newer model instrument panel on older model bike?
mikesaa309
PostPosted: 19:43 - 14 Mar 2014    Post subject: newer model instrument panel on older model bike? Reply with quote
I have the Bandit 600 1997 model however prefer the instrument panel of the newer 2000 upwards model. Is it possible to change them? I do believe the newer Bandits have an electronic instrument panel but not sure whether the 1997 model will have the required connections for it to work?
Not really a massive issue and probably won't change it just yet, but just out of curiosity, if in the future I decide to change them, is it do able?
PostPosted: 20:05 - 14 Mar 2014    Post subject: Reply with quote
Probably not likely that they are plug compatible. Is the later Bandits speedo driven from a pickup on the front sprocket cover?
One issue is that if you swap the clocks then any future buyer will suspect the bike has had a hefty crash, and at min will not trust the mileage at all.
PostPosted: 20:25 - 14 Mar 2014    Post subject: Reply with quote
They are not compatible and the speedo won't work. Mk1 is mechanical Mk2 electronic.
sabian92
PostPosted: 21:43 - 14 Mar 2014    Post subject: Reply with quote
You can likely put on an aftermarket generic one but you'll need sensors and all sorts of other pains in the arse to do it.
Source: I started a thread on it and was told it was a pain in the arse Laughing
The last post was made 12 years, 175 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 40.23 Kb
