non firing cylinders (3 & 4) - Bandit 600
mudcow007
PostPosted: 22:25 - 13 Mar 2014    Post subject: non firing cylinders (3 & 4) - Bandit 600 Reply with quote
men folk (an err lady folk) lend me your ears....
got my bandit back tonight from the menders who has said he cleaned the carbs - jets were blocked
but it isnt firing on the far right hand side cylinder
he said he tried to trim the lead but its had no change
so reckons it might be the coil?
plug seems to be firing when removed from cylinder, can i swap the coils over from the other side?
can you test a coil?
cheers all
Bezzer
PostPosted: 23:38 - 13 Mar 2014    Post subject: Reply with quote
Replied on the Bandit forum Thumbs Up
mudcow007
PostPosted: 22:13 - 17 Mar 2014    Post subject: Reply with quote
right..
a bit of an update
just had a poke around for the first time since bring the bike back home
the bike initially started but sounded lumpy, it seems to be running on only 2 cylinders (1 & 2) as these were the only headers that were hot to touch
i pulled the plugs from 3 & 4, both had blue sparks
my guess is fuel ?
but then im also getting a back fire so fuel must be getting through - if i undue the drain screws on the carbs that arnt firing could that show anything?
after the bike had (kinda of) run for a few mins, i pulled the plugs on 1 & 2 an they were pretty black - choke was on though 3 & 4 plugs are clean an dry
sickpup
Old Timer
PostPosted: 05:10 - 18 Mar 2014    Post subject: Reply with quote
the coils iirc should have one going to 1-4 and the other to 2-3, are yours set up this way?
PostPosted: 06:18 - 18 Mar 2014    Post subject: Reply with quote
That would be my first guess too.
mudcow007
PostPosted: 08:50 - 18 Mar 2014    Post subject: Reply with quote
i'm pretty sure i checked the leads last night, but will confirm tonight - thanks
think i'm going to try an resurrect the old scabby carbs that came as spares with the bike an see if i can get them clean & fit em
mudcow007
PostPosted: 19:15 - 18 Mar 2014    Post subject: Reply with quote
Update
just checked coils an L coil is 1 & 3, R coil is 2 & 4
is it possible to check if carbs on the right (3 & 4) are getting fuel?
sorry for stupid questions all!
Marmaduke
PostPosted: 19:28 - 18 Mar 2014    Post subject: Reply with quote
Drain screws on the bottom will reveal if fuel is getting to the carbs.
They'd have to be real dirty to not reach them though.
Checking if the plugs are wet will tell you if the fuel makes it further.
I'd take the carbs apart yourself, real simple on the bandit.
Ask if you need help as I only done mine last week.
Current: '03 Tuono RSV1000, '05 Van Van, '91 Zephyr 550
Previous: Multistrada 620,Bandit 600,Kawsaki ER-5, BMW K-75
PostPosted: 19:39 - 18 Mar 2014    Post subject: Reply with quote
mudcow007 wrote:
Update
Your plug leads are wrong. Swap 3 and 4 over.
331X2
PostPosted: 20:30 - 18 Mar 2014    Post subject: Reply with quote
+1 Thumbs Up
Would that explain the backfire as it sparks at the top of the exhaust stroke? Or just F/A mixture in the hot exhaust?
mudcow007
PostPosted: 21:24 - 18 Mar 2014    Post subject: Reply with quote
its alive an kicking!!!
cheers guys mucho Karma
Mr. Green
The last post was made 11 years, 304 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 69.26 Kb
