buying 94 suzuki rf 600rr need help
tajlee
PostPosted: 06:06 - 25 Mar 2014    Post subject: buying 94 suzuki rf 600rr need help Reply with quote
What is a fair price for this bike with around 20,60007 on it n its been parked for the last 7 years owned by 65 yr old man and its in excellent condition probably need a carb cleaned n other light maintenance. .. what u think is a fair price 8o)
PostPosted: 07:24 - 25 Mar 2014    Post subject: Reply with quote
£500-600.
PostPosted: 07:59 - 25 Mar 2014    Post subject: Reply with quote
I'd have said about £400 or even less maybe.
PostPosted: 08:46 - 25 Mar 2014    Post subject: Re: buying 94 suzuki rf 600rr need help Reply with quote
tajlee wrote:
its been parked for the last 7 years [...] and its in excellent condition
Garaged? Even so, give it a good going over. Check every piece of rubber for perishing, starting with the tyres. Bounce the suspension front and back several times then check for leaks. Does the chain have any links that aren't seized? Do the brakes engage and disengage? Check inside the tank to see how badly its rusted. Check the exhaust for any signs of leaks - it'll have been corroding from the inside out. The battery is presumably junk, check that it hasn't leaked.
The price will be entirely dependent on how much it's needing done to it. It's not worth spending money on, so make sure you won't have to.
Ribenapigeon
PostPosted: 10:42 - 25 Mar 2014    Post subject: Reply with quote
I was offered a bike in a simerler condition for £400. When I added up the cost of fuly servicing the carb changing al the hoses, new fluids, brake pads and tires. just wasnt worth it.
Pie-Roe
PostPosted: 12:25 - 25 Mar 2014    Post subject: Reply with quote
At that age, the plug caps and HT leads might be on their way out.
The rubbers to the airbox also.
Check for corrosion on the exhaust, they tend to crack at the 4-1 rather than rust.
The three 600s and 3 900s I've had, theres never been a problem with rust in the tank, but it's common for them to rust on the inside of the frame. The fairing infill panels usually are cracked by overtightening the screws.
I found the 600s to be a bit iffy starting in the wet, ended up putting vasoline around the seals to the plugs.
I wouldn't pay more than £400 really, it's not that low mileage for that particular model, as they often have next to no miles. After sitting for that long, you might need new tyres.
There is a RF dedicated forum, but it's a bit shit really.
tajlee
PostPosted: 02:56 - 28 Mar 2014    Post subject: Reply with quote
It has brand new tires front n back n a new chain with about 300 miles on them.... I live up in Minnesota n he said the winter of 07 he didn't put fuel stabilizer in it... I'm thinking. It just needs someone new gas n maybe a couple other things... already got new battery. .. no cracks on bike basically looks brand new
The last post was made 12 years, 232 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 51.4 Kb
