2014 CBR125R - judder / miss fire / hesitation when riding
djrikki
PostPosted: 09:53 - 18 Mar 2014    Post subject: 2014 CBR125R - judder / miss fire / hesitation when riding Reply with quote
Greetings, got a slight problem with my bike and was wondering if anyone had any thoughts on it.
It's a 2014 Honda CBR125R and Ive had it since mid January but only managed to put 400 miles on due to weather etc.
Everythings been great, no hiccups or anything until last night when after about 10 minutes of riding and going up a fairly decent hill on a dual carriageway the bike felt like it was lurching. Being inexperienced and at about 60mph on a 125 my arse was going 5p 10p but I pulled off and into an industrial estate to see if I could spot anything major like the chain being loose or tyre problem. Everything checked out fine and the bike was idling fine too.
Took it down the hill and all was good but on giving it a 2nd go up the hill it did the lurching thing once more - I was a mental note of speed, gear etc and it was again about the 55mpg mark, 5th gear at 8000 rpm with 3/4 throttle. I thought maybe it was some rough road surface and I was being over cautious but decided to head home anyway just in case. On the way back I went up another incline (East kilbride expressway from the Raith, off the M74 for anyone that knows the area) and gave it beans through the gear, backed off, put it in 5th at low revs to put it under load, partial throttle, WOT, up and down the gears and it was fine. Got a flat bit of road and opened it up all the way through to 65 slowed down for a roundabout, went round and started coming back the other way and when coming up through 4th and 5th it started lurching again. This was on completely flat road, wind at my back and a new road surface so I knew it was definitely a problem.
After that she was ok again but I just went home and parked up only stopping for fuel. The gauge read a 1/4 of a tank but I thought I might as well (even though Id been leaning it, going round bends and it didnt stutter). Managed to put £12 worth of liquid gold in so dont think she was running dry there.
This morning before work checked the oil and having been left on the side stand the dipstick was bone dry. Tilted it upright for a minute and re-read the stick and it was halfway up.
The chain had about an inch and half to 2 inches of movement up and down (not that I really know if thats normal on the 125) and there were no funny sounds from the exhaust or engine, back firing, ECU lights etc.
Just wondering if anyone had any ideas. Thanks Smile
CyrilSwan
PostPosted: 10:04 - 18 Mar 2014    Post subject: Reply with quote
The earlier CBF125's had a problem with their fuel pump that caused this same issue in hot weather. Perhaps it could be a similar issue?
It happened to me after about 30 mins of riding in hot weather. They replaced the fuel pump with one of a higher psi. Quite a common problem on the earlier models of the CBF. But seeing as they have fixed it on the CBF, you would have thought that new CBR's would not have the issue.
Current: Honda 2015 MSX125.
Previous: Honda 2012 CBF125.
PostPosted: 10:19 - 18 Mar 2014    Post subject: Reply with quote
You want about an inch of movement, I'd also be calling the dealers just to let them know before shit goes down. You know how reliable Honda are at warranty stuff....
Razz
Codemonkey
PostPosted: 11:25 - 18 Mar 2014    Post subject: Reply with quote
I wouldn't be taking a bike that's only done 400 miles to those revs. Did the book not suggest running it in a bit more gently ?
I doubt that's the problem though, but you might want to read the manual for any clauses about keeping it below certain revs until after the 1st service cos chances are the ECU will be recording the amount of time in each rev range and if you're ragging the thing, dealers could use that as evidence to avoid warranty work in the event of later engine problems.
Test Passed 10/05/2011 Current bike: XJ6-N
PostPosted: 11:39 - 18 Mar 2014    Post subject: Reply with quote
Unsure why you'd not trust a Honda to rev to the redline from 1 mile. The run in period is "guidelines" and I wouldn't listen to a single thing the manual says regarding it Wink
djrikki
PostPosted: 11:41 - 18 Mar 2014    Post subject: Reply with quote
I've read the manual and it didnt say anything about running in (from what I could see which was odd as the CBF did) so for the first 200 miles it was fairly gentle, no labouring in any gear, nowhere near the 13,000rpm redline - changing around the 8 mark. Now Im changing at 9 to give it a bit more push into the next gear as it is only a 125.
PostPosted: 11:44 - 18 Mar 2014    Post subject: Reply with quote
Give it full beans, change the oil (I'd probably have changed it 3 times by now Shocked ) and forget about it.
But no, I'd get it checked ideally at Victor Devine, you need good quality service from a reputable company.
Irn-Bru
PostPosted: 11:47 - 18 Mar 2014    Post subject: Reply with quote
You probably paid a fortune for it so get it returned to the dealers and make them fix it Thumbs Up
djrikki
PostPosted: 12:19 - 18 Mar 2014    Post subject: Reply with quote
So you're saying its metallurgy related?
PostPosted: 12:22 - 18 Mar 2014    Post subject: Reply with quote
Possibly, high degree of flux on the intake.
nowhere.elysium
The Pork Lord
PostPosted: 12:34 - 18 Mar 2014    Post subject: Reply with quote
I've had to deal with this on a CBF125. Basically, it's down to the fact that it's got a totally pony charging system. Make sure that your battery is at full charge, and that the bike's not hot. If it behaves itself for a while, and degrades after a while (50-100 miles or a week or so, whichever happens first) then you've got some electrical diagnostics ahead of you.
Short answer: take it back, tell them what's happening. Don't offer any suggestions as to what's causing it, let them sort it out.
PostPosted: 12:37 - 18 Mar 2014    Post subject: Reply with quote
OK, calm down, we all know the history here. Razz
There are two options:
#1 Electrics. It was relatively dry yesterday, although there's always a rain cloud looming over EK as you come up that road. Whistle That could be effecting either the spark system (ECU, CDI, coil, plug) or the fuel injector.
#2 Fuelling. Not enough fuel getting to the injector, or a clogged line or jet.
Trouble is, it's not that easy to distinguish them on a FI vehicle. With a carb, you tend to get a loss of power as the fuel runs out, before stuttering kicks in. With FI, the injector will either squirt or not squirt, so it just misses, the same as with an electrical fault.
OH MY GOD, I'VE BECOME TEFLON MIKE! Shocked
The tl;dr version is that could be anything (list is not exclusive). I'm not aware of specific problems with the new CBR (unlike with the very common fuel pump problem on the CBF) so it would just be guessing.
I would:
#1 Put injector cleaner in the tank. It's probably not that, and it probably won't help, but I'd do it anyway.
#2 Seat off and dose any exposed electrics with WD-40 (its one genuinely proper use).
#3 Check any electrical connectors for security. Particularly the injector, coil and CDI if you can find and get to them easily. Check the voltage across the battery terminals with the engine on and off.
#4 Try not to worry. Most bikes act up every so often. It could be cosmic rays.
#5 If it re-occurs, take it to Victor Devine for a thorough investigation under warranty sell it, do your DAS tests and get on a bike that wasn't made for the bowl-of-rice-a-day market. Wink
If it starts acting up reliably, I can have a look, but I'd just be doing steps #1 - #3 above, then sucking my teeth and saying "Well, you buy one of those Thai-wanese bikes made in Hongdonistan, what do you expect, mate?"
CaNsA
PostPosted: 12:37 - 18 Mar 2014    Post subject: Re: 2014 CBR125R - judder / miss fire / hesitation when ridi Reply with quote
a 2nd go up the hill it did the lurching thing once more - I was a mental note of speed, gear etc and it was again about the 55mph mark, 5th gear at 8000 rpm with 3/4 throttle.
I would say wrong gear for the incline.
My 125 would do the same thing up some steep hills so i had to drop it down into 4th.
djrikki
PostPosted: 12:48 - 18 Mar 2014    Post subject: Re: 2014 CBR125R - judder / miss fire / hesitation when ridi Reply with quote
You missed the end bit fella ...
"coming back the other way and when coming up through 4th and 5th it started lurching again. This was on completely flat road, wind at my back and a new road surface so I knew it was definitely a problem. "
Tried all variations of throttle angle, gearing, speed etc Smile
djrikki
PostPosted: 12:48 - 18 Mar 2014    Post subject: Reply with quote
Will check that - cheers!
djrikki
PostPosted: 12:50 - 18 Mar 2014    Post subject: Reply with quote
I would:
It was the bogs brae up towards A80 that it started going funny at the start, then it was 100% up the EK expressway only having a spaz out when it went round the roundabout at KFC/BP/Ford at the end of the Kingsway (or it is Queensway) and coming back up towards the centre - got to past the BP and lurched around a bit in the proper gear.
Will give it a dose of WD40 and check things out properly - just wanted a few pointers on what to do - and got em from this thread Smile
Cheers!
thepuma
PostPosted: 13:25 - 18 Mar 2014    Post subject: Reply with quote
Have you taken it for its 600 mile initial service/check?
if so...do that and mention it when you book it in.
No point summizing on here...get it looked at by Honda.
765 RS
thepuma
PostPosted: 13:27 - 18 Mar 2014    Post subject: Reply with quote
765 RS
GeorgeB.
PostPosted: 13:44 - 18 Mar 2014    Post subject: Reply with quote
Here we go again Twisted Evil Pass the popcorn
Current: '99 Fazer 600 | '99 Range Rover P38 4.6 HSE
Previous: Keeway TX125 | CBF 125 | CB400SF Project Big One
CBT 04/12/12 | Theory 03/12/13 | MOD 1 06/01/14 | MOD 2 13/01/14
djrikki
PostPosted: 14:13 - 18 Mar 2014    Post subject: Reply with quote
Let's hope not eh Laughing
djrikki
PostPosted: 14:15 - 18 Mar 2014    Post subject: Reply with quote
Nah only up to 400 - will give them a buzz though and mention it and see about getting it booked in for the service at the same time. Depending on house move / car sale still looking at shifting it in a few months time so long as it lasts till then Im good Laughing
0l0dom0l0
PostPosted: 14:25 - 18 Mar 2014    Post subject: Reply with quote
Just take it to the dealer and get them to look at it under warranty Thumbs Up
PostPosted: 14:52 - 18 Mar 2014    Post subject: Reply with quote
The nearest dealer worth the name is quite some distance away, sadly, and not that easily accessible by non-motorway routes.
Got breakdown cover?
djrikki
PostPosted: 16:42 - 18 Mar 2014    Post subject: Reply with quote
Yup Honda assistance included.
PostPosted: 18:16 - 18 Mar 2014    Post subject: Reply with quote
Then that which does not wreck it makes it stronger.
The last post was made 12 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.15 - MySQL Queries: 13 - Page Size: 133.91 Kb
