PC extremely slow to start up, if at all
Tungtvann
PostPosted: 11:08 - 08 Mar 2014    Post subject: PC extremely slow to start up, if at all Reply with quote
When I first got my PC, it would be up and running from button press to windows in 30 seconds. Something happened over the last few weeks, and it would stall at the 'starting windows' graphic for another minute or 2 before finally getting to windows. A few times whilst loading up, it would crash and I'd have to reset it, initiating windows start up repair (or whatever it's called) to replace missing/damaged files. But this doesn't seem to solve the problem.
Once running, PC is fine and runs quick as you like. It's just getting it started that's the problem.
Any ideas of causes or things I can check to identify what may be screwing with it?
Thanks.
The Artist
PostPosted: 11:12 - 08 Mar 2014    Post subject: Reply with quote
You have provided no information about your PC at all other than it uses Windows which has narrowed it down to 2 decades of OS's. Laughing
Tungtvann
PostPosted: 11:15 - 08 Mar 2014    Post subject: Reply with quote
Microsoft Windows 7 Home Premium 64 BIT
2 TB Seagate (2000 GB) SATA-III HDD 7200 RPM 64MB
Asus P9X79 (Intel X79)
4x Blu-Ray Reader & 8x DVD-ROM - Black (SATA)
XFX 850W ProSeries PSU - Low Noise
Corsair Vengeance C70 Rugged Series (Military Green)
Gigabyte (M6800) Optical Gaming Mouse - (USB) - Black
AMD Radeon HD 7990 - 6 GB - (XFX) - (PCI-E)
16 GB 1600MHz (2x8GB) - (DDR3) - Limited Time Low Price
Arctic Alpine 20 PLUS CO Heatsink & Fan
Intel Core i7 4820K (4 x 3.7 GHZ)
240 GB Kingston SSD SATA-III, Read 450MB/s, Write 450MB/s - Silent
Like that?
CaNsA
Download, install and run this
https://www.hdtune.com/files/hdtunepro_550_trial.exe
do a full error scan on all your drives.
https://i.imgur.com/Bb4SqT5.png
If you cant boot into windows then...
Download this
https://www.hirensbootcd.org/files/Hirens.BootCD.15.2.zip
unzip it, burn the iso to a dvd or cd
boot it, load mini windows, then run hdtune and run a full error scan.
Tungtvann
PostPosted: 11:41 - 08 Mar 2014    Post subject: Reply with quote
Error scan was all green, no issues.
CaNsA
PostPosted: 11:47 - 08 Mar 2014    Post subject: Reply with quote
you scanned all your drives within 30mins?
did you do the lazy boy's quick scan?
Tungtvann
PostPosted: 11:49 - 08 Mar 2014    Post subject: Reply with quote
240gb SSD @ a few hundred mb/s.
CaNsA
PostPosted: 12:15 - 08 Mar 2014    Post subject: Reply with quote
And what about the 2tb?
slowlydoesit
PostPosted: 13:25 - 08 Mar 2014    Post subject: Re: PC extremely slow to start up, if at all Reply with quote
Try installing X-Setup Pro from this link:
https://www.majorgeeks.com/files/details/x_setup_pro.html
Use the license key given at the bottom of the page. This app allows you to see what is being loaded at startup. There's usually a lot more there than is visible in the Startup folder. Also allows you to disable things one by one. Very good, but use with care as you can mess up your configuration.
CaNsA
PostPosted: 13:38 - 08 Mar 2014    Post subject: Re: PC extremely slow to start up, if at all Reply with quote
Pointless, msconfig does the same thing....
slowlydoesit
PostPosted: 17:21 - 08 Mar 2014    Post subject: Re: PC extremely slow to start up, if at all Reply with quote
Last time I looked X-Setup was more comprehensive and has a more friendly GUI to boot...
CaNsA
PostPosted: 17:28 - 08 Mar 2014    Post subject: Reply with quote
Well it is probably still the same as the last time you looked as the software hasnt been updated for 4yrs and is very unlikely to be updated anytime soon.
Tungtvann
PostPosted: 13:32 - 09 Mar 2014    Post subject: Reply with quote
Checked the 2TB drive, took bloody hours but it all came back green. I'm thinking it was a physical issue, I started having problems when I tried to fit a 2nd DVD drive (didn't work anyway because it's got old IDE connectors).
So I've just opened the PC up, had a fiddle, make sure everything was seated correctly. Nothing appeared to be out of place, but I just started it up again and boom, Bob's your next door neighbour, it's up and running in seconds.
Pretty weird, I'd have thought if something was loose, it wouldn't work at all, or would cause issues when running if it did.
Dalemac
PostPosted: 16:34 - 09 Mar 2014    Post subject: Reply with quote
It's not uncommon for random crash and start-up issues to be caused by incorrectly fitted hardware.
I once bought a basic tower from a shop, and it wouldn't stop crashing. took the CPU out and found a slightly bent pin. Straightened it out ad didn't have any further issues.
YBR125 -> GPZ500S -> SL1000
The last post was made 12 years, 183 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 78.27 Kb
