Rotavator cut out!
mic
PostPosted: 09:22 - 22 Mar 2014    Post subject: Rotavator cut out! Reply with quote
Bought an old rotavator. Seller showed it working and have a demo. Said had changed the points and gapped accordingly and it runs fine.
First time I use it yesterday and it took a few mins to start, looking for the right amount of choke (manual). It ran for about 30 seconds then died. Haven't been able to start it since! I'm assuming something simple needs doing (wet spark plug maybe?) as there's definanty a spark to that and I've seen it running before!
It's a basic engine it can't be that hard to sort out?!
zzr600
doggone
PostPosted: 10:46 - 22 Mar 2014    Post subject: Reply with quote
If it's a briggs and stratton it will probably be cheaper to get another one.
The basic things that can go wrong with these small engines - but are easily fixed - are needing a new plug or new carb diaphragm.
mic
PostPosted: 10:51 - 22 Mar 2014    Post subject: Reply with quote
Yea it's a Briggs and Stratton 3hp. Will take the plug out tonight if I can find the takerouter tool.
zzr600
PostPosted: 12:41 - 22 Mar 2014    Post subject: Reply with quote
Is it getting fuel?
Is it getting fresh fuel?
mic
PostPosted: 12:46 - 22 Mar 2014    Post subject: Reply with quote
stinkwheel wrote:
Is it getting fuel?
Yes
Yes
zzr600
smegballs
PostPosted: 14:21 - 22 Mar 2014    Post subject: Reply with quote
I fixed a briggs rotavator in portugal last summer, as said the carb diaphragms are a weak point on them. The rubber stretches/perishes with age and provides weak/intermittent fuel pumping which is a real bugger to diagnose.
The motor I was working on would sometimes fire, sometimes not, and never ran for more than a few seconds whenever it fired up. A £3 piece of rubber and it fired up after a few pulls.
It only cost about a fiver delivered to get the diaphragm sent from a UK ebay seller to the farm I was working at in portugal. As the part is so cheap, if this rotorvator is an old-ish one it is probably worth changing just to be on the safe side, and to simplify potential problems.
Islander
PostPosted: 19:34 - 22 Mar 2014    Post subject: Reply with quote
You can buy carb service kits for B&S engines - not expensive to service and dead simple.
Have you tried squirting a load of easy start into the air filter intake? My mower can be a bugger to start sometimes (B&S quantum engine) and I find that with East Start it'll go first pull whereas without I'll be at it for ages. Definitely worth a shot IMO. Thumbs Up
The last post was made 12 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 51.95 Kb
