Steering Dampers
Jon
Anyone for donuts?
PostPosted: 13:22 - 04 Jan 2005    Post subject: Steering Dampers Reply with quote
Bit of advice needed if poss.
Looking at ordering a steering damper this week for around £200, should get it at trade price though. However, which one should I go for? Toby or Sprint? any suggestions for a Hornet 600?
Rob W
PostPosted: 13:25 - 04 Jan 2005    Post subject: Reply with quote
Do you really need one on a Hornet 6?
Jon
Anyone for donuts?
PostPosted: 13:30 - 04 Jan 2005    Post subject: Reply with quote
erm... yes
Rob W
PostPosted: 13:32 - 04 Jan 2005    Post subject: Reply with quote
Why exactly? Never heard of Hornet 6's being prone to tank-slappers or having dodgy handling.
Jon
Anyone for donuts?
PostPosted: 14:32 - 04 Jan 2005    Post subject: Reply with quote
I'd much rather spend the money on some decent tyres but I tend to get one too many tank slaps when I go out on my Hornet, probably to do with me only weighing a kilo Laughing Plus it's pretty essential on the track when you tend to be riding pretty hard.
Fortuna
PostPosted: 19:15 - 04 Jan 2005    Post subject: Reply with quote
I only have Ohlins, but they are worth it on certain bikes. Namely tuned R1's Twisted Evil
streetfighter
PostPosted: 19:33 - 04 Jan 2005    Post subject: Reply with quote
Both dampers are good, it's a case of aesthetics.
They all do pretty much the same thing but some look better than others.
I'd pay the extra and get an Ohlins damper mounted on the top yolk. Wink
Jon
Anyone for donuts?
PostPosted: 19:54 - 04 Jan 2005    Post subject: Reply with quote
Didn't realise you could get an Ohlins steering damper mounted on the yolks for a Hornet?
Would like to but way too much Pound Coin Pound Coin Pound Coin
Toby
High quality dampers and fitting kits manufactured by M.Toby one of Europers leading Grand Prix suppliers. All dampers have 25 adjustments, PTFE anti dust seals and come with a 12 month warranty.
Sprint
Sprints long term development programme has enabled them to manufacture tried and tested steering dampers with many unique features that combine high tech performance with reliability and affordability.
* 13 position - click adjustable.
* Unique low friction seals to prevent heat seizure.
* O'ring controlled heat expansion device.
* Fully rebuildable.
Available in Silver, Black, Gold, Blue, Titanium, Purple or Red.
The Sprint is 20 quid more though Confused
Bendy
Mrs Sensible
PostPosted: 20:02 - 04 Jan 2005    Post subject: Reply with quote
RiDE mag recommended the Arrow damper. The Sprint scored the most points, but they said the adjustment doesn't make much difference until you get to the extreme end of the range.
They didn't test the Toby though - scores went:
Sprint - 47
Extreme Tech - 47
Arrow - 45
Matris M3 - 41
Ohlins - 39
Matris M4 - 38
Hyperpro - 34
Bitubo - 30
jonboy
PostPosted: 20:45 - 04 Jan 2005    Post subject: Reply with quote
I have to say I thought that damper test was the worst review Ride has ever done..Things like initial 'stiction' actually being a good thing, and testing the resistance at speeds of approximately one lock to lock every 5-10 seconds, led to me thinking the manufacturer's comments at the end were rather restrained.
I've got a sprint damper cos it was going cheap, but there's little difference in price being sprint and ohlins and most others, so don't rule the ohlins out.
Korn
Admin
PostPosted: 21:00 - 04 Jan 2005    Post subject: Reply with quote
That's very much bollocks, don't listen to it. Sounds like this article was freelanced out to a reject from Good Housekeeping magazine Thumbs Down
3516 Miles, 11 Countries
tintin
PostPosted: 12:49 - 05 Jan 2005    Post subject: Reply with quote
Save your money, you really don't need a steering damper on your bike. I've had 3 R6's and never needed a damper on any of them, even for track days.
Spend the money on getting the suspension set up properly for your riding style and weight and that will solve any problems you might be having.
The older I get the better I was
jay12329
Dr. Evil
PostPosted: 15:50 - 05 Jan 2005    Post subject: Reply with quote
I'm in two minds about fitting a dampner to my hornet 6. I've had a few moments mainly on the track where the front has had a slightly scary wobble.
On the other hand after talking to some people from the nest it seams that a dampner causes more problems than it solves for road rideing on the Hooner.
HTH
J
jay12329
Dr. Evil
PostPosted: 15:53 - 05 Jan 2005    Post subject: Reply with quote
On another note the money might be better spent on a fork re-valve (~£250.) But this means sending your forks away so you will be off the road, i think this normally takes around 2 weeks and well worth it if you are going to enter the hornet cup.
J
Jon
Anyone for donuts?
PostPosted: 17:19 - 05 Jan 2005    Post subject: Reply with quote
Yep, spoken to a fair few people now and it looks like it could be to do with the suspension set-up. Getting my braided lines fitted on Sat so will see what the mechanics say about the suspension Thumbs Up
Jay - have you got the Hel lines yet? £63 all in on ebay. Were £55 a week ago! Book Silverstone aswell, think I'll also be in novice.
stormwarning
PostPosted: 22:29 - 05 Jan 2005    Post subject: Reply with quote
HTH
J
A damper is a vital bit of kit on the track, you're doing things you'll never do on the road. There are so many forces acting on the front end that a damper really is important.
On the road just wind it right off.
Why not go the cheaper route and get new "progressive" springs for the forks and slightly heavier oil?
jay12329
Dr. Evil
PostPosted: 22:31 - 05 Jan 2005    Post subject: Reply with quote
Yes I have hel lines, only fitter the rear at the moment. Might do the fronts tomorrow. Dead easy job to do. For suspention i'm just upgrading my forksprings to ohlins to see what that does before i go the whole hog of re valving. another reasonably simple job when i get round to fitting them.
I'm still a bit unsure of silverstone, no point doing it if its wet cus i'll jsut be paranoid.
J
Dr Nick
PostPosted: 00:30 - 06 Jan 2005    Post subject: Reply with quote
Yes u do need a damper on a Hornet 6, i get little moment son mine all the time, especially from when comin down from wheelies, which is quite a lot now its downgeared. Think u can get Sprint dampers and bracket for £180, or jus get the bracket fromt sprint for £80 and get an ohlins damper?
If you get one tell me how well it works etc, might buy one myself.
ta
is that it
jay12329
Dr. Evil
PostPosted: 13:30 - 06 Jan 2005    Post subject: Reply with quote
I've been looking on e-bay and found the two options,
Yoke Mounted;
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=10460&item=7945976287&rd=1
And Engine mounted;
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=25623&item=7944763983&rd=1
When changing the fork springs stick with 10W oil. Use of anything heaver gives the impresion of extra dampning but its just slower moving, this increases the presre on the valves and cause excessive ware.
HTH
J
Korn
Admin
PostPosted: 13:35 - 06 Jan 2005    Post subject: Reply with quote
jay12329 wrote:
Those Matris jobbies are very good, as well as being adjustable they are speed sensitive so in theory don't offer any resistance to slow "I'm parking my bike" type movement - only proper head shakes.
Jon
Anyone for donuts?
PostPosted: 15:12 - 06 Jan 2005    Post subject: Reply with quote
jay12329 wrote:
That yoke mounted one went on ebay for £142 from the same guy... my computer froze in the last 30seconds Brick Wall otherwise I would've had it for £145 ish!
Don't really want to spend £205 on one though even if it is that good.. may bid but no doubt shit loads of other people will aswell.
The last post was made 21 years, 247 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 111.34 Kb
