Old FZR 600 vs GPZ 500
koolio
PostPosted: 09:28 - 23 Mar 2014    Post subject: Old FZR 600 vs GPZ 500 Reply with quote
Normally don't do newer bikes but was thinking about a GPZ 500 as a knock around / commuter. Then I spotted an old 1991 FZR 600.
Anyone tell me about the FZR 600 (specifically that model)? Would it be suitable for town/city riding/ all around use?
https://upload.wikimedia.org/wikipedia/commons/0/0f/1991_Yamaha_FZR600.jpg
_mjs_
PostPosted: 09:46 - 23 Mar 2014    Post subject: Reply with quote
I'd take the FZR over the GPZ any day.
stonesie
PostPosted: 09:57 - 23 Mar 2014    Post subject: Reply with quote
A friend has a 93 one... It's a bugger to find rear tyres as when I last checked only Bridgestone made that size (18" wheel) but it's supposed to be relatively easy to fit a thundercat swing arm and wheel (17") other than that it seems okay, watch out for rust and general signs of abuse.
PostPosted: 10:10 - 23 Mar 2014    Post subject: Reply with quote
Downpipes rust terribly. It's probably a better bike than a GPZ500, but if it's not in as good a condition walk away.
jjdugen
PostPosted: 10:26 - 23 Mar 2014    Post subject: Reply with quote
Anything has to be better than a GPZ.
This is the engine that went on to be fitted to Thundercats and the 600 fazers, so no problem with spares. Be wary of the well known second gear fault that can afflict this engine type and that it is not the easiest to repair. Performance is respectable enough, but a ZZR600 will make it look silly.
The weird rear wheel can be easily replaced with a TDM 17'', with a little backyard re-engineering.
Downpipes will either have fallen apart or are definitely going to. Delkivik make a god set of stainless replacements for less than £200 (about £150 as I recall).
Steel frame so will fade / show rusty bits, easily re-painted. Don't pay serious money for one, but make a good budget run-around that handles and stops very well.
They do look dated but can be spruced up and modernised very easily. I still prefer the ZZR though in every respect at this level of budget biking, still one of the fastest 6's out there.
PostPosted: 11:35 - 23 Mar 2014    Post subject: Reply with quote
We have had both.
FZR gearbox can be weak, as can the cranks. First can be a problem in road use, but the cranks only tended to be an issue when raced. Clutch isn't keen on abuse. Can get very nasty and grabby. Handling is good. Brakes are pretty good but prone to seizing up (nothing like as bad as ZZR600 brakes though). Fairly easy to free off though. Build quality isn't great. Finding replacement bodywork these days isn't easy (although plenty of grp copies) - and for that model even worse as they were only sold for a couple of years (the USA got the FZR600 for far longer than we did, but they used the older style twin round lights).
GPZ is quite a bit slower and less powerful, although a lot better on fuel. Lower seat height. Worse brakes, although the sliding calipers are easier to strip down. Build quality is no better than the FZR. Bodywork easier to find 2nd hand. No major gearbox issues, although I prefer to use the FZR600 gearbox (GPZ one is nicer at very slow bimble speeds around town). The GPZ engine does tend to wear out cam chains. There will likely be a lot of free play in the rear suspension linkage (even with new bushes - there was close to 0.5mm of clearance between the steel and plastic bushes in the linkage when new).
koolio
PostPosted: 13:13 - 23 Mar 2014    Post subject: Reply with quote
This is definitely an economy bike buy. I had a CB500 already but it was so boring thought I might try the GPZ next.
So the FZR 600 is an economy sports bike?
Seems like it will be the one requiring a little more work than a GPZ?
My other option is something like an FZR 400 but can imagine it being horrific around town. I think I'll be doing 70-80% riding in London and yea fuel economy is important to me so if the FZR 600 is thirsty may just go GPZ 500.
I found this one, quite like it:
https://www.autotrader.co.uk/classified/advert/201402111718044/sort/recpriceascdefault/usedbikes/model/fzr/make/yamaha/page/1?logcode=p
PostPosted: 13:19 - 23 Mar 2014    Post subject: Reply with quote
Doubt you'll find it much different.
While the FZR should be noticeably more prompt.
What's your budget?
koolio
PostPosted: 13:23 - 23 Mar 2014    Post subject: Reply with quote
What's your budget?
Budget's not fixed but around 1k, can be more or less but would be happier with less. Heard the GPZ was a commuter with a bit more spirit, I also found the looks of the CB500 to be atrocious whereas the GPZ 500 looks even pleasing to my eye, I think thats the issue I had with the CB500 more than anything, it was just so ugly.
I would have thought the FZR 600 was more sporty being a multiple cylinder bike?
Quornholio This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
PostPosted: 13:27 - 23 Mar 2014    Post subject: Reply with quote
Won't notice much difference for the GPZ - you should with the FZR.
I'd keep an eye out for a ZX6R G/J/A model with that money.
Or, much as I dislike them - should be able to easily get an SV650 for that. While the SV650 is pretty boring, it's still a step up from a 500 twin.
PostPosted: 18:59 - 23 Mar 2014    Post subject: Reply with quote
The GPZ500s gave between 55 and 65mpg for us. The FZR600 a bit over 45mpg (note that these are not round town figures).
FZR400 is pretty similar to the 600 in quite a few ways (the 600 was basically a stretched and cheapened version of the 400).
evoboy
PostPosted: 19:06 - 23 Mar 2014    Post subject: Reply with quote
IMO, the CB500 is a better bike than the GPZ.
Engine is nicer, gearbox is also smoother, they handle far better.
For £1K you can do alot better than an old FZR though!
F/G/J model zx6r, steel frame cbr600, thundercat etc.
APT Motorcycles
andys675
PostPosted: 19:16 - 23 Mar 2014    Post subject: Reply with quote
my vote would be a 95 FZR600 foxeye
basically a thundercat without the ramair
fully adjustable front and rear suspension, when adjusted properly that bike can really embarrass later / more powerful bikes, calipers can be replaced with blue spots, I had a couple and they were seriously one of my all time favourite bikes
Major Doss
PostPosted: 21:12 - 23 Mar 2014    Post subject: Reply with quote
Pirelli Sport demon comes in 18". I am running one at the moment, grip is great but massive trade off with longevity. There is a (4" and even later 4 1/2") FZR600 with 17" rear, the prior being a popular upgrade with some Divvy6 owners. As previously mentioned, early TDM will go in ( not sure about mkII or 900) with modification.
Antisocial phucker.
PostPosted: 21:16 - 23 Mar 2014    Post subject: Reply with quote
While there is a 140/70 18 Sport Demon tyre in a V rating there isn't a matching 110/70 17 front in a decent speed rating (only H rated).
Major Doss
PostPosted: 21:27 - 23 Mar 2014    Post subject: Reply with quote
Michelin, Bridgestone, Continental? Doesn't have to be from the same manufacturer.
Antisocial phucker.
koolio
PostPosted: 21:39 - 23 Mar 2014    Post subject: Reply with quote
Mk1GSF wrote:
Hate to break it to you, but both are multi cylinder.
Smile Yea I'm used to thinking in terms of singles and twins, anything "multiple" is more than that in my book!
It's unbelievable how cheap some of these newer bikes are.
I know it sounds crazy but I like to have a bike appeal to my eye as well as performance and I have a soft spot for the late 80s early 90s stuff.
That FZR 600 above looks great, same with the NC30 and FZR400 of the same era.
Ideally a mix of some performance and fuel economy would be great and not the CB500 (too ugly to like it), would the FZR 400 be less fuel hungry than the 600?
On another note would the FZR 600, FZR 400 and VFR NC30 be at all suitable for city riding? I don't mean riding position I mean the gearing.
95 FZR600 foxeye
I would but the front fairing doesn't appeal to me looks wise!
PostPosted: 21:40 - 23 Mar 2014    Post subject: Reply with quote
You'll be paying for the older looks with older handling and so on - your choice Smile.
PostPosted: 21:43 - 23 Mar 2014    Post subject: Reply with quote
Not sure the FZR400 would be appreciably different to the 600 in fuel consumption.
While you could ride any of the 400s around town, whether it is pleasant might well depend on how flexible you are and how much discomfort you are prepared to put up with. The FZR clutch might suffer a bit from heavy town use (on the plus side, the plates are incredibly easy to change).
koolio
PostPosted: 21:59 - 23 Mar 2014    Post subject: Reply with quote
I know but it must please my eye! Doesn't matter how good the bike is if it doesn't just won't be able to ride and feel good!
Right so is there a gearing difference with the two? I understand the 400s are geared very high with a high powerband, so lots of revving and clutch work around town?
PostPosted: 22:15 - 23 Mar 2014    Post subject: Reply with quote
Depends on where you want power (you do need to rev a GPZ500 for best progress, as they have a fair kick in the power delivery). If you just want to go at normal speed round town I doubt you would need to push any of them hard.
The 400 will be higher revving and think it is a fair bit lower geared.
PostPosted: 22:19 - 23 Mar 2014    Post subject: Reply with quote
Yet you're considering a GPZ500? Laughing
koolio
PostPosted: 23:08 - 23 Mar 2014    Post subject: Reply with quote
I actually like it, I know its so wrong but it's so right! Whereas the CB500 makes me want to vom.
Ah so should be better around town?? Is this the same with the NC30?
PostPosted: 23:20 - 23 Mar 2014    Post subject: Reply with quote
Err, depends what you want. Lower gearing probably compensates for the lower torque (ie, thrust, not flexibility), but does mean quite a lot more revs for the same speed.
The last post was made 12 years, 236 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 135.75 Kb
