Oil Filter Stuck!
bikertomm
PostPosted: 22:08 - 09 Mar 2014    Post subject: Oil Filter Stuck! Reply with quote
Hi guys, went to do an oil change today for the first time and failed at the first hurdle.
Thought I'd try and crack the filter before letting all the oil drain out, and I failed.
You can see it almost looks rusted on. I'm worried it hasn't been off in a long time. What bloody monkey tightened that!
https://i1145.photobucket.com/albums/o520/bikerrtomm/20140306_144605_zps641c6672.jpg
Have used brute force with just hands, a chain wrench tool that just wanted to dent and pierce it.. a special tool that clamps round it and all no luck.
Ideally I don't want to use the screwdriver method unless last resort.
I think I need to try and get those special pliers from halfrauds.
Would penetrating oil in the meantime do any good? I was worried it could actually get inside the filter? I've never used it before either.
Any ideas?
Cheers!!
Tom Thumbs Up
The Artist
PostPosted: 22:09 - 09 Mar 2014    Post subject: Reply with quote
You can't really go wrong with the screwdriver method unless it is totally ruined anyway.
Do it about midway so if for some reason it doesn't work, there is still something to work with.
woll
PostPosted: 22:17 - 09 Mar 2014    Post subject: Reply with quote
+1 on ramming a screw driver through it. If that fails your fucked rip it to shreds and peel the threads off.
-LG-
PostPosted: 22:18 - 09 Mar 2014    Post subject: Reply with quote
I used the screwdriver method when attempting to do mine. Pain in the arse!
Snow rider wrote: I'm far to annoying to be near for long periods of time
yen_powell
PostPosted: 22:26 - 09 Mar 2014    Post subject: Reply with quote
On a really stuck one recently I used filter pliers and a chain wrench at the same time, one close to the joint with the engine and one halfway along, worked a treat.
XT1200Z and a DR350 in bits
lihp
PostPosted: 22:31 - 09 Mar 2014    Post subject: Reply with quote
https://washford.scene7.com/is/image/Washford/400-696674?$PDP_MAIN$
lihp
sickpup
Old Timer
Try a boa, its a rubber strap wrench.
bikertomm
PostPosted: 22:33 - 09 Mar 2014    Post subject: Reply with quote
Sounds like a plan!
Thanks for all responses.. anyone know about this penetrating oil?
Ed Case
PostPosted: 22:35 - 09 Mar 2014    Post subject: Reply with quote
In the past when some twerp has wound the filter on like his life depended upon it I've been reduced to using a slim 6" sharp cold chisel and a light hammer. Desperation I know but it worked. Bloody hate using hammers on bikes.
bikertomm
PostPosted: 22:40 - 09 Mar 2014    Post subject: Reply with quote
Is it something like this?
https://i.ebayimg.com/t/DRAPER-43863-2-PIECE-OIL-FILTER-STRAP-WRENCH-REMOVAL-TOOL-/00/s/NDIzWDgwMA==/z/NIUAAMXQUY1RAr2Z/$(KGrHqR,!g4FC+kQC5vDBR!r2ZBMtw~~60_12.JPG
Ooooh shiney.
https://img.auctiva.com/imgdata/1/5/3/2/6/7/3/webimg/716900929_o.jpg
Coupled with this:
https://i.ebayimg.com/t/NEW-12-OIL-FILTER-ADJUSTABLE-WRENCH-REMOVAL-PLIER-TOOL-/00/s/NTAwWDUwMA==/z/ikoAAOxydlFS1Q4D/$_12.JPG
Might give me a better chance.
Cheers for all suggestions! Thumbs Up
RhynoCZ
PostPosted: 22:53 - 09 Mar 2014    Post subject: Reply with quote
Have you tried WD40? Thumbs Up
Nb
PostPosted: 23:04 - 09 Mar 2014    Post subject: Reply with quote
I find these do well provided you can get them in on cars and bikes
https://www.monumenttools.com/web_images/72dpi_min500pix_A/MON2022.jpg
Rogue_Shadow
Used something similar to that to remove mine from the SV.
Apart from mine attached to a socket wrench Twisted Evil
Crushed the filter to hell, but it loosened it enough to remove by hand Thumbs Up
A screw driver would be a last resort for me, mainly because I know it's a last resort
I like knowing that other options are available Razz
bikertomm
PostPosted: 23:12 - 09 Mar 2014    Post subject: Reply with quote
Yes.. had it soaking in the stuff! Twisted Evil
And rogue shadow haha that's good to hear, think I will purchase one of those and some pliers Thumbs Up
kerr
PostPosted: 00:03 - 10 Mar 2014    Post subject: Reply with quote
Cheap method : wrap masking tape round it, turn it over frequently so the outside is sticky, this way you can get a good grip with your hands.
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
John933
PostPosted: 00:17 - 10 Mar 2014    Post subject: Reply with quote
If it's on as tight as I think it is. You will need a chain tool. I use one on my bike. Well worth getting one for the price. Tip of the week, When fitting a new filter back, rub a smear of grease round the rubber gasket. The whole thing will after a few day's heat up and some-how grow. I then go back and give it a quarter turn off the thread. Make's life a lot easer to get off next time.
John933
My trip
PostPosted: 00:24 - 10 Mar 2014    Post subject: Reply with quote
Probably not going to help. If the threads are seized then they are doing well, having been immersed in oil for ages, and are nowhere near the outside of the filter. The only thing the penetrating oil is going to reach is the rubber seal on the filter which is probably not going to be freed off by it.
Darylw27
PostPosted: 00:36 - 10 Mar 2014    Post subject: Reply with quote
Looking at that I'd +1 for the screwdriver if brute forcing it off with a filter wrench failed. Penetrating oil will be unlikely to help in a situation like this unfortunately.
PostPosted: 00:48 - 10 Mar 2014    Post subject: Reply with quote
I'd have smashed a screwdriver through it, had it off, and serviced the missus by now.
PostPosted: 09:32 - 10 Mar 2014    Post subject: Re: Oil Filter Stuck! Reply with quote
The rust you can see is just rust on the collar of the filter. Personally I'd whack a scerw driver through it. Always been able to get mine off with the filter tool personally, even ones that have been done up by Heman.
DrDonnyBrago
PostPosted: 09:50 - 10 Mar 2014    Post subject: Reply with quote
Don't stab a screwdriver in it.
My CBR had a similarly stuck filter when I first bought it, screwdriver hammered in near the base still tore it open and I was left with a stub attached to the cooler. In the end, used a chisel on the rim of the fitler to get it to turn.
I'd use a filter cup type removal tool if I had another stuck filter.
james1988
PostPosted: 10:20 - 10 Mar 2014    Post subject: Reply with quote
In the past I've found using a cut up anti slip mat for grip good enough for getting the filter moving where it wouldn't just by hand. When that hasn't worked, the hammer and screw driver come out.
James
Honda XL1000VA '07
barrkel
PostPosted: 14:36 - 10 Mar 2014    Post subject: Reply with quote
Cup socket removal things can end up just skipping over the flats on the filter.
I have a filter chain tool, filter pliers and filter locking wrench.
There wasn't enough clearance to use the chain tool. I couldn't get the filter pliers to grip hard enough, ended up using them as pincers, almost stabbing the oil filter.
But now I have an oil filter locking wrench, basically mole grips with wider jaws, like these ones (American, first search result):
https://www.harborfreight.com/locking-oil-filter-wrench-66568.html#.Ux2_T9u9rW0
slowlydoesit
PostPosted: 17:34 - 10 Mar 2014    Post subject: Reply with quote
Possible tautology in progress!
The last post was made 12 years, 229 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.93 - MySQL Queries: 13 - Page Size: 127.21 Kb
