time and ran fine
KLX 300r
The last post was made 12 years, 261 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 117.63 Kb
