Bandit 600n front pads?!
mudcow007
PostPosted: 21:45 - 22 Mar 2014    Post subject: Bandit 600n front pads?! Reply with quote
when i bought my bike the calipers had no pads in - so i have nothing to work from...
when im fitting pads do i need clips, backing plates or anything?
also the front of the pads has a square notch that im guesing must locate in the caliper somehow, can anyone explain how it stays in place in the caliper
cheers all
PostPosted: 22:11 - 22 Mar 2014    Post subject: Reply with quote
The tab on the pad fits into the notch in the caliper, and a pin fits through the hole in the other end of the pad to secure it.
mudcow007
PostPosted: 12:43 - 23 Mar 2014    Post subject: Reply with quote
cheers Pete
I was struggling with one side (will come back to that)
when i tried the right had side the pads went in a treat, located the front tab an screwed the pin in, jobs a good
the left side (from sitting on the bike) is a no go...
https://i25.photobucket.com/albums/c81/mudcow007/20140323_112819_zps5e3b4a2d.jpg
the pad seems to be sticking out too much, but its hard up against the caliper - if that makes sense?
any ideas?!
yen_powell
PostPosted: 12:54 - 23 Mar 2014    Post subject: Reply with quote
My calipers are like that. You have to push the two parts of the caliper on the pins to make the step appear that the pads sit on. It'll be obvious when you start moving the caliper on the pins what I'm on about.
XT1200Z and a DR350 in bits
mudcow007
PostPosted: 13:31 - 23 Mar 2014    Post subject: Reply with quote
just had another go but i dont really get what you mean...(sorry)
https://i25.photobucket.com/albums/c81/mudcow007/20140323_121654_zps07d51407.jpg
PostPosted: 13:42 - 23 Mar 2014    Post subject: Reply with quote
Take the pad out and pull that bit in the middle until it pops the rubbers off. Underneath you'll find two pins that your red arrows are pointing at. They will need cleaning and greasing.
mudcow007
PostPosted: 17:25 - 23 Mar 2014    Post subject: Reply with quote
thanks chaps
i think ive sussed it, cheers
Just need to sort the binding caliper now
Karma
recman
PostPosted: 19:24 - 23 Mar 2014    Post subject: Reply with quote
Give the pistons a good scrub with hot soapy water and an old toothbrush, rinse off and dry with brake cleaner.
I've just done mine. Thumbs Up
https://www.youtube.com/watch?v=FNz00OTRLzM
Robby
Dirty Old Man
PostPosted: 20:08 - 23 Mar 2014    Post subject: Reply with quote
mudcow007 wrote:
thanks chaps
Karma
If you're going to do it right, you need to get the pistons out, carefully remove the seal in the caliper body that sat behind the pistons, and scrape out any alloy corrosion (fluffy white shit) from behind the seal.
The alloy corrodes and pushes the seal in against the piston, so the piston can't move freely.
Also worth cleaning the piston up, I tend to use a finishing pad or high-grit emery paper used very carefully.
Of course, when you're doing this work then it's also worth getting the outside of the caliper really clean, getting any corrosion out from behind shims and the like.
This is part of why I hate getting new (second hand) bikes. A simple brake pad change ends up taking all day and costing far more than just a set of pads. Do end up with sharp brakes though.
mudcow007
PostPosted: 12:34 - 24 Mar 2014    Post subject: Reply with quote
cheers boys n girls
well found out it was the left hand side caliper that is dragging
popped the pistons out, an they were pretty clean - after that i gave up (i ran outta brake cleaner)
hopefully going to attack the pesky caliper tonight
can you reuse the seals? i will clean them first an check condition etc
PostPosted: 18:02 - 24 Mar 2014    Post subject: Reply with quote
Yeah you can re-use the seals if your budget doesn't stretch to new ones. I have done it many times.
PostPosted: 19:03 - 24 Mar 2014    Post subject: Reply with quote
Just make sure that you put them back in the right way round.
mudcow007
PostPosted: 19:21 - 24 Mar 2014    Post subject: Reply with quote
seals are goosed - they look like they have leprosy
didnt realise they were only a few quid
fingers crossed they arrive soon im desperado to ride the thing now
cheers all
The last post was made 12 years, 221 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 78.23 Kb
