Ram air NSR?
Noggin
PostPosted: 22:30 - 04 Jan 2005    Post subject: Ram air NSR? Reply with quote
Those pipes on the front of the bike do nothing as far as I'm aware, they're there for just cosmetic reasons. SO, if I could get a new cover for the airbox (i.e. vacuum form one) and continued the pipesso they went into the top of the airbox, would it alter the performance in any way? Faster preferably!
Craig G(Noggin)
Current bike: kawasaki zx12r 2002
Track bike: yamaha r6 1998
Old Bike: honda NSR 125 1998
NSR125-Kid-UK
Attention Whore
PostPosted: 22:35 - 04 Jan 2005    Post subject: Reply with quote
It would afaik make your fuel/air mixture incredibly lean.
Without adjusting to compensate, I imagine you would run the risk of damaging your engine.
https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman
Noggin
PostPosted: 22:49 - 04 Jan 2005    Post subject: Reply with quote
Ah, well it was worth the idea. But if I changed the petrol air mix? Would that make any improvement?
Craig G(Noggin)
McJamweasel
BCF Junkie
PostPosted: 23:31 - 04 Jan 2005    Post subject: Reply with quote
I dount it.
Ram air doesnt come into effect until over 100mph - and then you only get around 10% afaik - so that would be 2bhp on an nsr at over 100mph.
PostPosted: 00:04 - 05 Jan 2005    Post subject: Reply with quote
Adjustment would not make much difference. A carb works on the basis that the air going through the carb goes quickly and thus is lower pressure than the air pressure in the carb float bowl.
If you pressurise the airbox then the you pressurise the carb and so it will not work. The only way to get it to work is to vent the carb float bowl with a pipe to the pressurised airbox.
PostPosted: 00:05 - 05 Jan 2005    Post subject: Reply with quote
Also, ram air systems are designed to operate well at speeds over the maximum of the NSR, so I doubt that will help much.
stevo123
PostPosted: 18:52 - 07 Jan 2005    Post subject: Reply with quote
Just for "something different" value you could route cold air from the fron the the intake area to give it cold air. Will help keep things more consistant jetting wise I would of thought
The last post was made 21 years, 272 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 52.17 Kb
