honda cd200 disc brake conversion
salem1987
PostPosted: 20:35 - 04 Mar 2014    Post subject: honda cd200 disc brake conversion Reply with quote
Thinking of putting some different wheels on my cd200 for some improved braking.
Ive been looking at superdream wheels and forks which should fit, just struggling to work out what back wheel would fit?
Not too bothered about having a disc brake on the rear, but it needs to be in the same style as a superdream one. (or whatever front end fits)
Cheers
Will
davebike
PostPosted: 08:47 - 05 Mar 2014    Post subject: Reply with quote
I used CB125TD wheels when I did this mod years ago
The rear wheel is Interesting You need access to a Lath it needs to be a stepped spacer with two Flats cut in the smaller section that goes though the chain adjuster and the swing arm
I had to make spacers for both sides to centre the wheel
Front I swapped the whole front end Yokes forks wheel etc etc
Dave
Dave
NC750Xdct + others at work !
[email protected]
Teflon-Mike
tl;dr
PostPosted: 12:55 - 05 Mar 2014    Post subject: Reply with quote
Hmm.... "Improved Braking"
125 S-D Front end should go straight on, as said. S-D rear wheel though does have very wide hub. However.
Benley has Brakes. To my mind, large part of Benley 'Charm' is it's traditional styling, with wire wheels & metal mudguards, AND... while disc brakes were vaunted for offering 'better' braking.... lets face it, the thing is a 15bhp commuter.... and Drums were good enough for the GP Bikes of the 60's with as much power as a 600 Super-Sport!
Drum Brakes are hugely under rated to my mind, and while ultimately they dont have the same shear stopping force potential as you might get from a disc, they dont HAVE to be 'dire' for power, and they do have a fair few facets that can be an advantage over discs.
Biggest asset they have over a disc is 'cheapness', which has not done them any favours over the years; remaining on 'budget' models, they have not had the best drums to start with, re-inforcing the idea that discs are 'so' much better.... when you are comparing 'adequete' brakes for a sub 15bhp ecconomy commuter bike, to a disc for a 'sports' tiddler designed to have 25 or more!
Purely Mechanical; there's no hydraulic fluid, or seals, or pistons to get stuck, or have to replace. The Drum is simple, reliable, and cheap and easy to maintain and or overhaul.
And if you are contemplating the CB125 Super-Dream disc set up? Well, it's a fairly 'nice' one as discs go; but twin-piston floating caliper; like most Honda calipers, suffers the gripe of float-mounts siezing and pistons 'gumming'... also, used, youngest are going to be twenty five years old, and coming from something sorely neglected and BER. Fully reconditioning the front brake on Snowie's Pup was one of the most expensive 'bits' of her renovation; new caliper pistons, seals, float-pins, master cylinder piston, seals, and line, all up, I think was something like £130. The little DT or my Cota, for comparison? New Shoes, and err.... what else is there? Cable... yup, thats about it. £25!
Clean, grease, oil, and adjust; and keep it cleaned, greased, oiled and adjusted, a Drum can be very good brake. Ultimate power is not THAT bad compared to a disc; you can still lock the front wheel, and thats as much 'power' as you need; but, the brake shoes, 'hinging' from one end, and curved, as you apply them, the initial braking comes only the eld of the shoe touching the drum; as you squeeze, pushes more shoe into contact, and you get a far more 'progressive' take up and far more 'feel' (if well fettled') than you do with a disc, while the rotation of the drum, on a 'leading shoe' has a self-servo effect, the shoe 'rotating' into contact with the drum, initial take up tries to drag the shoe with the drum, pulling the brake on for you.
On a disc; the pad pressed perpendicularly into the rotor; initial contact is far less subtle, and under 'light' application, you can get a 'chatter' effect, where initial contact, rather than 'bite' the rotor tries to push the pad away from the rotor. On early chrome or stainless discs; this was often made worse, by the pad having to 'wipe' any grime or water on the surface before it would bite, leading to brakes that were critasised for being overly 'sharp' and lacking feel.
So; ponder points. How 'bad' is the brake you have? How much 'better' do you want or need it? How much is the 'classic' asthetic of the Benley worth preserving? How much are 'better' brakes worth in cost and hassle?
Remembering that a disc brake and com-star wheels are pretty obviouse modifications on a Benley, and insurance companies get very squiffy about modifications to the 'safety critical' braking system! Even if its 'better'... they have little idea what it feels like to ride through traffic on a motorbike, let alone one with lesser drum brakes and a bunjee cable; and will presume, you want better brakes because you are riding faster the whole while!
What can you do with the stock set-up? There's fuck all to it; and its pennies, reletively to completely over-haul with new shoes, springs, if necessary cam, and cable. Little care and attension to setting it up and adjusting it properly; potentially big boost to braking, for little cash, hastle or effort; without any slight to styling.
Beyond that? Well, when there weren't any disc-brakes; when the manufacturers built bigger, heavier bikes that needed more brakes than a 4" single-Leading-Shoe could do... they gave them, 6" SLS, and when that wasn't enough, 6" Twin-Leading Shoe, or more; the 9" TLS being the sort of brake used on racers right up till the '70's.
Keeping it sympathetic to the 'style' of bike it is; sticking with wire wheels and drum; what else might you do?
Thought that springs straight to my mind, would be to look at dirt bikes. What was on the Honda XL250 or 500? dirt bikes retained drums well into the mid eighties, and think about it; you want 'braking force' a reverse 'thrust' at the tyre. Made elswhere, it gets there as 'torque' on the wheel, force times radius.
If you have a hub intended for an XL250; it would have been intended to put a brake torque on a 21" rim. What's the Benley have? 17!s isn't it? So using smaller rim, you will give the drum, something like a 20% increase in leverage over the tyre, before any question of whether the drum is any more efficient.
It's a tangent to your thinking.... but; bit of teflon-thinking to ponder.
I have always found that so many people, plotting mods; jump in with a solution, before they have really considered the actual 'problem', and headed down an avenue, where they can chuck the baby out with the bath-water, or make more problems than they solve, as they go.
Explore the avenues; there MIGHT be something 'better' than a super-dream disc... and it could be as simple as doing full overhaul on what you got, rather than throwing it away!
Or perhaps I just like the look of them cutesy 'shrouded' forks on the Benley! Wink
delsol
PostPosted: 20:24 - 05 Mar 2014    Post subject: Reply with quote
An interesting and informative 'Tef-Style Synopsis' on the attributes of drum brakes.
Enjoyable reading, Karma Thumbs Up
The last post was made 12 years, 260 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 46.54 Kb
