using washing machine waste water to water flowers
fredsredhat
PostPosted: 19:48 - 22 Mar 2014    Post subject: using washing machine waste water to water flowers Reply with quote
any gardeners on here? we're on a water meter so to keep costs down im trying to recycle as much water as possible. im thinking of a system where i attach a hose to the waste pipe of the washer through a valve system (i havent thought of this yet) so i can either let the water run down the drain as normal or divert it through the hose. the hose would run the length of the flower border with holes punched in at intervals as a kind of sprinkler. the garden runs slightly downhill, would the washer pump be upto it? would the dirty water have too many chemicals (soap) to cause a problem to the plants? we already have a water butt, but im thinking if we have a long dry summer like last yr then our raised veggie patch would take most of that??
any thoughts?
Karma
Ben90
PostPosted: 20:05 - 22 Mar 2014    Post subject: Reply with quote
Given this a read?
Washing machine water isn't ideal, especially as the new ones tend to be more water efficient leaving you with a higher concentration of detergent, you could however switch your detergent to something biodegradable but then it's a toss up between money saved reusing water and money spend on fancy detergents.
Shower and bathwater is good source as it is usually cleaner and most bathrooms are upstairs so you can use gravity to get water where you need it more easily.
Yamaha FZ6 S2
clancy
PostPosted: 21:05 - 22 Mar 2014    Post subject: Reply with quote
Get a bigger water Butt ? Or get a second one and set the first to overflow into it ?
KLX 300r
Fisty
PostPosted: 23:20 - 22 Mar 2014    Post subject: Reply with quote
No, no, no. Mate of mine went all "good life" and piped his washing machine and dishwasher to a water butt to water his garden and veg patch. EVERYTHING was dead within a month.
Just set up 3-4 water butts around the garden and that will save you money in the long term.
Fatter and faster than Fret
Fisty
PostPosted: 23:22 - 22 Mar 2014    Post subject: Reply with quote
You can do this with an infinate amount of them .
CaNsA
PostPosted: 23:30 - 22 Mar 2014    Post subject: Reply with quote
210 Litre watter butt for under £30 in aldi
https://www.aldi.co.uk/en/specialbuys/thursday-20th-march/product-detail/ps/p/210-litre-water-butt-set/
Rigga
PostPosted: 23:34 - 22 Mar 2014    Post subject: Reply with quote
But at least his garden smelt nice Thumbs Up
Current bike: Honda CBR 1100xx
Fisty
PostPosted: 23:51 - 22 Mar 2014    Post subject: Reply with quote
No he was vegetarian Wink
PostPosted: 02:13 - 23 Mar 2014    Post subject: Reply with quote
I wouldn't use the grey water on the garden, but would use it for flushing the loo.
dodsi
Dirty Carny
PostPosted: 22:12 - 23 Mar 2014    Post subject: Reply with quote
Water isn't that expensive, 1000l costs about £2 Inc wastewater charges - how much is a grey water system and how many ML can you buy for this?
Quornholio This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Hoffy
PostPosted: 01:33 - 24 Mar 2014    Post subject: Reply with quote
Mk1GSF wrote:
Not unheard of for people to modify those 1000l IBC containers to store water in. Not as pretty/normal as water butts, but much cheaper per l, if you can find someone selling them. Think Felton's in Preston was selling them for around the £50 mark, but you had to collect/move them.
Be aware of what was stored in it previously though.
My old man has 4 of those on his allotment, he swears by em.
He can get hold of em for 30 quid, can find out where if anyone is interested, pm me.
Plagued by 1980s Suzuki 2 strokes !
clancy
PostPosted: 01:53 - 24 Mar 2014    Post subject: Reply with quote
You can get IBC containers on Gumtree and ebay for £20-40 there's literally thousands for sale
KLX 300r
dydey90
PostPosted: 11:47 - 24 Mar 2014    Post subject: Reply with quote
What do you mean modify? All the ones I've seen have a tap on the bottom and a hole in the top about 4" diameter.
Not knowing much about household plumbing, would your shower/sink drains be on a different system to your washer/toilet/kitchen sink? And if they're on on the same system, is it possible to split them?
Sounds like the ideal situation is:
Fresh water --> Drinking and washing (inc shower)
Waste from drinking water and shower ---> Garden
Waste from washing machine/kitchen sink ----> toilet cistern
Am I right in thinking that some water meters only charge on what goes down the drain?
hellkat
PostPosted: 20:13 - 24 Mar 2014    Post subject: Reply with quote
I kinda like them IBC things, they look a bit space age, compared to those stupid green plastic things.
So if you knew what had previously been stored in them, you'd have to rinse them first. So ... save all the rainwater in it to wash it out before you use it ... OR ... hose it out, thereby wasting more water than you are saving?
I wouldn't use the washing machine water on the garden. I like my plants to smell of plants, not of chemical "plant-scented" flavours. Carrots tasting of Black Diamond fabric conditioner isn't the most appealing of vegetables.
ficedula
PostPosted: 21:13 - 24 Mar 2014    Post subject: Reply with quote
It's the other way around on my water meter - the meter measures the water coming into the house, that gets charged for, and then the sewer charge is based on a percentage of the incoming water.
(The assumption presumably being that most of what comes in goes into the drain, but some will be used for watering the garden / washing the car/bike and will evaporate or otherwise not go down the drain, so they assume the drain water is less than what went into the house.)
Bike history: YBR125 -> XJ600
dodsi
Dirty Carny
PostPosted: 22:31 - 24 Mar 2014    Post subject: Reply with quote
Absolutely correct, based on incoming water from the Meyer but charged (around here) 92.5% of the volume of incoming. But the wastewater will be charged at a higher rate than incoming. (This is due to the expense of removing wastewater from properties and treating it)
dydey90
PostPosted: 09:32 - 25 Mar 2014    Post subject: Reply with quote
Must be that different water boards measure in different ways then. The last time I had to pay a water bill they only had a reading for waste.
dodsi
Dirty Carny
PostPosted: 20:07 - 25 Mar 2014    Post subject: Reply with quote
You maybe have 2 water companies, one for fresh and one for waste?
The waste bill would still be based on the reading taken by the fresh water company.
There is no waste metres on houses.
totalllama82
PostPosted: 22:09 - 28 Mar 2014    Post subject: Reply with quote
Glad I live in a country where I pay a flat fee for water when I read this nonsense. I suppose you gain the fact that there isn't a torrential downpour every 5 minutes.
Gone: Haotian HT125-8 / Yamaha YZF 600R Thundercat / Kawasaki ZX9R C2
Current: Kawasaki ZZR 1400 A7F
Ariel Badger
PostPosted: 22:45 - 28 Mar 2014    Post subject: Reply with quote
I live on my own and am very glad I have a water meter.
The last post was made 12 years, 201 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.45 - MySQL Queries: 13 - Page Size: 122.22 Kb
