my new bike
fullmetalwing
PostPosted: 20:03 - 11 Mar 2014    Post subject: my new bike Reply with quote
Hi there
I got my new bike its a 2nd kymco pulsar 125 I am having trouble starting her up this my first bike I just done my CBT today, I had to change the battery as he had died now lol my boy friend can start it up but I don't get why I can't maybe it because I am not use to it yet any advice for a noob
Thanks
wr6133
PostPosted: 20:20 - 11 Mar 2014    Post subject: Reply with quote
Is it in gear? If it is it probably won't start
Not that? Then try with the sidestand up
shereen
PostPosted: 20:30 - 11 Mar 2014    Post subject: Reply with quote
Check the above.
Also try holding the clutch in when you are starting it.
fullmetalwing
PostPosted: 20:31 - 11 Mar 2014    Post subject: Reply with quote
Thank you will try it tomorrow and see what happens
ws4936
PostPosted: 21:04 - 11 Mar 2014    Post subject: Reply with quote
It's kickstart right? Maybe technique.
Try a fast sharp hard kick with control and slow rapidly at the end of the kick, and as mentioned, half choke maybe.
These bikes can be a niggle but very satisfying when you are both as one like ying and yang.
If everything seems under control, you're just not going fast enough.
PostPosted: 21:18 - 11 Mar 2014    Post subject: Reply with quote
DON'T PANIC!
These are very simple bikes and you will get it going.
First, has it got fuel in the tank? Are you sure?
It appears to have a vacuum operated fuel tap, so we'll skip that for now, unless you can find an obvious lever on it marked PRI (or prime).
Does it not fire at all? If so, check that the killswitch hasn't been tripped. It's on the right hand controls and it should look like this:
https://i.ebayimg.com/t/Kymco-Pulsar-125-Right-Hand-Switch-Gear-/00/s/MTYwMFgxMjAw/z/dHYAAOxyNo9Sovd4/$_35.JPG
You want the switch to be on the setting that doesn't have an X through it.
If your chap got it started, was it warm when you tried to start it?
If so, did he leave the choke on? It looks like the choke lever is on the left hand switchgear, although I'm not 100% confident about that - it could be on the carb itself.
If you can let us know exactly what's happening, we can maybe diagnose it. Does it not fire up at all? Does it stutter but not fire up properly? Does it fire up but then die?
fullmetalwing
PostPosted: 13:25 - 12 Mar 2014    Post subject: Reply with quote
I got her started this morning Smile thank you all for the help hope the weather is nice is for my first ride tomarrow I report how she performed lol
The last post was made 12 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 54.69 Kb
