CB500 Takes Ages To Start
Motorhate
PostPosted: 13:15 - 13 Mar 2014    Post subject: CB500 Takes Ages To Start Reply with quote
My CB500 takes ages to start. Not sure why, but I'll turn over for ages and not fire. Just when I think it won't start (after about 5mins trying to turn over) it'll fire up. When its warmed up its fine - can stop and start with no problems. I don't think its the battery or plugs as I'd assume it would have problems starting all the time.
Don't think its carb issue as the bike starts without choke, just takes a long time to start.
Any suggestions?
Current - Harley Davidson FXDB Street Bob | Harley Davidson FLTR Road Glide | Harley Davidson Road King
GONE - Honda CB500 Ratbike | Yamaha FZ750 | Yamaha XVS1100 | Kawasaki VN2000 | Kawasaki ER-6 F | Harley Davidson XL883L Sportster
Formerly known as
P.
PostPosted: 13:17 - 13 Mar 2014    Post subject: Reply with quote
Put full choke on.
I'm starting all my carbed bikes with at least 1/2 choke, maybe more these days.
orac
PostPosted: 13:18 - 13 Mar 2014    Post subject: Reply with quote
when were valave gaps last done? cold engine will almost always need choke - it will take an age to start without choke.
how old is the battery, how fast does it crank.
Motorhate
PostPosted: 13:21 - 13 Mar 2014    Post subject: Reply with quote
Not sure when they valve gaps were done, previous owner didn't mention it. Battery is about a year old. Takes about 15 - 20 turns of the ignition over the space of about 5mins. I leave a gap for fear of flooding the engine.
orac
PostPosted: 13:27 - 13 Mar 2014    Post subject: Reply with quote
do you give it any throttle when starting, there seems to be a thing that people like to twist the throttle when starting a machine. some need about 5 mill off the stop when starting without choek ona luke warm engine, but otherwise the throttle shoudl ne be touched.
also have you looked at plug gaps, i had difficulties with mine a while back, the irridiums and warn to 1.3mm gpas from the quoted 0.7mm
Formerly known as
P.
PostPosted: 13:28 - 13 Mar 2014    Post subject: Reply with quote
Check the spark plugs, use full choke and start it properly. You won't flood it then.
Motorhate
PostPosted: 13:52 - 13 Mar 2014    Post subject: Reply with quote
I do give it a little bit of throttle, not a great deal though along with the choke out halfway. Plugs were replaced recently (not by me though) so will give them a look at too. What is the recommended gap measurement? Any ideas? Sorry - I'm about as mechanically minded as a Gok Wan.
Formerly known as
P.
PostPosted: 13:56 - 13 Mar 2014    Post subject: Reply with quote
I've never really bothered gapping a plug, it "works" but hey.
I would say full choke, no throttle, use the starter for 2 seconds, then a teeny bit of throttle.
PostPosted: 13:59 - 13 Mar 2014    Post subject: Reply with quote
How to start a CB500:
Fuel on. Choke on full. Ignition on. Killswitch to run. Make sure it's in neutral. Press button. Do not touch throttle.
Why would you only use half choke?
map
Mr Calendar
PostPosted: 14:06 - 13 Mar 2014    Post subject: Reply with quote
Possible issue with starter motor. Bushes probably. There was a thread on here a bit back about repair (do a search).
I know this as I have an issue with mine. Occasional hit starter and get nothing, maybe a few clicks (so maybe not like your issue). Put in 2nd and run forward, like a push start. Hit starter again and all fires up.
I have never ever been able to start the CB500 without full choke.
Motorhate
PostPosted: 15:43 - 13 Mar 2014    Post subject: Reply with quote
My FZ would only start on half choke so ( actually a little bit over half but never on full) so just copied the habit from there.
Interesting that you've never gapped a plug Paddy. Thought that was essential.
Not sure if its a starter motor problem as the starter seems to turn over OK, just doesn't fire.
Conzar
PostPosted: 15:47 - 13 Mar 2014    Post subject: Reply with quote
CB500, Though you would have to use a pull cord for one of those.
Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
11:05:35 Rob Fzs: i just wanna own an rd350 valve before they send us to war with durkadurkastan
Formerly known as
P.
PostPosted: 15:55 - 13 Mar 2014    Post subject: Reply with quote
Its a full choke problem, put it on full and start it Thumbs Up
davebike
PostPosted: 16:41 - 13 Mar 2014    Post subject: Reply with quote
I say either air filter or plugs
I have a look to see what plugs were fitted Should be CR8EH-9 or better CR8EHIX-9
I seldom need choke on mine or my previous CB500 or any of the Loan ones we had
I have Owned and serviced Lots of CB500's
Hardly ever seen one needing the valve clearance doing but air filter plugs and oil are common sources of problems
Dave
Dave
NC750Xdct + others at work !
davebike1@gmail.com
trevor saxe-coburg-gotha
PostPosted: 19:41 - 13 Mar 2014    Post subject: Reply with quote
You do *not* need any choke to start a CB500 - if it's been garaged and used regularly. Assuming we're talking the '90s twins. Bit of throttle - should catch within first second or two. Then hold it at 500 to 1000 rpm - should come on two in about half a minute or so. After a minute or two it should be able to idle at 1250rpm with no trouble at all, while you get the rest of your clobber on to give it a little more time to warm. The CB5 is no cold arsed breed and gets to a healthy temperature with ease if it's in decent nick.
Motorhate
PostPosted: 19:54 - 13 Mar 2014    Post subject: Reply with quote
Not garaged unfortunately and does seem to start a bit quicker in the warm weather or when the bike is warmed up.
The last post was made 11 years, 342 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 90.5 Kb
