Oil pan problem
James2012
PostPosted: 16:10 - 05 Mar 2014    Post subject: Oil pan problem Reply with quote
I've cross threaded my tread on the oil pan by over tighting it, the bolt in in place but leaking oil a little what's the cheapest and easiest way of fixing this? Bearing in mind I have little skill?? The bike is a ybr custom
Cheers James
Still trying to learn
trevor saxe-coburg-gotha
PostPosted: 16:14 - 05 Mar 2014    Post subject: Reply with quote
You've cross threaded it by over tightening it? Does not compute. Do you mean you've simply cross threaded it? Or you've over tightened it and have now rounded the bolt's head trying to get it undone again? Probably the former, I'm guessing - because the latter wouldn't result in leaking oil. Anyway, it's too late now but in future just screw it all the way in by hand then the last half a turn or full turn do with a socket. There's no way you can cross the thread then - unless you've got bionic fingers.
James2012
PostPosted: 16:23 - 05 Mar 2014    Post subject: Reply with quote
Well I undone the bolt and I can see bits of metal chipping on the bolt anyway after emptying all the oil I went to tighten the bolt again and it kept going round and round and would not tighten?? Sorry for the simple talk??
PostPosted: 16:35 - 05 Mar 2014    Post subject: Reply with quote
Hopefully the problem is with the bolt then. Can you tell if the thread on the bolt is damaged? You probably haven't got a spare bolt to try, but that would be the obvious thing to do.
James2012
PostPosted: 16:36 - 05 Mar 2014    Post subject: Reply with quote
The tread on the bolt is fine, it's the cast Sad
skatefreak
PostPosted: 16:48 - 05 Mar 2014    Post subject: Reply with quote
I'll put my money on having threaded the sump.
If the engine/sump is alloy it will strip the thread out before the bolt gets damaged, a bit silly because a new bolt is a lot cheaper than a new sump...
This will result in a bolt that just spins and oil will leak.
What you saw I'm guessing is the thread from the sump in between the thread of the bolt.
Bad times.
You may be able to get the engine casing cheap and swap it but that would be a lot of work.
Another option, much easier is get a heli-cal fitted. The hole will need re-threading and then a metal spiral that sits in the new thread and you can screw your bolt into this.
Google it and you should get a good idea. If you have a tap/die set and are comfortable with it you could buy the helical yourself and DIY it or google for a garage that will do this for you.
Best regards
-Jvr
Busa1340R
PostPosted: 16:49 - 05 Mar 2014    Post subject: Reply with quote
Sounds like you need a Helicoil (thread insert) my friend. You may need to remove the sump pan though as the old thread will require drilling/machining out and you don't want swarf floating around inside your sump. It is usually recommended that the sump plug is replaced as well as a precautionary measure even if it looks servicable.
You can buy helicoil kits and have a bash your self or if you don't feel too confident.....take the sump pan to a mechanical engineer or the whole bike to a reputable workshop.
Current: 2010 Suzuki GSX1340R Hayabusa, 2013 Yamaha YP250R X-Max Sport - Previous: Triumph Sprint ST1050ABS, Honda XL600V Transalp, Honda NT650V Dullsville (don't ask!), Kawasaki ZX9R E1, Honda NX650 Dominator, Suzuki GSX1300RKZ Hayabusa, Honda CBR1000FM, Kawasaki GPZ500S, etc etc
James2012
PostPosted: 16:57 - 05 Mar 2014    Post subject: Reply with quote
Thanks guys is there anything I can do in the mean time? Because need to travel 14 miles everyday for 4 more days?
doggone
PostPosted: 17:02 - 05 Mar 2014    Post subject: Reply with quote
You might get it to seal with some kind of fine material (cloth) bound around the threads.
Does the bolt seem to grip at first then turn loosely at the end?
You might space it with a washer if so.
All very risky though apart from suddenly losing oil which would not be good for your engine it would dump it on the back tyre if it lets go.
More the sort of thing to try as last resort to get you home than a bodge for several days.
Busa1340R
PostPosted: 17:05 - 05 Mar 2014    Post subject: Reply with quote
This would be a bit of a bodge and I wouldn't recommend it, but you can buy a metal repair putty at most motor factors. You could try using some of that to repair the thread or to "permanently set" the sump bung back in the sump. If you go down this route though I would keep a very close eye on it before, "during" and after riding. You don't want any oil on that back tyre.........
James2012
It turns loosely at the end, it's leaking very slowly I mean little drops
James2012
PostPosted: 17:16 - 05 Mar 2014    Post subject: Reply with quote
May have to get some heat proof sealant and set the bolt in, instill I can afford a new sump
doggone
PostPosted: 17:32 - 05 Mar 2014    Post subject: Reply with quote
I can't see that bonding to an oily surface TBH.
A better bet would be thicker, softer gasket of some kind if it's only slowly dripping you might almost stop it.
The risk is you have some pressure in there and it could blow out altogether at a most inconvenient moment.
You clearly won't be able to put enough torque on it to stop it working loose either.
James2012
PostPosted: 20:16 - 05 Mar 2014    Post subject: Reply with quote
Hmmm I can't seem to find a ybr sump pan forsale anywhere Sad
skatefreak
PostPosted: 20:20 - 05 Mar 2014    Post subject: Reply with quote
I know its a bodge but has as much/little chance of success...
What about a bigger screw with a wider thread, easing it in slowly to attempt to cut a rudimentally rough thread?
if the sump is that soft in comparison then it may just work?
-Jvr
James2012
PostPosted: 20:23 - 05 Mar 2014    Post subject: Reply with quote
-Jvr
Hmmm good idea I'm getting so fed up of things going wrong :/ baring in mind this bike is little older than 6 months old Sad it's putting me right off
PostPosted: 20:36 - 05 Mar 2014    Post subject: Reply with quote
-Jvr
Bad idea.
You'll land up with fine metal shavings in the engine to add to the problems.
The basic idea is sound though, it's your suggested execution of it that's poor.
Stripped sump plug holes can often be drilled slightly oversize, a new thread cut and an oversize sump plug fitted.
At a pinch and as a serious bodge, this could be done on the bike very, very slowly and carefully using a frequently-wiped greased dril then tap to catch the swarf.
Given the OP is still at the engineering level of stripping sump plug threads, I would suggest this is probably too big an ask and would end in disaster. As such, it would need to be done with the sump on the bench.
What make and model of bike is it? Not all bikes have a removable sump.
As a temporary measure, and in the full awareness that if it fails it could result in a blown engine, a crashed bike or both, I would wrap loads and loads of PTFE tape round the sump plug then carefully screw it down onto a bonded seal washer until it is just nipped up. If it was me doing that bodge, I'd be very tempted to lockwire it too.
James2012
PostPosted: 20:43 - 05 Mar 2014    Post subject: Reply with quote
-Jvr
Bad idea.
It's a 2013 ybr custom
davebike
PostPosted: 08:15 - 06 Mar 2014    Post subject: Reply with quote
You need to get this right 1st time
The YBR engine dose not have a removable sump
crack the case and it is a new pair crank cases and a full rebuild or a second hand engine
Ride it and the plug comes out could easy be new engine time or oil on rear tyre = crash
A good workshop can either drill and re-tap to a larger plug or fit a Timesert Hellicoils do not work well for sump plugs
Dave
Dave
NC750Xdct + others at work !
[email protected]
James2012
PostPosted: 07:20 - 07 Mar 2014    Post subject: Reply with quote
Dave
I've booked it in with my nearest yamaha workshop for a quote lets hope it doesn't break my bank
Aff
PostPosted: 08:48 - 07 Mar 2014    Post subject: Reply with quote
There are usually unused threads that the OEM plug wont reach. You can often go and buy a longer sump bolt and it will tighten onto these unused threads. I've done this a few times to give people a usable car/bike until they can fix it properly.
Electric Bike Project
James2012
PostPosted: 09:04 - 07 Mar 2014    Post subject: Reply with quote
Yeah good idea . Just wanted a rough estimate of the cost so I know Im not being ripped off lol
mudcow007
PostPosted: 10:12 - 07 Mar 2014    Post subject: Reply with quote
could you not just tap it slightly larger an get a bigger sump plug - saves messing about with coils
im guessing here.....
James2012
PostPosted: 20:27 - 07 Mar 2014    Post subject: Reply with quote
_Iain_ wrote:
Thats because there isn't one as such. The oil drain unbolts from the left side of the crankcase. Short of a full engine strip and cases split there's not really any way of replacing it - its a really really bad engine to have done that on.
Basicly if you bodge it with gasket paste it stands a chance of coming out. Best case if it falls out you kill it quickly (which is unlikely as theres no killswitch, only the key), worst case is the oil ends up on your tyre throwing you under a bus.
I'd sort it propperly. Helicoiling and significant amount of flushing to get the swarf out is probbably the only cost effective option here.
Well either that or getting a magnetic sump bolt of a bigger thread, then drilling & tapping it yourself if you've got the skills to pull it off.
Sump bolt is no.8 on this diagram;
https://www.motorcyclespareparts.eu/App_Themes/VDM/Catalog/Yamaha/Motorcycles/CE_8825_1.jpg
Hmmm just going to have to take it too the bike shop :/
The last post was made 12 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.14 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 137.8 Kb
