Headlamp Aim
Jammy-G This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 18:36 - 04 Jan 2005    Post subject: Reply with quote
There should be an obvious pattern when you shine it on a wall. I would make sure it is on level ground and a decent distance from the wall, and put some tap at headlight height where you want it to aim on the wall. This way you can set high beam to be pretty much straight on.
Dip will naturally be below that.
Gazdaman
I did a trackday!!!
PostPosted: 22:11 - 04 Jan 2005    Post subject: Reply with quote
IIRC the beam has to be level with the height of the headlight at a distance of 25m.
I read that somewhere, but when I think about it, that seems very high.
maybe it's got to be at ground level 25m away.
I'm not helping...
Gaz
McJamweasel
BCF Junkie
PostPosted: 22:46 - 04 Jan 2005    Post subject: Reply with quote
25m is a VERY long way - how many workshops do you know of that are 25m long?
2.5m, maybe.
Gazdaman
I did a trackday!!!
PostPosted: 01:11 - 05 Jan 2005    Post subject: Reply with quote
2.5m, maybe.
Good point, my info was taken from a post on these forums, I could have easily overlooked a decimal point.
Just be aware, there are some kind of criteria for headlight aim..
Gaz
Rob W
PostPosted: 01:14 - 05 Jan 2005    Post subject: Reply with quote
Have you got a manual for the bike? In the manual I had for my bike it had a section showing you how to adjust the light's and what not.
Dom_
Points Mean Prizes
PostPosted: 01:25 - 05 Jan 2005    Post subject: Reply with quote
I thought it was 20m away, but 25m don't seem bad.
If the distance was 2.5m then your headlight must be really out of place if it doesn't shine straight on.
Finglonga
PostPosted: 16:13 - 05 Jan 2005    Post subject: Reply with quote
Lookie Here.... https://www.webmaster10.com/ldr/headlight_aiming.html Wink
Andy Sez....
F.Y.Y.F.F.
The last post was made 21 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 57.39 Kb
