| David072 |
 David072 Nova Slayer
 Posted: 13:47 - 25 Mar 2014 Post subject: Car Help: Failed MOT |
Hi Guys,
Sorry, car question! This is for a 2001 Honda Accord 1.8.
I haven't driven my car at all in the last 6 months, and only did 3k miles since the last MOT. I had it in for it's MOT today and it has failed.
Apparently, the handbrake is only working at 15% efficiency and therefore it failed. The reason, they said, is because the rear brakes need replacing - new discs and pads, because of rust and pitting?
They want £250 inc labour to replace the rear pads and disks.
Thing is, I had planned on selling after it passing the MOT (expected it would fly through, it had no advisories last year and has done only 3k since). If I sell the car, it'll only be worth around £1,000 (despite it having FSH) as its done 100k and is an old car.
Therefore, not sure I can justify spending £250 on getting this fixed. And I'm not entirely convinced it should've failed.
Anyone got any thoughts here? Curious as to what you guys would do at this stage.
Thanks all! |
 - Super Spammer
 Posted: 14:00 - 25 Mar 2014 Post subject: |
How many clicks does it take to get the brake to hold when you pull the lever?
Try adjusting the cable to tighten it a bit. Also once adjusted up, if it's been stood a while, drive a few meters with the handbrake applied to clean off the surfaces of the shoes/drum.
This might help...
https://www.driveaccord.net/forums/showthread.php?t=4565 ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Jaguar S Type 3.0 V6 Sport R, VW Transporter T5 GP LWB Shuttle 140ps DSG. |
| P.addy |
 P.addy Red Rocket
| David072 |
| Northern Monkey |
 Northern Monkey World Chat Champion
| P.addy |
 P.addy Red Rocket
 Posted: 14:11 - 25 Mar 2014 Post subject: |
| David072 |
 Posted: 14:17 - 25 Mar 2014 Post subject: |
I was expecting to sell for around £1k - it's got a solid service history and the cambelt was done about 30k ago if I recall correctly.
There's no major rush to sell it, I'm not in desperate need for the money, more a realisation that I havent driven it in 5 months and may as well sell it.
Thanks for the offer of help, I'm over by Heathrow so probably a bit far out. |
| MarJay |
 MarJay But it's British!
| ficedula |
 ficedula Scooby Slapper
 - Super Spammer
| Rogerborg |
 Rogerborg nimbA
| Busa1340R |
 Busa1340R Nova Slayer
 Posted: 15:16 - 25 Mar 2014 Post subject: |
Used to work in a Honda dealership back in the day. Not uncommon for rear pads to seize to the caliper abutments.
Whilst all of the above could well work, I would probably do this.
Let off the handbrake cable adjuster a bit so that there is plenty of free play.
Remove the rear calipers and wind the pistons back in to ensure that the pistons are not seized.
Take the pads out and (if serviceable) grind/file/clean up (not too aggressively) the top and bottom "ears" on each pad.
Measure the rear discs and compare to Workshop Manual tolerances. They will either be worn or not. Replace only if worn past service limit.
Remove and thoroughly clean the silver coloured anti rattle shims.
Reassmble with a reasonable amount of copper grease on the pad "ears" and backing plates.
Pump out the pads with the footbrake ensuring a firm pedal, before re-adjusting the handbrake cable. I would usually adjust until rear brakes binding and then back off a couple of turns of the adjuster nut.
Ensure everything that you have undone is done up securely and then take it for a good run making full use of the brakes..... ____________________ Current: 2010 Suzuki GSX1340R Hayabusa, 2013 Yamaha YP250R X-Max Sport - Previous: Triumph Sprint ST1050ABS, Honda XL600V Transalp, Honda NT650V Dullsville (don't ask!), Kawasaki ZX9R E1, Honda NX650 Dominator, Suzuki GSX1300RKZ Hayabusa, Honda CBR1000FM, Kawasaki GPZ500S, etc etc |
| Nb |
 Nb World Chat Champion
| bikenut |
 bikenut World Chat Champion
| DrDonnyBrago |
| Llama-Farmer |
 Llama-Farmer World Chat Champion
| David072 |
| dansp1 |
 dansp1 Nitrous Nuisance
| Rogerborg |
 Rogerborg nimbA
| David072 |
| moonzoomer |
 moonzoomer World Chat Champion
 - Super Spammer
 Posted: 23:47 - 25 Mar 2014 Post subject: |
| David072 wrote: | Thanks all.
Took the car for a second opinion and the guy said the rear brake discs were really corroded, which is probably the problem and why they suggested new discs and pads.
Now then... What to do? If I try as you've said, driving with the brake on for a bit, will it remove enough of the rust for me to pass...?
The fail certificate says I can return in 10 days and pay a partial retest fee, anyone know how much that is? |
You could always do what you've done so far and completely ignore the same advice, you've been given several times now!
I can't be arsed typing it out again, I've already posted the link showing how to check the clicks in the lever, adjust the cable and clean the shoe/drum surface.
Are you just hoping someone will look at it for you, or that it will fix itself?  ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
| WD Forte |
 WD Forte World Chat Champion
| bikenut |
| David072 |
The last post was made 12 years, 189 days ago. Instead of replying here, would creating a new thread be more useful? |
