Nail in tyre-ride or not?
speedysi
PostPosted: 18:21 - 04 Mar 2014    Post subject: Nail in tyre-ride or not? Reply with quote
I know this may be a daft question, so I apologise in advance. I've picked up a large nail-one of those grey ones the builders use for plaster board so fairly wide-in my rear tyre.Do people get theirs plugged and just ride away for months,or would people be happier with a new tyre?
I was going to replace them in a few months for something that actually grips(they're maxxis diamonds which I was given) anyway. Mmmm. Money!!
Thanks
1999 CBR 600F😄
Theory Test passed 15/08/2011👍. Off Road passed 20/09/2011👍. On Road passed 5/10/11👍
delsol
PostPosted: 19:01 - 04 Mar 2014    Post subject: Reply with quote
Inquire at a couple of tyre shops, if they say it is repairable then I would have it mushroom plugged and use it with confidence.
PostPosted: 19:40 - 04 Mar 2014    Post subject: Reply with quote
Plugged tyres are fine to ride on until the tyre is worn out - but not all damage can be plugged. Since you cannot make an informed decision yourself you should take it to a tyre shop. If money is tight take the wheel off and get a lift to the tyre shop - it'll be cheaper if they don't have to remove and re-fit the wheel.
clancy
PostPosted: 19:54 - 04 Mar 2014    Post subject: Reply with quote
Plugged tyres are fine, mine at the minute is plugged, had one on my rvf plugged as well
They can normally plug it provided it's not too far to the edge of the tyre. As Pete said take it loose if possible and it will be cheaper
KLX 300r
Doovy
PostPosted: 22:26 - 04 Mar 2014    Post subject: Reply with quote
Stop n Go tyre plug kit. Get one.
https://www.amazon.co.uk/STOP-POCKET-TYRE-PLUGGER-KIT/dp/B003VE0ZL6
PostPosted: 01:42 - 05 Mar 2014    Post subject: Reply with quote
_Iain_ wrote:
I did worry given the title that you were going to ask if it was okay to ride with a nail in the tyre Laughing Thumbs Up
If you do this, what NOT to do is to do a burnout after giving a friend a lift to to pick up his car during lunch time.
Otherwise you may find you need a VERY prompt ride to get home before it goes flat, when it's no longer plugged by said nail!
Smile
STONEY!
PostPosted: 11:12 - 05 Mar 2014    Post subject: Reply with quote
My old boss used to do track days on plugged tyres at one point he had 5 plugs in one tyre, never had any problems.
I got a nail in my tyre on my old pick up, could hear the air escaping as I drove, pulled over sharpish found the hole where the nail had been and shoved a twig in it, made it to services pumped the tyre up a bit and drove home.
skatefreak
PostPosted: 11:32 - 05 Mar 2014    Post subject: Reply with quote
Had a nail in my NSR front tire for about 6 months...
Was even an advisory on the bikes MOT.
Got some new tires and it turned out to just be a small tack 'Sighs'.
Got some silly string plugging things though Very Happy
If its the back tire its not AS catastrophic as losing pressure in the front tire so yeah, I'd plug it.
-Jvr
The last post was made 12 years, 260 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 67.61 Kb
