| mudcow007 |
 mudcow007 World Chat Champion
| SQL |
 SQL World Chat Champion
| map |
 map Mr Calendar
 Posted: 16:18 - 20 Mar 2014 Post subject: |
After a similar episode I went and got 1/4" hex socket set.
https://washford.scene7.com/is/image/Washford/168328?$PDP_MAIN$
yes, they were from Halfords. Only place open on the Sunday I was working. I'm sure other places sell them, probably cheaper.
Once you manage to remove remember before reassembly use of copper grease is your friend for next time.
Best of luck  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| SQL |
| mudcow007 |
 Posted: 16:55 - 20 Mar 2014 Post subject: |
im sure i have got some of them hex socket thingies somewhere...
cheers will try an attack it tonight
| c_dug |
 c_dug Super Spammer
 Posted: 19:23 - 20 Mar 2014 Post subject: |
If you're trying to split the caliper because you can't get the pins out, don't bother. Drill the back of the pins and knock them out with a punch. Before you put them back in stick each one in your battery drill and spin them up and use a bit of emery cloth to clean the rust off them. Re-fit them with grease, not copaslip. ____________________ a.k.a 'Geri'
| mudcow007 |
 Posted: 19:50 - 20 Mar 2014 Post subject: |
bit of an update
i left the caliper with one of our maintenance guys who has demolished the head of the bolt- he was only trying though
he said he knows someone at an engineers who will be able to get it out - i can see it being drilled an retapped....
Pete - its to clean the pistons up, i had to dremel/ cut the pins out as they were beyond stuck
cheers |
 Posted: 19:52 - 20 Mar 2014 Post subject: |
Pistons will come out without splitting the caliper. ____________________ a.k.a 'Geri'
| mudcow007 |
| SQL |
 Posted: 20:59 - 20 Mar 2014 Post subject: |
Wrap a strip of cloth around a piston and give it a good squirt of wd40. Use the cloth like a shoe-shine buffer and clean the piston up. Get your old pads and jamb them in between the pistons. Lever between the pads to shove one piston or the other back all the way. Once you have one piston all the way home, put the old pad up against it and make a couple of wedges to fit either side to hold it in. Now blow the opposite piston out with compressed air, clean the piston, seal, seal groove up and re-assemble. Shift the pad you used to hold back the first piston to the other side and perform the same procedure for cleaning up the second piston. ____________________ a.k.a 'Geri'
| mudcow007 |
| mudcow007 |
| gavcarter |
 gavcarter Could Be A Chat Bot
The last post was made 12 years, 202 days ago. Instead of replying here, would creating a new thread be more useful? |
