Removing/Refitting rear wheel
TwoWheelsDail...
PostPosted: 11:54 - 07 Mar 2014    Post subject: Removing/Refitting rear wheel Reply with quote
Hey folks,
Im a big noob when it comes to removing/changing/fixing bike stuff.
I want to remove my rear wheel to get decent access to the swing arm for a very deep clean. I have read a few things online and it says i need to remove the caliper?
Also i am worrying about re-aligning the wheel once i have put it back on. Is it really that difficult? Is it any harder than a push bike to allign the wheel? I could rebuild a mountain bike in an hour but i get very worried when doing anything to then bike!
Many thanks,
Benn
Suzuki GSR 750 - 33BHP (Restriction Ends 17/12/2014)
KTM Duke 125 - SOLD
www.facebook.com/TwoWheelsDaily | www.twitter.com/TwoWheelsDaily | www.instagram.com/TwoWheelsDaily
MeatHelmet
PostPosted: 12:09 - 07 Mar 2014    Post subject: Reply with quote
It makes life easier of you remove the rear calliper, just make sure you support the calliper once off and don't let it hang on the brake line.
Putting the wheel back on and aligning it is not as difficult as you might think. You just have to remember to turn the adjustment bolts a little at a time alternating between sides and make sure your chain isn't too tight/slack.
Maybe have a look on youtube for some instructional vids. Better to watch someone do it before you attempt it i always think.
Bike - 2003 Kawasaki ZX6R 636 Ninja (A1P)
PostPosted: 12:10 - 07 Mar 2014    Post subject: Re: Removing/Refitting rear wheel Reply with quote
If you don't touch the adjusters (which you shouldn't have to), you shouldn't need to 'do' anything to align it again - it'll be setup in the same position it was when you took it off.
MeatHelmet
PostPosted: 12:14 - 07 Mar 2014    Post subject: Re: Removing/Refitting rear wheel Reply with quote
True, but i like to run them back and adjust until they are spot on, that way I make sure the chain is spot on too. Just a personal preference.
PostPosted: 12:24 - 07 Mar 2014    Post subject: Re: Removing/Refitting rear wheel Reply with quote
What do you use to check alignment?
The last post was made 12 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 44.62 Kb
