bandit start up knock
jam125
PostPosted: 17:38 - 05 Mar 2014    Post subject: bandit start up knock Reply with quote
hi iv got a 600 bandit mk1 on start up it sometimes makes a realy nasty knock (like a spanking the crank case with a hammer kind of nasty knock) as it still starts and runs perfectly i have blamed the starter clutch and motor maby a tooth broken off a gear or somthing. so iv took the cover off the gears are all in good shape but the big gear on the crank shaft has 4 or 5mm of float and can twist slightly it has also slightly scuffed the engine block behind the gear.
so is this play normal? it makes a good clonk when pushed to the engine or pulled up to the starter clutch. i dont just want to start throwing parts at it so if anyone could shed some light on this i would be realy greatfull
jam125
PostPosted: 18:41 - 06 Mar 2014    Post subject: Reply with quote
or can anyone point me to who might know
A100man
PostPosted: 20:03 - 06 Mar 2014    Post subject: Reply with quote
Doesn't sound right to me. If you don't have a manual the next best option is to check at cmsnl for worn, or missing parts..
https://www.cmsnl.com/suzuki-gsf600-s-bandit-1996-1999-usa_model16066/partslist/?model_q=bandit
Good luck..
jam125
PostPosted: 17:43 - 07 Mar 2014    Post subject: Reply with quote
fairly sure its ducked ta for the help
The last post was made 12 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 1.36 - MySQL Queries: 13 - Page Size: 38.93 Kb
