2007 YBR125 starting problems - knackered battery?
sabian92
PostPosted: 21:56 - 05 Mar 2014    Post subject: 2007 YBR125 starting problems - knackered battery? Reply with quote
Hey,
Not ridden for a week or so (new tablets etc, not felt right enough to chance it) and got on yesterday for a quick ride out to Liverpool. Started on the button, rode away and did half an hour of solid running out to the airport, then I turned it off.
Sat about a bit and got back on to come home and nada - starter motor wouldn't turn over (well, hardly, you can hear it trying) and the dash lights went dim when I used the button. Started it with the kickstart and it fired (eventually) and rode home. Got 3 miles from home and I let it stall (by accident Embarassed) and it wouldn't start with the electric start again so I pushed it off the road and left it for 15 minutes.
I ended up pushing it 3 miles home (uphill, mostly Rolling Eyes) and I've left it since. Had a flick through the Haynes manual and there's various things it could be, like bad fuel (not likely, used half a tank), flat battery etc. Looked at the servicing receipts and there's nothing in there about a new battery being fitted so I'm guessing it's the original.
Reckon it is just the battery or something more? My MOT is due in the next week and a bit so I need it sorting ASAP. It starts on the kickstart but I'd rather not rely on that. I started it when I pushed it home just to see if it would charge the battery a bit and when I was pushing it it just died on me - revs dropped off and it stalled.
Cheers. Thumbs Up
Islander
PostPosted: 22:03 - 05 Mar 2014    Post subject: Reply with quote
Flat battery. Stick it on charge and see how it goes. Thumbs Up
Pigeon
PostPosted: 22:06 - 05 Mar 2014    Post subject: Reply with quote
Bung a multimeter on the battery terminal. Islander recently told me you should get 12.5v with everything switched off.
I read somewhere else that with the engine running it should go up to about 14.5v
Does sound like a knackered battery, but need to check the charging system is working as it should too.
sabian92
PostPosted: 22:19 - 05 Mar 2014    Post subject: Reply with quote
Reckon just riding around for a few hours would do it? Could do with an excuse to go exploring. That and I don't have the funds at the moment to be spending on stuff I don't 100% need to have.
Islander
PostPosted: 22:36 - 05 Mar 2014    Post subject: Reply with quote
Yep that should stick sufficient charge in for the time being. If it does the same thing again then check the battery and charging voltage as suggested above but tbh, my money would be on a knackered battery. Thumbs Up
sabian92
PostPosted: 22:44 - 05 Mar 2014    Post subject: Reply with quote
Right, there's tomorrow morning sorted then Laughing
I'll give it a good hour and a half, 2 hours ride and turn it off and see what happens. Worst comes to worst I can use the kickstart anyway. Then I'll come home and order a new battery. My fiancee asked if I'd left the heated grips on and I said no but honestly, I might have done. I didn't want to admit that though Laughing
Cheers fellas Thumbs Up
qarka
PostPosted: 22:55 - 05 Mar 2014    Post subject: Reply with quote
Why did you push it home rather than start it with the kickstart?
Boris the spider
PostPosted: 08:39 - 06 Mar 2014    Post subject: Reply with quote
Nice day for a walk maybe ???
I asked myself the same question when I read it.
Yes I'm a pig....And yes... The working public do pay my wages. Tho I contribute to your benefits you lazy c##t. You do not pay my wages. So go fcuk yourself.
sabian92
PostPosted: 10:43 - 06 Mar 2014    Post subject: Reply with quote
It had died when I was riding (at a junction) so I didn't really fancy it dying on me a 2nd time. It was a nice evening though so it wasn't all bad. I picked the night that it was crawling with police though and a few gave me the stinkeye Laughing
bikersupermot...
PostPosted: 11:49 - 06 Mar 2014    Post subject: Reply with quote
my crm is only kick start! your lucky with your electric luxury! cant believe you'd push a bike home thats got a kick start just coz the electric didnt work omg.
would you push your car home if the electric window wouldnt go down? Shocked Laughing sounds like you'd try! lol
tinybikes
simonjb
PostPosted: 17:27 - 06 Mar 2014    Post subject: Reply with quote
Deffo sounds like a flat battery, if you have a multimeter it's definitely worth checking the battery voltage. Should be between 12.5 and 12.8 for a well charged battery (12.8 when it's brand new and 100%).
When you're riding, try to keep the revs to something around 5000 or so, as that's usually when the alternator is producing the highest voltage (14.3+) and hence theoretically charging the fastest. Don't use any extra electrics like heated grips for a while unless absolutely necessary, and try to hold the revs slightly above idle (~2k) when stopped as when the battery is completely flat, the bike can stall at idle speed.
So grateful for a kickstart, why they removed them on the newer YBR's I don't know.
Current Bike: 2008 Yamaha YBR 125
sabian92
PostPosted: 17:37 - 06 Mar 2014    Post subject: Reply with quote
It wasn't that I pushed it because the electric start wouldn't work, it was because it had died several times in traffic and I didn't fancy getting plowed into by somebody watching the lights and not me and running me over.
I haven't got a multimeter but I'm going to get one at some point when I've got the funds. I'm going to get a new battery ASAP though, they're cheaper than a multimeter Laughing
simonjb
PostPosted: 17:54 - 06 Mar 2014    Post subject: Reply with quote
As aforementioned, best to keep the revs above 2k when stopping or travelling slowly; and try to keep the revs at 5k when riding. Best to start your run at a time when there's not much traffic, that way if it is the battery, you should have charged it to a point where it won't stall at idle by the time you have to stop often.
£2.69 with shipping.
https://www.ebay.co.uk/itm/350994707916
Or you can pick one up at any DIY or electrical store for ~£20.
sabian92
PostPosted: 18:09 - 06 Mar 2014    Post subject: Reply with quote
Yeah, I have been but the odd occasion I forgot it dropped off the bottom and stalled. Did it when I tried to pull away in 4th as well Laughing
I've ridden it a good 4 hours over the last 2 days and now the starter motor won't even turn over so it must be shagged and everything is just powered as the bike is riding along. That being said though my heated grips still light up though even with the ignition off.
Cheers for that link - all the ones I've found googling were 20 and 30 quid. I'll order it now. Thumbs Up
Presume red goes to +, black to - and just see what the voltage is? (Or the other way around, can never remember).
simonjb
PostPosted: 18:25 - 06 Mar 2014    Post subject: Reply with quote
Yep Red to +, Black to - though it doesn't really matter, because if you get it wrong, the multimeter will just give you a negative reading of the same value.
When you get the multimeter, make sure your charging circuit is charging the battery properly, by testing the voltage across the battery when the engines running at idle (should be in the 13's likely above 13.3v though can't remember what it should be exactly), and when it's at 5000 RPM (should be around 14.4v).
sabian92
PostPosted: 18:41 - 06 Mar 2014    Post subject: Reply with quote
Right, will do. If it's the charging circuit is faulty, is that a major problem?
Cheers for the help. Thumbs Up
simonjb
PostPosted: 23:33 - 06 Mar 2014    Post subject: Reply with quote
It would depend on what the problem actually was. If it was just the regulator or rectifier (both included in the same unit on the YBR and is the most common charging circuit fault) then it'd be as simple as ordering a new one from ebay or wherever, and fitting it (it's also very easy to access and replace). If it was the alternator its a fair bit more complex.
Don't worry about it till you have a meter, its unlikely as winter kills old batteries anyway. I mean, my brother's CBF battery has all but died, but that's because he's barely used it and now it wont hold charge xD
The last post was made 12 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.16 - MySQL Queries: 13 - Page Size: 102.2 Kb
