| alan0259 |
 alan0259 Nova Slayer
| moonzoomer |
 moonzoomer World Chat Champion
| alan0259 |
| moonzoomer |
| DJP |
 DJP Crazy Courier
 Posted: 22:32 - 23 Mar 2014 Post subject: |
Well if it runs OK cold, that would tend to rule out physical engine damage such as dropped valves etc.
As you've swapped coils, that would seem to rule out electrics.
That just really leaves carbs. I don't really know much about them on this bike, but I'd be having another close look at carb #3. (eg Float heights? Bent needle? Another blocked jet somewhere that you haven't noticed? Correct jets fitted? etc etc).
Failing that, how about getting a used set of carbs and seeing if it runs OK with them? ____________________ Suzuki Bandit 1250
https://deejayp999.atwebpages.com/index.html
That's http not https |
| Major Doss |
 Major Doss Traffic Copper
 Posted: 22:39 - 23 Mar 2014 Post subject: |
The pulse coil on early Hinckley Triumphs were renowned for breakdown when hot, dropping a cylinder. Fine when cold. Just throwing it out there.....  ____________________ Antisocial phucker. |
| P.addy |
 P.addy Red Rocket
| cb1rocket |
 cb1rocket World Chat Champion
| P.addy |
 P.addy Red Rocket
 Posted: 10:49 - 24 Mar 2014 Post subject: |
| weasley |
 weasley World Chat Champion
| alan0259 |
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 12:51 - 24 Mar 2014 Post subject: |
| alan0259 wrote: | Thanks for the replies everyone.
I've remembered that when putting the carbs back on, I was struggling to get to all of the clamps so a couple of carb boots aren't clamped down.
Do you think this could be causing the issue? The two that I tightened were just about accessible so god knows how I'll get to the other ones. |
I would say this is probably the most likely cause. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| alan0259 |
| Pete. |
 Pete. Super Spammer
 Posted: 21:28 - 24 Mar 2014 Post subject: |
Your initial fault sounds like tight valve clearances on that cylinder but after the last post, well, who knows? ____________________ a.k.a 'Geri'
| weasley |
| spikenipple |
 spikenipple Crazy Courier
| salem1987 |
 salem1987 Scooby Slapper
| geordiecbrblo... |
 geordiecbrblo... Trackday Trickster
| 0l0dom0l0 |
 Posted: 10:04 - 25 Mar 2014 Post subject: |
| alan0259 wrote: | Right, weird update.
Last night when I swapped two coil plugs around the fault was still there but I was testing while the engine was red hot.
Today I've done the same tests three times (morning, afternoon,night), all four are now firing fine when first started and also when engine has been running for 10-15 mins.
But now the revs seem to creep up from 1.3k to 2k after 10mins of it running and it requires a big (ish) throttle blip for it to settle again, a small blip seems to keep it at 2k revs.
Also noticed that its making a clicking noise when I first turn ignition on (sounds like the wheel of fortune wheel as its about to stop spinning!).
Well and truly baffled! |
This really does sound like an air leak. One way you can check is by squinting WD40 on the join between the carbs and inlet rubbers with the bike running and if the revs increase you have an air leak.
Personally I would start from scratch now. I'd pull the cards off, re clean and check them and make sure everything (especially cylinder 3) is spot on and standard. I'd also look at the condition of the inlet rubbers over all to see if they are cracked anywhere and if they need replacing.
Then I'd probably change the plugs (can't remember if you have or not). It's also worth mentioning you've changed the caps but have you changed the leads? I reckon a lead might be dodgy and it's breaking down when it gets hot is one option.
After that I'd re start the bike and as above check the charging system is working properly (while its running nicely) and there are no horrible spikes as said.
Hopefully you will find the issue amongst that. If that doesn't work you could check valve clearances but that wouldn't be my choice.
If there is still no avail I would probably then do a compression test as these engines are known for cracking the liners and loss of compression when hot and hence poor running on one cylinder only could suggest a cracked liner.
Keep persisting you will find the problem eventually. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
| orac |
 orac World Chat Champion
| alan0259 |
| alan0259 |
 Posted: 21:16 - 26 Mar 2014 Post subject: |
Ok, decided to tweak the mixture screws on the carbs (whilst still on the bike like a magician!) whilst the tank and airbox was off, I turned them out another 1/2 a turn, so 2.5 turns out from the bottom, then altered idle to suit.
Bike was then idling and revving perfect.
Bingo i thought!
Then i put the plastic tray back on that covers the plugs, airbox, air hoses, fuel tank, seat.
Started it back up and same fault again!!!!!!
This to me is definitely looking like a trapped wire of some sort, maybe the tray catching the plug leads??
It's been running fine for two days then as soon as I out these bits back on it does it again, the first time I noticed the fault it was after putting things back together so it's a pattern.
I'm going to strip bits back off it tomorrow to try identify the problem...
Nightmare!!!! |
| Nemo |
 Nemo Could Be A Chat Bot
 Posted: 21:41 - 26 Mar 2014 Post subject: |
You can't really turn the idle screw a half turn and expect it to be peachy, sometimes it will, but majority of the time it won't.
You need to do it with the engine running, turn the mixture screw and listen for a change in engine tone, when it rises then starts to fall, go back to the peak, that's where you want it, set the idle then move onto the next cylinder.
Whilst you're at it, if you have the gauges, may as well balance them. ____________________ Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo |
| temeluchus |
| Ariel Badger |
 Ariel Badger Super Spammer
The last post was made 12 years, 212 days ago. Instead of replying here, would creating a new thread be more useful? |
