CBR600 F1 (1987-1990) Dies when revving, wont idle
Nipedley
PostPosted: 17:46 - 03 Mar 2014    Post subject: CBR600 F1 (1987-1990) Dies when revving, wont idle Reply with quote
Hi guys,
The problem is: my CBR600 FJ won't idle unless on choke, and if I give it any throttle at all it will stall out and die.
It was working fine until I got a new exhaust, dropped the old exhaust off and while waiting for new exhaust collars also replaced the fuel lines as the ones I had on were the ebay shit that just degraded on my other bike and nearly started a fire, and in the process of which stupidly put the fuel filter on backwards.
I've dropped the exhaust headers off and re-done them with new gaskets just to make sure it wasn't the exhaust at fault and there's no leaks there, so I can presume the exhaust is fine ?
I have cleaned the carbs by dropping and cleaning out the float bowl, removing and cleaning the float valve, and removing and blowing through all of the jets. I did have an issue where Carb #4's drain screw barely dripped fuel when open where all the others dribbled fuel out, and cleaning fixed that problem so lots of fuel comes out now like all the others, however it still won't idle...
I can only imagine this is a carb thing though right, so needs to be re-cleaned or I didn't do a good enough job? Perhaps still some crap in the fuel lines that I need to flush out
Sorry for the long post. Suggestions very much gratefully received Smile
Copycat73
PostPosted: 17:50 - 03 Mar 2014    Post subject: Reply with quote
make sure the fuel lines are not kinked,nipped or twisted and correctly routed.
caveat emptor
Nipedley
PostPosted: 18:11 - 03 Mar 2014    Post subject: Reply with quote
Hey there,
Yeah the fuel lines are all good and the float bowls are full of fuel now that I've cleaned then, I can only assume either there was more shit still in the fuel lines that's got sucked through after I've cleaned them, or I didn't do a good enough job...
I think the plan is, new fuel filter, blast through the fuel lines with water/air and a good re-clean of the carbs
cb1rocket
PostPosted: 10:12 - 04 Mar 2014    Post subject: Reply with quote
Did you clean the jets?
Nipedley
PostPosted: 12:45 - 04 Mar 2014    Post subject: Reply with quote
I did yeah, 3 of the smaller jets were clogged and 1 of the main ones, and I presume one of the float valves was blocked which is why Carb #4 had very little fuel in it.
Since the problem is the same, I can only assume some more crap was in the fuel line and has done the same thing, I'll have a go at flushing everything through with a new fuel filter as well
Fizzer Thou
PostPosted: 10:13 - 05 Mar 2014    Post subject: Reply with quote
With the engine running,spray some WD40 around the inlet manifolds one at a time.If the engine revs up slightly then you have either loose or split rubbers letting in air,so weakening the mixture.
Always have a 'Plan B'
The last post was made 12 years, 260 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 47.33 Kb
