Before I take the new bike in, what causes this?
Bonneville63
PostPosted: 22:00 - 19 Mar 2014    Post subject: Before I take the new bike in, what causes this? Reply with quote
The bike is about 6 months old and has always had this problem on and off. It's so inconsistent that I told Triumph I'd like to try get to the bottom of it myself before I have to give it to them for a couple of days. I need it for work so I've tried to hold on to it for as long as possible.
I finally managed to film the problem, it's difficult to explain to someone.
So before I book myself in to Triumph (the bike still has a 2 year warranty) - I'd like to see if I can diagnose and fix it myself with your help.
(To start it you need to hold the clutch in, and make sure it's in neutral - the problem occurs with the side stand up, and with the side stand down)
Any ideas?
https://www.youtube.com/watch?v=aTfHmJFop6M&feature=youtu.be
Thank you.
https://www.youtube.com/user/TheBonneville63/videos
stuartt
PostPosted: 22:04 - 19 Mar 2014    Post subject: Reply with quote
check for dampness on the starter relay
stuartt
PostPosted: 22:06 - 19 Mar 2014    Post subject: Reply with quote
has it ever cut out while you have been riding it ?
PostPosted: 22:08 - 19 Mar 2014    Post subject: Reply with quote
So you hold your finger on the button, and the starter just cuts out?
If so your fault lies with the starter circuit, or (more likely) there's a dodgey connection in the switchgear.
yen_powell
PostPosted: 22:11 - 19 Mar 2014    Post subject: Reply with quote
It might just be me but you don't actually hold the starter button till it starts, you just press it and immediately let go. The time it started in the video was when you held the starter button in for longer than a quarter of a second.
XT1200Z and a DR350 in bits
PostPosted: 22:13 - 19 Mar 2014    Post subject: Reply with quote
That's how it looked to me, hence I wondered if the start was cutting.
Bonneville63
PostPosted: 22:15 - 19 Mar 2014    Post subject: Reply with quote
That's because it cuts out and if I held it down it wouldn't be doing anything. Almost as though an anti theft or safety mechanism is cutting in.
Bonneville63
PostPosted: 22:16 - 19 Mar 2014    Post subject: Reply with quote
Correct. I can hold my finger down as long as I like but it'll cut out and won't continue starting.
Bonneville63
PostPosted: 22:17 - 19 Mar 2014    Post subject: Reply with quote
Fortunately no. The bike has been flawless while riding. It's just this little hiccup which is causing a slight headache.
PostPosted: 22:19 - 19 Mar 2014    Post subject: Reply with quote
Take it in, Friday afternoon switchgear/starter. Thumbs Up
stuartt
PostPosted: 22:20 - 19 Mar 2014    Post subject: Reply with quote
thats what was up with my rocket , except it cut out on the move to , £72 to dry the starter relay
Bonneville63
PostPosted: 22:22 - 19 Mar 2014    Post subject: Reply with quote
What did they end up replacing?
mentalboy
PostPosted: 22:24 - 19 Mar 2014    Post subject: Reply with quote
Probably the best idea if it's still under warranty terms. Otherwise I'd give it a squirt of WD-40 (or similar) into the switchgear unit - and then take it apart to clean it properly if that made a positive difference.
Make mine a Corona.
stuartt
PostPosted: 22:28 - 19 Mar 2014    Post subject: Reply with quote
nothing , they dryed the connection !
PostPosted: 22:29 - 19 Mar 2014    Post subject: Reply with quote
You paid them £72 to sit the switchgear on a radiator. They saw you coming! Laughing
Bonneville63
PostPosted: 22:31 - 19 Mar 2014    Post subject: Reply with quote
Cheers for the replies. I'll take a closer look at the switchgear tomorrow afternoon. In my naivety I was thinking it could only be an internal problem.
Thanks.
stuartt
PostPosted: 22:39 - 19 Mar 2014    Post subject: Reply with quote
i made £75 that day Crying or Very sad
i really couldn't be arsed saying anything .
what pissed me of was a few months before when they fitted a new wiring loom & ecu , i was told they used loads of electrical grease on every connection to keep dampness out & stop the wires from rotting .
i checked a number of connections after the work was done & there was loads of grease on the ecu & other connections that i checked , this was about 4 months ago .
the bike was about 6 weeks out of warranty when it broke down again .
the engine cutting out while overtaking was the final straw for me ! its on autotrader now .
The last post was made 12 years, 219 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 93.18 Kb
