Honda Bros chain adjustment
DukeRed
PostPosted: 17:55 - 03 Jan 2005    Post subject: Honda Bros chain adjustment Reply with quote
How do I do it and how tight/loose should it be. At the moment I can push the chain up about 2 inches and down 1.
Also how can you tell when you need to get a new chain?
Jan
Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com
mr.z
PostPosted: 18:38 - 03 Jan 2005    Post subject: Reply with quote
Right, it should defeately be less than that, at its tightest point dont forget! depending on the bike really how loose/tight it should be.....
You chain needs changeing if its visibly knackered, or if it can't be adjusted any more, also if the sprockkets are hooked or obviously worn in any other way they need replaceing as does the chain with them...
To adjust it loosten the axle nut, then use the adjusters at the ends of the swing arm, turn them both EQUALY small ammounts at a time, clockwise should tighten the chain... when your done tighten any locknuts and the axle nut.
When you change the chain you need to change both sprockkets as well at the same time, because they wear together...
DukeRed
PostPosted: 19:13 - 03 Jan 2005    Post subject: Reply with quote
The odd thing is that it doesn't have adjusters at the end, which is why I'm confused.
Jan
mr.z
PostPosted: 19:30 - 03 Jan 2005    Post subject: Reply with quote
* Looks sexy, is easy to clean and makes wheel changing a complete doddle. The chain is adjusted by turning an ecentric cam, you must have the correct spanner and you do have to learn the knack of getting the spanner to locate on the cams.
Much easier on the gearbox than the shaft drive fitted to the NTV etc. The gearbox on the Honda V twins is noted as being very clunky, even on the latest version. Chain tension on the Bros is difficult to assess as the swingarm pivot is way behind the gaer box sprocket. You must have your weight on the bike to set the tension correctly, set it as per the manual and it'll be too tight. Get a mate of approx the same weight as yourself to sit on the bike and then adjust the chain. When the chain is correctly adjusted, get your mate off and put the critter on the centre stand. Now take the adjusting spanner and hold the handle by the little arrow stamped on the sdie of the swingarm, put a piece of tape on the handle to represent the correct tension and you'll not need your mate again. When correctly tensioned it will be VERY loose when the bike is on the centre stand.
Ah, apparently there a little more to it Very Happy
I'm sure some peeps here have owned a bros at some point, hopefully somebody will be able to help a bit more
carvell
Scuttler
PostPosted: 19:49 - 03 Jan 2005    Post subject: Reply with quote
Yup I can tell you.
Well, the manual on my PC can, far too hard to explain.
Loosen the eccentric bearing carrier pinch bolt.
Turn the eccentric bearing carrier clockwise or counterclockwise by the bearing carrier wrench to obtain the drive chain slack as necessary.
Tighten the eccentric bearing carrier pinch bolt.
You really need a C-spanner to do it, or a hammer and a punch.
Yamaha TDM 850
DukeRed
PostPosted: 21:11 - 03 Jan 2005    Post subject: Reply with quote
Ah I see. So after loosening the pinch bolt just turning the disc parallel to the wheel adjust the tension.
Can't find a C-spanner anywhere though, hoping a screwdriver and hammer will do the job.
Thanks alot
Jan Thumbs Up
sickpup
Old Timer
PostPosted: 11:53 - 04 Jan 2005    Post subject: Reply with quote
Jan Thumbs Up
No it won't but it will fuck up the adjuster pretty damn quick.
carvell
Scuttler
PostPosted: 12:10 - 04 Jan 2005    Post subject: Reply with quote
Had a couple of people asking for the manual that I was refering to, so there is a link to an online version below. Although it is clearly for the 650cc version, everything is pretty much exactly the same.
You'd be doing well to do what I have done and save the lot to your PC incase it ever goes offline.
https://www.hawkworks.net/manual/
Yamaha TDM 850
DukeRed
PostPosted: 23:03 - 04 Jan 2005    Post subject: Reply with quote
Cheers carvell Thumbs Up
Well I know exactly what I'm doing but the bloody pinch bolt is really tight and no matter what spanner or spanner with attached lever will do it.
Anyone in Luton with a hefty wrench and c spanner?
Jan
mr.z
PostPosted: 00:44 - 05 Jan 2005    Post subject: Reply with quote
Try giveing it a dose of WD40 (dont get your tyres, maybe put a rag behind the bold) get a socket to fit on the bolt then use a hammer on top to give it a short sharp "tap" this should losten the bolt a bit... a mallet is an amazeingly satisfying piece of equipment to own and use Cool
I can imagine that being a bloody fiddley place to be swinging a mallet so take care!
Oh yeh, when you put it back... copper grease, lots of, is your friend Thumbs Up
carvell
Scuttler
PostPosted: 00:50 - 05 Jan 2005    Post subject: Reply with quote
Mine was very tight too.
I ended up attaching a massive pole to the spanner, getting my brother to hold the bike and taking a run up and flying kick at the pole - did the job, even if I did miss the first 6 times.
Yamaha TDM 850
hawkeye
PostPosted: 07:09 - 05 Jan 2005    Post subject: Reply with quote
Nooooooooooooo don't use a hammer and punch, it'll knacker the adjuster and then you'll find out exactly how the whole rear axle goes together when you replace it!!! I got a double ended C-Spanner from the local bike shop. One end fits the chain adjuster and the other fits the shock Smile (The swinger and adjuster assembly for the Bros is very smiliar to the NC30 and my housemate has a Bros 400)
When you're setting the chain tension, you should really do it with the bike laden (ie with you on it), but you can allow for that slightly. You should measure the slack about half way between the sprockets on the bottom run and it should be about and inch on so. Theres a picture on my chain guard of what the slack should be Smile Hope that helps.
'89 R/W/B NC30
'The car in front is... in my way'
DukeRed
PostPosted: 18:44 - 05 Jan 2005    Post subject: Reply with quote
Went out and bought a doubled ended c-spanner. Doesn't bloody fit for some reason. Well I will try it in the light so I can actually see it but by the feel of it the spanner is too wide Confused .
Was VERY tempted to try the screwdriver and hammer technique since two mechanics I went to suggested it. (A&M & Dave Bliss).
Jan
The last post was made 21 years, 272 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 81.57 Kb
