| MattWadz |
 MattWadz Trackday Trickster
 Posted: 00:36 - 22 Mar 2014 Post subject: Carb 30mm from 24mm in a 125 2T |
Okay, looking through my spares earlier found a what i believe to be 30mm Flatside Mikuni carb from possibly a KMX/KX.
Took the float bowl off to find a 210 Main jet :S, the rest of it seems okay, now i want to put this carb onto my MTX, MTX currently has a 24mm carb and a 120 main jet, so i put the 120 main jet in place of the 210 on the flatside and stuck it on the bike, no start situation for some reason, is the 120 too small for that carb to function? would the MTX run with a 210 in it? i have a selection of jets in my other house from about 130-200 which will fit the flatside.
So would the MTX run with the 30mm carb and 210 main jet (temporarily)
also the idle screw seems to be completely missing from the flatside, would this cause it not to run or would it just make it impossible to idle off of carb settings?
the MTX does have the snorkel removed from the airbox allowing a bit more air and it does have a performance expansion chamber and silencer.
Any ideas?
Thanks
 ____________________ Pitbike x2, Mini Moto x4, China Quad, 02' Suzuki AP50 > 03' MBK Nitro > 86' Suzuki GP100 > 02' Yamaha Jog R > 57' Honda Lead 100 > 95' Piaggio ZIP Rst 50 > 51' Suzuki TS50x > 83' Honda CB125TDE Twin > 51' Yamaha Aerox > 98' Kawasaki KX60 > 89' Yamaha DT50MX > 80's Honda QR50 > 05' CG clone > 125cc China Pitbike > 91' Honda MTX125 RW-L > 09' Peugeot Speedfight 2 LC LR > Lucky MX 140cc > Apache Tomahawk 50 Quad (current = 2010 Yamaha WR125R |
| MattWadz |
 Posted: 00:39 - 22 Mar 2014 Post subject: |
https://www.1977mopeds.com/media/catalog/product/5/0/50095-0.jpg
Carb looks like this ____________________ Pitbike x2, Mini Moto x4, China Quad, 02' Suzuki AP50 > 03' MBK Nitro > 86' Suzuki GP100 > 02' Yamaha Jog R > 57' Honda Lead 100 > 95' Piaggio ZIP Rst 50 > 51' Suzuki TS50x > 83' Honda CB125TDE Twin > 51' Yamaha Aerox > 98' Kawasaki KX60 > 89' Yamaha DT50MX > 80's Honda QR50 > 05' CG clone > 125cc China Pitbike > 91' Honda MTX125 RW-L > 09' Peugeot Speedfight 2 LC LR > Lucky MX 140cc > Apache Tomahawk 50 Quad (current = 2010 Yamaha WR125R |
| smegballs |
 smegballs World Chat Champion
| Kickstart |
 Kickstart The Oracle
 Posted: 10:56 - 22 Mar 2014 Post subject: |
Wouldn't expect the main jet to make any difference to the idling (but a major difference once you open the throttle).
I thought the MTX used a Keihin carb and not sure that the main jet size markings they use are comparable to Mikuni ones.
Is the missing screw for the idle speed or idle fueling? If the first it won't idle and will probably be a bit lean at idle. If the 2nd then probably no chance it will idle without it
| MattWadz |
 Posted: 11:01 - 22 Mar 2014 Post subject: |
i see! so keihin jets are on a different size scale to mikuni ones?
yeah i understand, im not expecting it to idle due to there being no idle adjustment screw in it, just wondering why it wouldnt start, perhaps if i stick the 210 jet back in the flatside il try and start it with that in?
Il give that a go and report back!
thanks guys!
| Kickstart |
 Posted: 11:15 - 22 Mar 2014 Post subject: |
Not sure. Think the standard sizing for jets is based on size, but think Mikuni have also used that system and also one based on flow rate (this is from memory). But think the flow is not 100% dependent on the size, so a slightly different design will flow differently (although I suspect with a reasonable range unless you are trying to fine tune the settings).
Missing idle speed screw is possibly allowing air in bypassing the idle circuit - hence lean. Try blocking the hole off (tape it up for now)
| bladerunner |
 bladerunner World Chat Champion
 - Super Spammer
| stevo as b4 |
| temeluchus |
| dangerousdave |
 dangerousdave Traffic Copper
| Kickstart |
| bladerunner |
 Posted: 23:31 - 22 Mar 2014 Post subject: |
Spot on kickstart that is how they are measured! And when you get picky....a flow bench is the best option .......and a real necessity if using cheap aftermarket jets....I've seen them 4 sizes out of stamped value!  ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
| MattWadz |
The last post was made 12 years, 212 days ago. Instead of replying here, would creating a new thread be more useful? |
