RS 125 Coolant leak and overheating?!? (Helppp)
RsJohno
PostPosted: 12:18 - 11 Mar 2014    Post subject: RS 125 Coolant leak and overheating?!? (Helppp) Reply with quote
I have a 2001 RS 125 that is leaking/pissing water out of the header tank cap and overheating, I have changed the head gasket, thermostat and radiator, flushed the pipes and bled them and it is still doing it there seems to be a major pressure build up.. Anyone know what the problem could be? The water pump seems to be working as well.
PostPosted: 00:26 - 12 Mar 2014    Post subject: Reply with quote
What coolant are you using? 50 / 50 mix of water and anti freeze?
RsJohno
PostPosted: 16:27 - 12 Mar 2014    Post subject: Reply with quote
Yeah mate, I am using the correct coolant
PostPosted: 23:45 - 12 Mar 2014    Post subject: Reply with quote
If the cooling system is working normally but still pressurising then suggests a 'leak' somewhere. You have changed the head gasket O ring so hopefully that is OK, but possibly time to check for a cracked head or barrel.
Omega
PostPosted: 06:09 - 13 Mar 2014    Post subject: Reply with quote
Could the cap itself be damaged and releasing pressure early? I had that problem on one of my cars. The bottom of the cap had split.
Omega
PostPosted: 08:43 - 13 Mar 2014    Post subject: Reply with quote
Assuming it is actually overheating. Does the fan turn on when it should?
PostPosted: 23:35 - 13 Mar 2014    Post subject: Reply with quote
No fan on the RS125.
The last post was made 11 years, 342 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 52.35 Kb
