| kramdra |
 kramdra World Chat Champion
 Posted: 23:33 - 12 Mar 2014 Post subject: Carb float needles |
Would like some advice on how to fix the carb float needles as its pissing fuel out the overflow. When they shut, they seal perfectly. They are 100% clean and the rubber tips are good. Im not sure if the needle seats are too loose from being corroded or if the floats are lacking enough buoyancy.
The floats do float - therefore they are not leaking. They move smoothly but if I tilt carb upside down, the needles seem to stick 50% of the time.
The brass needle seats were corroded but cleaned up easily with a non scratch kitchen pad.
I stripped carb again today and put the float bowls back from below with great care so that I could be sure they would not stick. Connected tank and it pissed out overflow
Is this a common problem with carbs? I dont think the brass seats are removable without machining?
TL:DR = Im not sure if the needle seats are too loose from being corroded or if the floats are lacking enough buoyancy |
| moonzoomer |
 moonzoomer World Chat Champion
| bypass2 |
 bypass2 Spanner Monkey
| kramdra |
| bypass2 |
| temeluchus |
| kramdra |
 - Super Spammer
The last post was made 11 years, 348 days ago. Instead of replying here, would creating a new thread be more useful? |
