| stevelup |
 stevelup Renault 5 Driver
| wristjob |
 wristjob World Chat Champion
| qarka |
 qarka Spanner Monkey
 Posted: 21:12 - 20 Mar 2014 Post subject: |
Delboy recommends setting your suspension right in the middle of its range for the best compromise.
Personally I reckon unless you're a trackday hero you wont notice any adjustments until you really fuck it up. But then I leave mine alone, and just try and dodge the potholes.  ____________________ Previous - Sinnis Apache - Honda Bros 400 - Yamaha SR500 - Honda Transalp - Kawasaki ZX-7R - Honda CB-1 - Honda 929 Fireblade - Honda NTV650 [b]Current[\b] Honda CB500 |
| stevelup |
| fozzym |
 fozzym Brolly Dolly
 Posted: 22:32 - 20 Mar 2014 Post subject: |
If you look online all the suspension guys (pros) will tell you that you should have your suspension set up for you as an individual. Which is the correct advice and something you can do yourself.
Contrary to belief bikes are not set up to suit a range of riders as that is not possible, they are set up to suit the average rider (about 10stone in Japan) and what the particular manufacturer thinks is a good set up hence some bikes come rock hard and some more plush.
It's not hard to set your bike up yourself, you and a mate can do it in 45mins easily. Use a step by step guide found on youtube. Once you've done it and understand what does what then you can make a change to see if it improves what you want. Just make a note of your setting before making a change so it is easy to change back.
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
| ficedula |
 ficedula Scooby Slapper
| stevelup |
| ficedula |
 Posted: 23:37 - 20 Mar 2014 Post subject: |
Ah, fair enough - that's particularly annoying then
Unless the implication is that "this is important therefore take it to ZE DEALER". ____________________ Bike history: YBR125 -> XJ600 |
| biggeeman |
 biggeeman Scooby Slapper
| evoboy |
 evoboy World Chat Champion
| Matt B |
 Matt B World Chat Champion
 Posted: 12:07 - 21 Mar 2014 Post subject: |
If you want to start setting it up the most important, and probably easiest thing to start with is the rear preload.
Read this: https://www.gostar-racing.com/club/motorcycle_suspension_set-up.htm
Then get your rear preload set so that you have 30-40mm of rider sag.
I don't think your bike had adjustable front suspension does it? ____________________ stinkwheel: He had an animated .gif of a cat performing fellatio. It's not socially acceptable. It can have real life adverse effects on other people. |
| stevelup |
| MarJay |
 MarJay But it's British!
 Posted: 12:16 - 21 Mar 2014 Post subject: |
As usual in a suspension setup thread, there is some good advice here and some nonsense.
The suspension on a motorcycle must be set up in the following way:
1.) Correct Static (or rider) sag
2.) Rebound damping
3.) Compression damping
The static sag generally needs to be set so that when the rider is sitting on the bike fully kitted the top third of the suspension travel is used up. There are rules of thumb to help set the static sag, or you can set rider sag with the aid of a few mates.
Rebound damping can be set roughly by pushing down on the bike and then standing up quickly so there is no load on the bike. The bike should follow you at a similar pace, not really faster or slower than you can move.
Compression damping is then generally adjusted by riding the bike and making compromises between ride quality and cornering. It is possible to make a bike ride nicely but it feel wallowy in corners. It's also possible to make a bike feel tight in corners but kick you out of the seat over bumps. A compromise between the two is what you want. I do have a document that explains this in more detail somewhere, and I thought it was stored as an attachment on the forum but it appears to have been lost. I'll try to dig it out when I'm back at my home PC (Stupid logmein is no longer free ).
Oh yeah, and I almost forgot. It's no good doing ANY Of this until you have a decent set of tyres with correct manufacturer recommended pressures and good quality bearings, decent fork oil, an unshagged rear shock and smooth linkages. If the bike is not in tip top condition when you start setting it up, it's never going to be right. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| fozzym |
 fozzym Brolly Dolly
 Posted: 12:40 - 21 Mar 2014 Post subject: |
I second the above.
The last post was made 12 years, 177 days ago. Instead of replying here, would creating a new thread be more useful? |
