Yamaha YBR125 2012 Speedo/Rev Gauge Bulbs
znetkid
PostPosted: 22:01 - 05 Mar 2014    Post subject: Yamaha YBR125 2012 Speedo/Rev Gauge Bulbs Reply with quote
Does anyone have a guide how to replace the bulbs behind the speedo/rev gauge? The bulb went out last night, although it may be a circuit problem as the speedo done the same thing but came back on after a while.
Thanks!
simonjb
PostPosted: 17:43 - 06 Mar 2014    Post subject: Reply with quote
If there might be a circuit fault, I recommend checking behind the headlight, a connector may simply have come loose. If you have a haynes manual, page 8-14 onwards is where you need to look to find the removal of the instrument cluster and how to replace the bulbs.
To check the wiring, for the YBR (at least the older ones - I presume it's the same) you need to take off the beam unit (the main headlight) by the 2 small screws on the sides of the front chrome part (not the large bolts that hold the whole thing, just the front part). Check all the wiring behind there, specifically the connectors from the instrument cluster, as they come in through the back of the headlight casing.
If you cannot find a problem, you'll need to take off the instrument cluster, take the back off and pull out the bulb holders. I'll post the pages from the haynes manual if you need them.
Current Bike: 2008 Yamaha YBR 125
The last post was made 12 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 31.6 Kb
