Front brake still binding after service
Baffler186
PostPosted: 15:32 - 05 Mar 2014    Post subject: Front brake still binding after service Reply with quote
Mk1 bandit 600 - the brakes were binding and last time it was in the garage (200 miles ago) they were apparently serviced, but now they are binding again. Just wondered if this means that either they weren't serviced properly or that the discs are warped? They seem to be rubbing uniformly so thought maybe they are not warped.
Also, how do you tell if the discs are worn (i.e. too worn and need to be replaced)? What are the symptoms?
thanks,
PostPosted: 15:35 - 05 Mar 2014    Post subject: Reply with quote
What exactly did they "service"? If they just gave the exposed pistons a quick blast of brake cleaner that won't have fixed swollen seals.
PostPosted: 15:38 - 05 Mar 2014    Post subject: Reply with quote
How are they "binding" is it first thing in the morning?
Busa1340R
PostPosted: 17:12 - 05 Mar 2014    Post subject: Reply with quote
If you have fairly old rubber brake hoses they can perish from the inside. Small pieces of rubber then block the return passage of brake fluid and subsequently don't allow the caliper pistons to return fully.
This is particulary prevalent when the hoses have been clamped for some reason (such as removing caliper for overhaul)
Current: 2010 Suzuki GSX1340R Hayabusa, 2013 Yamaha YP250R X-Max Sport - Previous: Triumph Sprint ST1050ABS, Honda XL600V Transalp, Honda NT650V Dullsville (don't ask!), Kawasaki ZX9R E1, Honda NX650 Dominator, Suzuki GSX1300RKZ Hayabusa, Honda CBR1000FM, Kawasaki GPZ500S, etc etc
Baffler186
PostPosted: 06:42 - 06 Mar 2014    Post subject: Reply with quote
Break levers are stock and old. They are binding quite badly i.e makes it hard to push, they are the same cold as they are after miles of riding. Not sure how they were serviced bjt judging by the other work this particular garage carried out I'm not certain it was done properly. Will check disc specs against new, and see what they are like.
Benjums
PostPosted: 07:05 - 06 Mar 2014    Post subject: Reply with quote
Morning baffler I've just had to order pads and calliper rebuild kits for my bandit as the brakes were binding on mine as well. If you have to order rebuild kits then here is the link to the ones I have ordered, 150733049798 don't know what the quality is like on them yet as only ordered them last night, but they were one of the cheaper ones I could find after a lot of looking.
PostPosted: 08:41 - 06 Mar 2014    Post subject: Reply with quote
Well, calipers off, pads out, have a look at the pistons. If they're grimed up, give them a clean. That's 15 minutes and you'll know where you stand.
Fizzer Thou
PostPosted: 09:50 - 06 Mar 2014    Post subject: Reply with quote
If you were charged for work to be carried out and the brakes are binding after only 200 miles then return to the shop.
There is nothing I hate more than a shop charging for work that was not carried out.
Always have a 'Plan B'
PostPosted: 10:23 - 06 Mar 2014    Post subject: Reply with quote
To what end? If OP didn't pay for a rebuild, he won't have got a rebuild.
Baffler186
PostPosted: 16:28 - 06 Mar 2014    Post subject: Reply with quote
ok will do. I just assumed that the chap servicing them would have told me if they looked knackered. He gave me a list of everything else that looked worn and then told me to get rid of the bike as soon as I could.
Baffler186
PostPosted: 16:29 - 06 Mar 2014    Post subject: Reply with quote
thanks - could you re-post the link as I just see numbers Confused
Minty
PostPosted: 16:47 - 06 Mar 2014    Post subject: Reply with quote
Search for those numbers in eBay - they are the the listing reference numbers. Thumbs Up
My fingers smell of your mum.
PostPosted: 17:59 - 06 Mar 2014    Post subject: Reply with quote
Sounds like a plan.
I'm completely onboard with the issue of dodgy mechanics not doing work properly, but there's also the consideration that if you put a bike in and say "Fix it mister" then they might be doing you a favour by getting it rolling again and then offering advice as above.
bikertomm
PostPosted: 18:04 - 06 Mar 2014    Post subject: Reply with quote
If you do start having a go yourself and are unsure, make sure you check 'delboys garage' on youtube out.
The blokes an actual legend - really helpful videos of maintenance, it's all on a bandit too!
https://www.youtube.com/watch?v=7LtlhEg1eys
There's also ones of him taking the caliper apart / cleaning ect.
He explains in good detail too Thumbs Up
The last post was made 12 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 92.47 Kb
