Backfire?
mudcow007
PostPosted: 09:08 - 05 Mar 2014    Post subject: Backfire? Reply with quote
So....what causes a backfire?
tried to start my Bandit last night, it coughed but didn't do much else, so changed the plugs
here are the old ones
https://i25.photobucket.com/albums/c81/mudcow007/20140305_090047_zps3eadc738.jpg
they looked wet last night an stunk of fuel
im running the bike at the moment without the tank an a funnel shoved into the fuel feed pipe - im guessing that might have something to do with it?
Hetzer
PostPosted: 09:18 - 05 Mar 2014    Post subject: Reply with quote
Un-burned fuel going into the exhaust and detonating there.
mudcow007
PostPosted: 09:20 - 05 Mar 2014    Post subject: Reply with quote
so the bike is overfueling then....
hmm if a float was staying open wouldn't it just through it down the overflow pipes?
i hate carbs....
Hetzer
PostPosted: 09:23 - 05 Mar 2014    Post subject: Reply with quote
Or the plugs aren't getting enough juice to fire properly.
mudcow007
PostPosted: 09:56 - 05 Mar 2014    Post subject: Reply with quote
funnily enough when i plugged the battery into my optimate last night it did say it needed charging - i just hope the coils are ok
this cheap bike is starting to cost a bit.....
Hetzer
PostPosted: 10:08 - 05 Mar 2014    Post subject: Reply with quote
Once the engine is running the plugs should be powered directly by the alternator, so a poorly charged battery shouldn't be the issue. Coils are more likely.
You can test for a good spark by holding the threaded part of the plug against the block and hitting the starter-button so you can observe the spark directly. It should be a 'fat' white/blue affair. If the spark is good the fuelling would be my next guess.
RhynoCZ
PostPosted: 10:16 - 05 Mar 2014    Post subject: Reply with quote
What exhaust does it have?
mudcow007
PostPosted: 10:57 - 05 Mar 2014    Post subject: Reply with quote
a "snazzy" looking carbon Scorpion
it was on the bike when i got it, i also have the standard pipe too though
RhynoCZ
PostPosted: 13:27 - 05 Mar 2014    Post subject: Reply with quote
I'd try the original one first, before you take it all apart.
gavbriggs
PostPosted: 16:01 - 05 Mar 2014    Post subject: Reply with quote
I always use a jump lead to the engine and the spark plug to test. That way you get a good ground.
Assuming you haven't changed anything and its suddenly happened I would firstly look for any looses intake parts to and from the carb. I seated my air box lid wrong and got all manner of issues!!
davebike
PostPosted: 19:30 - 05 Mar 2014    Post subject: Reply with quote
If it was running OK before with the after market can on :-
I say either a sticking float / dirty carb or more lightly just a filthy air filter
You might get away with cleaning the plugs but I would fit new
Dave
Dave
NC750Xdct + others at work !
[email protected]
mudcow007
PostPosted: 09:07 - 06 Mar 2014    Post subject: Reply with quote
cheers all
i have given it to a local tinkerer so fingers crossed he can sort it
i bet its something i have done though....
The last post was made 12 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 72.01 Kb
