yamaha aerox
 Topic moved: from Biking News & Rumours to The Workshop by Korn (5 Mar 2014 - 17:39)
danboy3322
PostPosted: 17:16 - 05 Mar 2014    Post subject: yamaha aerox Reply with quote
Hi, I have a 2003 YAMAHA AEROX i have a PM X-TECH cylinder Alu kit for it and a 21mm carb with a geanelli Exhaust pipe, I cannot quite get the jetting right. Can anybody give me and ideas as to what jet to use and the needle position please? thank you Thumbs Up .
moonzoomer
PostPosted: 22:39 - 05 Mar 2014    Post subject: Re: yamaha aerox Reply with quote
Trial and error mate, no two bikes are the same but if in doubt run it rich instead of weak or even better just get a bigger bike and save yourself a lot of hassle and expense.
evoboy
PostPosted: 00:07 - 06 Mar 2014    Post subject: Reply with quote
Keep going up in jet size untill it bogs out at full throttle, then go back a size.
Set the needle clip to the middle.
APT Motorcycles
stirlinggaz
PostPosted: 13:24 - 06 Mar 2014    Post subject: Reply with quote
hi,
normal procedure is to start off with a main jet too big & work down until its correct.
i know this might result in a few quid wasted on main jets, but not as expensive as running at WOT with too small a main jet,
cheers,
GAZ
danboy3322
PostPosted: 16:22 - 06 Mar 2014    Post subject: YAMAHA AEROX Reply with quote
i have done the trial and error i run it rich to point where its choking like heck (forgot to mention im running practically open carb as im using a k&n air filter) and the pm xtech pistons are like £30.00 each and whilst it was running rich it literally welded the ring to the piston and scored right through up the piston (that may be down to the fact that the flywheel side main bearing collapsed and shards of metal went through the ports and then to the side of piston) but it still welded the ring when running rich.
evoboy
PostPosted: 19:45 - 07 Mar 2014    Post subject: Reply with quote
hi,
cheers,
GAZ
You will do well to seize it just from one run in a lean state. It will show as lean as soon as you try to move off from a standstill as full throttle is nearly always needed to launch.
On a geared bike I would start rich and get leaner till the bike ran best with good plug colour. But for a scooter its far far easier to work the other way round.
For example. The race ped has a 21mm carb and a Athena HPR 70cc kit. The carb came with an 88main. The scooter would still run at full throttle on that jet. It now has a 100main and I'm still going bigger! Laughing
APT Motorcycles
The last post was made 12 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 1.13 - MySQL Queries: 16 - Page Size: 49.79 Kb
